Old 05-15-2006, 08:34 PM   #1
IceMan2
IceMan2 is on a distinguished road
Default Wiper Motor Replacement
Can anyone give me a heads up as to how to get to the front wiper motor for replacement, 00 LW series. I can see it, but not sure how to get the plastic guard off. Thx
Add to IceMan2's Reputation
Rate the quality of this post and help IceMan2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IceMan2 is offline   Reply With Quote
Old 05-15-2006, 11:02 PM   #2
lostwages_ls2
lostwages_ls2 is on a distinguished road
lostwages_ls2's Avatar
Default Re: wiper motor replacement
Remove wiper arm finish caps.
Mark both wiper arm positions on windshield by using a wax pencil or tape.
Remove wiper arm retaining nuts and washers.
Remove wiper arms.
Remove weatherstrip at rear of hood.
Remove grill nuts from base of wiper arm shaft.
Remove grill.
Remove electrical connector from wiper motor.
Remove wiper motor retaining bolts.
Remove wiper motor assembly from plenum area.
If replacing wiper module bushings, remove steel bushing first, then rubber grommet.
Remove motor from transmission assembly.
Replace as necessary.
INSTALLATION
Install wiper motor to transmission assembly.
If wiper module bushings were replaced, install rubber grommet first, then steel bushing.
Install wiper motor to plenum area.
Install wiper motor retaining bolts. Torque: 5 N.m (44 in-lbs)
Install electrical connector to wiper motor.
Install weatherstrip at the rear of hood.
Install grill.
Install grill nuts to base of wiper arm shaft.
Install wiper arm assemblies at mark made during removal or at Park position if a new wiper motor is installed.
Install wiper arm retaining washers and nuts. Torque: 28 N.m (21 ft-lbs)
Install wiper arm finish caps.
Verify correct wiper system operation.
Your Honor Student is merely a pawn in my Min Pin's diabolical world domination plot.
Obey the Min Pin
Add to lostwages_ls2's Reputation
Rate the quality of this post and help lostwages_ls2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lostwages_ls2 is offline   Reply With Quote
Old 05-16-2006, 02:18 AM   #3
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
Make sure to get the rotating shaft from the motor to the transmission in between the alignemt marks after "homing" the wiper motor. If not, things will get WACKY!!!
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-16-2006, 07:43 PM   #4
IceMan2
Thanks for the help, it took about 2 hours with the help of a neighbor and $42.00 for the part. My local Saturn tech also helped out.
Old 05-16-2006, 08:52 PM   #5
1stSaturnowner
1stSaturnowner is on a distinguished road
1stSaturnowner's Avatar
2001 L-Series 2.2L Sedan
Cool, I am glad someone was able to help you out IceMan2. I saw your thread, read it, and was not able to reply, due to my lack of never doing this, but I hope Charlie will see this thread, and put it in the How-to section of the forum.
D.J.
Add to 1stSaturnowner's Reputation
Rate the quality of this post and help 1stSaturnowner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1stSaturnowner is offline   Reply With Quote
Old 02-11-2011, 01:30 PM   #6
sjfishon
sjfishon is on a distinguished road
sjfishon's Avatar
2000 L-Series 2.2L Wagon
Default Re: Wiper Motor Replacement
i am glad i saw this post, my daughter is coming home from college in a few days, she has a oolw1 i need to replace the blower motor, and was wondering how to take the wiper arms off, all cars are dif, THanks
Add to sjfishon's Reputation
Rate the quality of this post and help sjfishon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sjfishon is offline   Reply With Quote
Old 04-28-2011, 05:03 AM   #7
keithreed
keithreed is on a distinguished road
Need help also.. Thanks
Add to keithreed's Reputation
Rate the quality of this post and help keithreed reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
keithreed is offline   Reply With Quote
Old 10-11-2011, 05:58 PM   #8
hubesiagosa29
hubesiagosa29 is on a distinguished road
Sorry, thats challenging, I would advice you go to the nearest motor garage
[url=http://primus.org.uk/]Professional seo services[/url]
[url=http://1stpetinsurance.co.uk/]Pet insurance[/url]
[url=http://convertyourgold.com/]Cash for gold[/url]
Add to hubesiagosa29's Reputation
Rate the quality of this post and help hubesiagosa29 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hubesiagosa29 is offline   Reply With Quote
wiper motor gregory_t S-Series Tech 3 01-08-2008 11:22 AM
Wiper motor Geronimo S-Series Tech 4 10-06-2007 09:08 PM
96 SL Wiper Motor 96saturnslowner S-Series Tech 1 03-06-2007 09:20 PM
Wiper Motor or something else loki S-Series Tech 3 06-15-2006 09:16 PM
96 SC2 Wiper Motor replacement grandpastock S-Series General 3 09-15-2005 02:47 AM
