Old 03-28-2006, 11:01 AM   #1
Luke
Luke's Avatar
Default Fuel System Operational Pressure Test
Fuel System Operational Pressure Test: 1995 SL 2
SOHC/DOHC engine at idle:
Min system pressure > 31 psi
Max system pressure > 36 psi
SOHC/DOHC engine with key on / engine off:
Min system pressure > 38 psi
Max system pressure > 44 psi
BTW, the fuel rail pressure regulator can be functionally checked by removing the vacuum line, at the regulator, with the engine's rpm at idle. The pressure should vary from 6-10 psi.
Add to Luke's Reputation
Luke is offline   Reply With Quote
fuel pressure test port? nitroussaturn Vue Tech 7 11-01-2009 03:00 PM
What is the proper way to do a fuel pressure test? groingo S-Series General 3 07-09-2009 12:20 PM
fuel pressure test que 97sl2 97sl2DOHCaut1.9 S-Series Tech 1 03-14-2009 12:10 AM
How to make a surge tank cap to help pressure test your coolant system Grandpa Joe S-Series General 2 06-30-2006 01:30 PM
How to pressure test coolant system with no radiator cap? Grandpa Joe S-Series General 17 06-28-2006 03:43 PM
