Old 08-18-2009, 05:06 PM   #1
Ctaylor
Ctaylor is on a distinguished road
2006 ION-3 Sedan
Default DTC code P1174
2006 Ion 3 2.4
The check engine light came on and when I plugged my scanner into it I got P1174 but no explanation as to what the code means. Can anyone explain please.
Cheers
Chris
Ctaylor is offline   Reply With Quote
Old 08-18-2009, 07:52 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: DTC code P1174
P1174 indicates fuel trim cylinder balance malfunction. This means that your cylinder-to-cylinder air to fuel ratio is not balanced properly. Usually caused by a faulty heated oxygen sensor located on the exhaust or a simple vacuum leak. It will not harm your vehicle but it will lower your fuel mileage and the engine light will remain on until the issue is fixed
2007 Saturn Ion 2
2003 Chevrolet venture lt
Old 08-18-2009, 08:32 PM   #3
Ctaylor
2006 ION-3 Sedan
Thanks 2006 ion2 for the quick reply. The code is apparently newer than my scan tool
Old 08-20-2009, 07:55 AM   #4
Ctaylor
2006 ION-3 Sedan
Update
I took the car to the dealer last night. They flushed the injectors(at my expense) and said if the code showed up again they would replace all the injectors un warranty
Old 10-02-2009, 10:50 AM   #5
Ctaylor
2006 ION-3 Sedan
Second update
Check engine light came on again and DTC code was the same. Car went back to the dealer who replaced all 4 injectors under warranty
Old 10-02-2009, 11:00 AM   #6
2006 ion2
2007 ION-2 Sedan
good news!!
2007 Saturn Ion 2
Old 10-04-2009, 10:39 AM   #7
G.M.
G.M. is on a distinguished road
G.M.'s Avatar
you must have a 2.4
there's a TSB on those first style injectors. they should have changed them out the first time.
turbo saturn - 400 club
www.sixthsphere.com
http://www.cardomain.com/ride/3895969/1998-saturn-s-series-sl2-sedan-4d
G.M. is offline   Reply With Quote
Old 02-01-2010, 10:33 AM   #8
Graham052
Graham052 is on a distinguished road
How do you know if you have the "first style injectors"? Have an 06 ion 2.4l that has had this code for some time now. Car drives fine, but I would like to fix it. Thanks
Graham052 is offline   Reply With Quote
Old 02-01-2010, 11:00 AM   #9
2006 ion2
2007 ION-2 Sedan
you "should", worst case, be able to have a tech at a GM dealership just look at them and be able to tell you for free.
2007 Saturn Ion 2
Old 02-03-2010, 05:54 PM   #10
Way2QWK
Way2QWK is on a distinguished road
Did they reprogram the PCM? There is a new program that coinsides with the new style injectors.
***Saturn Tech and owner of Planet Automotive in Tucson AZ. Specializing in Saturn repairs.
94 SW2- custom intake and ported throttle body
2003 Saturn Vue 3.0 v6
Way2QWK is offline   Reply With Quote
Old 02-06-2010, 01:02 PM   #11
Ctaylor
2006 ION-3 Sedan
WAY2QWK
Sorry for not replying sooner. According to the work order when they replaced the injectors they updated the PCM software
Old 02-10-2010, 05:51 PM   #12
Way2QWK
The bulletin states that cleaning the injectors will not correct this problem. We have not had any cars return after following the bulletins replacement of injectors and program PCM. Dont know why they didnt follow the bulletin. you may want to go back and ask for a refund on the injector cleaning
Old 02-10-2010, 06:02 PM   #13
2006 ion2
2007 ION-2 Sedan
all said they had them replaced, re read the thread.
2007 Saturn Ion 2
Old 02-12-2010, 02:56 PM   #14
Way2QWK
2006 ion2, You talking to me?
If so read post #4. They charged for a injector clean that doesnt fix the problem.
Old 02-12-2010, 02:59 PM   #15
2006 ion2
2007 ION-2 Sedan
read post 5. yes, they were initially only cleaned, but later replaced. and trying to get GM to refund anything is harder than getting them to cover something under warranty.
2007 Saturn Ion 2
Old 02-13-2010, 11:26 AM   #16
Way2QWK
Gm is not refunding anything, the dealer should. They miss-diagnosed the concern. They should refund the cost of the injector flush. Its worth a try. dont now what your deal is. Our service dept would give the refund. The OP can at least try.
Old 03-05-2010, 12:51 AM   #17
sposadni
sposadni is on a distinguished road
2007 ION-3 Sedan
I am glad to have found this forum. My '07 Ion 3 (2.4L) showed a check engine light and I took it to a dealer here in FL. Of course, the light was not showing when I got there. According to the receipt, it showed DTCS P0171, P0300 and P1174. They replaced the 4 injectors and reprogrammed PCM just as someone here said was the proper fix. With no male figure to help me along with this problem, it was nice to read that they didn't take this old lady to the cleaners. Price=$0.00, covered under warranty!! Thanks!
sposadni is offline   Reply With Quote
Old 03-25-2010, 04:02 PM   #18
jbundy77
jbundy77 is on a distinguished road
Way2QWK,
Do you know the mileage and age limitation for that bulletin. Local dealer says vehicle "not covered under warranty"
Thanks
John
jbundy77 is offline   Reply With Quote
Old 03-25-2010, 11:50 PM   #19
2006 ion2
2007 ION-2 Sedan
just because it is in a TSB does not mean it is covered under warranty or is free. the TSB is issued to tell dealer how to deal with and prevent common problems.
2007 Saturn Ion 2
Old 03-29-2010, 05:06 PM   #20
jbundy77
Originally Posted by Ctaylor View Post
Second update
I know TSB's are not necessarily a warranty item but when I read the above I just assumed they where covered under warranty, if not why did they warranty them? I am just trying to get a second opinion as to when the warranty is up on fuel injectors for this 2006 Ion 2.4. Thanks for the reply!
Dtc 32 saturncrzy S-Series Tech 1 04-02-2009 08:47 AM
DTC Code P0327 Knock Sensor scaragon Ion General 5 09-04-2008 05:39 PM
HELP! DTC code 23, IAT sensor low temp saturn slayer S-Series Tech 4 01-09-2006 01:22 AM
DTC Code 341 "Camshaft Position Sensor"? staffordgt S-Series General 1 09-29-2005 07:46 PM
dtc code -transaxle lee S-Series Tech 4 12-09-2002 05:11 PM
