Old 05-11-2007, 12:49 PM   #1
LaraKimbo
LaraKimbo is on a distinguished road
Default EGR Valve Cleaning - HELP!
My car has been having some idling problems, and we finally figured out it was the intake manifold gasket (Looks like it was installed all nice and wrinkly). So we've got everything out of my car and I was going to get down to the business of cleaning out my EGR Valve.
It is absolutely caked in carbon! I was wondering if anyone has some good tips on how to get a completely encrusted EGR valve clean, what products you use and any tips/techniques that work for you. This it the first time I've tried cleaning it so any help would be appreciated.
THANKS!
2000 SL1 with over 250,000 miles on her.
"Would it save you a lot of time if I just gave up and went mad now?" -Arthur Dent-
Add to LaraKimbo's Reputation
Rate the quality of this post and help LaraKimbo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LaraKimbo is offline   Reply With Quote
Old 05-11-2007, 12:59 PM   #2
BarnOwl
BarnOwl's Avatar
Default Re: EGR Valve Cleaning - HELP!
Lessee dental type picks and compressed air, sea foam or deep creep (Same thing just sprayable.), carb cleaner, brake cleaner. All of those have been used by different people on here with some success. While you've got it off, you can run the engine for 10 or 15 seconds (It'll run like crap.) to blow the carbon out ofthe passages.
Add to BarnOwl's Reputation
Old 05-11-2007, 01:41 PM   #3
99SVLRSC2
99SVLRSC2 is on a distinguished road
I will be completely honest with you, I have taken it off and cleaned it a couple of times with different cleaners, but it never fixed it. I had a local shop to an engine treatment that is to help increase fuel mileage and clean out the deposits in the engine (and EGR supposedly). The EGR still set off the SAS light, but the engine runs a lot better after the cleaning. I got tired of the headache and just went and got a new part from Saturn for $160 and have had no problems since then.
Add to 99SVLRSC2's Reputation
Rate the quality of this post and help 99SVLRSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99SVLRSC2 is offline   Reply With Quote
Old 05-11-2007, 02:34 PM   #4
LaraKimbo
Thanks for all the tips. The EGR isn't the problem, I was just hoping that by cleaning it I would be able to postpone replacing it for just a little while longer.
Old 05-11-2007, 03:27 PM   #5
eljefino
eljefino's Avatar
1995 SW1
Yes cleaning is good for it. The solenoid will prefer if the pintle is free moving, then it won't draw as much current and burn itself out. Eventually the solenoid will get weak and not be able to budge against even small chunks of carbon... then it's $160 replacement time.
Anything that can depress the pintle-- even a pencil-- will work great. Fill the valve up through its open hole with the solvent of your choice then depress the pintle and let that solvent trickle out the pintle hole.
Add to eljefino's Reputation
Old 05-12-2007, 12:13 PM   #6
LaraKimbo
Thanks! the pintle is free moving and most of the carbon is removed. Now to see if I can do better job of installing an intake manifold gasket than saturn!
Cheers!
cleaning egr valve bdobraj S-Series General 14 11-09-2019 09:06 AM
EGR valve cleaning abinder S-Series Tech 9 10-22-2008 05:57 PM
EGR Valve Cleaning clickclickw00t S-Series Tech 1 05-30-2007 03:14 PM
EGR Valve cleaning diablo2070 S-Series Tech 5 04-02-2007 09:11 PM
Cleaning EGR valve wolfehunter S-Series General 9 07-18-2006 11:03 PM
