Old 04-08-2007, 07:36 PM   #61
illenium
illenium is on a distinguished road
illenium's Avatar
1992 SL2
Default Re: URGENT HELP NEEDED!! Spark Wires??
Cleaning the IACV while attached to the throttle body will do little for the servo mechanism inside and behind the valve where it may have debris and carbon exhaust deposits interfering with smooth movement. You don't have any choices, either remove the IACV and attempt cleaning as best you can or contemplate the possibility of replacing it ($$$). I would think that its worth a try to attempt cleaning it since you have nothing to lose and the engine is still running at less than peak performance. You have the throttle body removed from the engine so removing the IACV is just another step in this cleaning process. Just my 2-cents.
The positive crankcase ventilation (PCV) valve is just a one-way valve for engine blow-by gases to be re-introduced back into the engine through the intake manifold. Clean with solvent or replace it.
hi, ok i know now which part you mean, and i took the throttle
body off again, cleaned everything (REALLY CLEAN) and put it
back.
Testride > Same problem
i took 2 short vids today, to show how it cuts off (744kb and 1.3mb)
hitch clutch, rpm goes down, engine cuts off > http://www.illenium.de/saturn/DSCI0055.avi
next traffic light, see the rpm stays straight at 900-1000 when
the car is not moving, speed up, 1st gear, 2nd gear, 3rd gear,
stay on clutch, nearly cuts off > http://www.illenium.de/saturn/DSCI0059.avi
done:
engine check (no codes) (89 USD)
new oil + filter (40 USD)
new airfilter (19 USD)
new ECTS (18 USD)
new sparkplugs (15 USD)
new spark wires (25 USD)
new ignition coils (49 USD)
new air sensor (12 USD)
new idle throttle position sensor (29 USD)
cleaned throttle body + IAC (nada)
Add to illenium's Reputation
Rate the quality of this post and help illenium reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
illenium is offline   Reply With Quote
Old 04-08-2007, 09:48 PM   #62
1-Unable to view videos.
2-Since nothing has changed there are still some things to check;
a)fuel filter changed?
b)fuel pressure regulator; pull the vacuum line off to check the vacuum side of the regulator is not full of gas. No gas verifies a good regulator.
c)was the EGR valve cleaned/replaced? Pull the vacuum line and plug it, the idle should remain the same, drive normally and observe for engine dying again when clutching.
Old 04-09-2007, 10:03 AM   #63
illenium
illenium's Avatar
1992 SL2
the vids works on my computer, i can upload it to
youtube if this would help
the fuel filter was not changed, since the problem only
occures once the engine is warm, but i will replace it
asap (its just a few bucks i think), is the filter located
under the backseat on the fuelpump?
is there a how to for checking the vacuum, i dont know where
to find these parts? is it the line that goes to the pcv? or the lines
on the throttle body?
the egr was not cleaned/changed, i also dont know where this
part is located, hopefully this one works because its very expensive
(100 and up on advanceautoparts.com )
Old 04-09-2007, 10:48 AM   #64
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Originally Posted by illenium View Post
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-09-2007, 03:28 PM   #65
illenium
illenium's Avatar
1992 SL2
Originally Posted by richpin06 View Post
theres no text in your message???
i passed the driving test, car died 3 times, got 6 penalty
points for that (they called it wrong use of the clutch .)
4 stops, 3 times engine cut off
since they gave me 3 penalty points for steering with on hand,
i was close to fail the test
Old 04-09-2007, 03:38 PM   #66
richpin06
richpin06's Avatar
Ya.... what's with that guy...............
I started posting then realized your car was a 92 and not a 99 like i thought.So the info i had didn't pertain.Therefor no text...............
Old 04-09-2007, 11:57 PM   #67
Try cleaning the old EGR valve first; be sure that the shaft will move freely from the open position to the closed position after cleaning the deposits of the pintle valve and shaft. Here's a picture.........
Old 04-10-2007, 03:02 AM   #68
Phredawgy
Phredawgy's Avatar
morse code for uuhhh nevermind
Add to Phredawgy's Reputation
Old 04-10-2007, 10:40 AM   #69
richpin06
richpin06's Avatar
Old 04-10-2007, 10:46 AM   #70
Phredawgy
Phredawgy's Avatar
you were abducted by aliens and they did what?!?!?!?!
Old 04-10-2007, 10:57 AM   #71
richpin06
richpin06's Avatar
Now you can make your own morse code message...............
Old 04-10-2007, 11:02 AM   #72
Phredawgy
Phredawgy's Avatar
looks like a pain in the *- *** ***
Old 04-13-2007, 04:14 PM   #73
illenium
illenium's Avatar
1992 SL2
hello, i allready bought a new fuelfilter, so i will
clean the egr
repleace the fuel filter
this weekend, if the weather isnt too bad!!
car took me to washington and back, was
running ok, but still cutted of sometimes
in the stop and go traffic in dc
i'll let you know on sunday or monday
if this solved the problem.
ps: morse codes...reminds me of my military time in austria
Old 04-18-2007, 04:04 PM   #74
illenium
illenium's Avatar
1992 SL2
hey guys, i wasnt able to change the fuel filter by now
because of the bad weather
the car is now runing very rough, it also makes
noise since a few days. when i start the cold
engine i can hear a strange sound, like something
is squeaking, like drill into metall, i have to record
it because i dont know how to describe it.
somethings really wrong
once the engine is warm, the noise goes away, but its
runing very rough, its hard to keep a constant speed,
like when im driving 30mph its shaking me back and forward
i dont know if this is something that has to do with the
egr, which i also have to clean on the weekend
seems like my saturn will break down soon
Old 04-19-2007, 11:47 AM   #75
illenium
illenium's Avatar
1992 SL2
to everyone that can help on this matter, i'll start
working on the car on saturday at 11-12am my time (baltimore, md)
i'll set up the webcam and go live on www.stickam.com , my
user id is illenium2002, chat enabeled, everone whos interested
in watching and giving advices what i should check and to
do it is very welcome.
this is my last try on this car, i'll give it new spark plugs (changed 3 weeks
ago > maybe bad part?), fuelfilter, clean the egr, check the ects again,
new o2 sensor, clean the throttle body again
i dont now how to inspect the belts, would be nice if someone could
take a look at it it via the webcam
thanks, juergen
if its raining, i wont work on the car, if you want to notify me
before i start working, send me a message on here
Old 04-19-2007, 01:29 PM   #76
illenium
illenium's Avatar
1992 SL2
sorry, if you want me to notify you send me a message
Old 04-24-2007, 11:46 AM   #77
illenium
illenium's Avatar
1992 SL2
ok, egr was sticky, cleaned, the knocking noise is nearly gone!!!!
New fuel filter installed.
Throttle body checked again, IAC and TPS cleaned again,
electrical connections cleaned again, wires checked, spark
plugs checked.
still the same problem
Old 04-24-2007, 01:24 PM   #78
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
Originally Posted by Luke View Post
Reading the spark plug wells, from left to right, as:
[1]> > > [2]> > > [3] > > > [4]
The respective plugs wire should sit on top of the coils as:
[4]> > > [1]> > > [2] > > > [3]
With the above in mind, the top of the left most coil, should go to plug well [4].
The second from the left coil [2], should go to spark plug well [1]
The third from the left coil [3], should go to spark plug well [2]
the fourth from the left coil [4], should go to spark plug well [3].
There should be a graph on the center of the engine compartment's radiator, just where the hood latches to the center grill area.
Would this be the same for a 97 S series?
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 04-24-2007, 03:50 PM   #79
Yes, but by "left to right", Luke means YOUR left to right, standing under the hood, that is, the CAR's rightmost plug (by the reservoir / washer fluid) is #1.
Add to madpogue's Reputation
Old 04-25-2007, 01:06 PM   #80
illenium
illenium's Avatar
1992 SL2
ok im lucky, one of my colleagues knows a mechanic
that will have a look at it FOR FREE!!
maybe he can tell what the problem is, we'll meet this
weekend, once i know it, i'll go ahead and post it in
here with a review of the issues and the solution.
wish me luck
Spark Plug Wires Firing Order 01SC02 S-Series Tech 17 12-11-2019 12:44 PM
What is the spark plug wires firing order hook up? 96 sl1 AtlanticBeach S-Series Tech 2 08-13-2009 07:53 PM
spark plug wire order nmsaty S-Series General 5 02-10-2006 11:59 PM
Order of Spark Plug Wires? kossuthreb S-Series Tech 4 04-30-2005 01:50 AM
1995 SW2 spark plug wire order and torque? 95 staturn Mods and Performance 1 04-18-2005 08:29 AM
