Old 01-28-2004, 12:11 AM   #1
Hittman
Hittman is on a distinguished road
Default evap canister purge solenoid
Has anyone replaced this solenoid and how much of a pain in the ass is it? My girlfriend's car needs it and I want to see what I am getting into. Its a 95 sc1 sohc
Add to Hittman's Reputation
Rate the quality of this post and help Hittman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Hittman is offline
Old 01-28-2004, 12:46 AM   #2
wolfman
wolfman's Avatar
Default
It is difficult to get to. The CCPS is bolted to the engine above the starter below the intake manifold. If you'll check my "member gallery" (just click on the little camera by my avatar) you'll find a picture ("S" series engine labeled) of it's location on a removed engine. Hardest part is getting to it. One bolt screwed right into the engine's aluminum block holds it in place.
Add to wolfman's Reputation
wolfman is offline
Old 01-28-2004, 01:23 AM   #3
Hittman
Default
Is it possible to get to it from underneath? or do I have to remove the damn intake?
Hittman is offline
Old 01-28-2004, 01:30 AM   #4
wolfman
wolfman's Avatar
Default
From below is realistically the ONLY way. I will add that many techs (including myself when I worked for Saturn) don't actually remove the old one...just unplug the electrical connector and vacuum lines, hooked them up to the new one, and tiewrap the new one to the intake manifold tightly up out of the way leaving the old one in place and disconnected. The solenoid itself does NOT need to be mounted or grounded to teh engine block to work correctly..
wolfman is offline
Old 01-28-2004, 02:04 PM   #5
Dach
Dach is a jewel in the roughDach is a jewel in the roughDach is a jewel in the rough
Default
One more tidbit, check the condition of the vacuum line to it, it may be rotted away within a foot of the solenoid.
Add to Dach's Reputation
Rate the quality of this post and help Dach reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dach is offline
Old 01-28-2004, 06:25 PM   #6
Hittman
Default
Thanks guys that sounds like a good idea. I will have to try that when I get home. Do you guys think I should get one from the dealership or just get a junkyard piece. I just don't want to do it twice.
Hittman is offline
Old 01-29-2004, 12:28 AM   #7
Dach
Default
Definitely a dealer part. I did mine and I think it was about $20 or so. Are you having a quad driver fault? I can't remember if '95 has linear egr but if not you may as well change your egr solenoid too. They die hand in hand w/the purge solenoid.
Dach is offline
Old 01-29-2004, 11:06 AM   #8
Luke
Luke's Avatar
Default
Actually, I also replaced mine last year, and the work went very smoothly -- working from underneath. A flashlight will be helpful. BTW, after replacing it, I found that it was not necessary.
Fm Wolf
Very good idea, Wolf; For future reference, thank you...
Add to Luke's Reputation
Luke is offline
EVAP canister purge solenoid location CA-Legal-Vette S-Series Tech 3 10-19-2008 05:41 PM
canister purge solenoid - where can I buy!! lee L-Series Tech 3 03-25-2008 08:11 PM
EVAP purge solenoid hufhouse L-Series Tech 3 01-04-2008 11:49 PM
canister purge solenoid jaylie S-Series Tech 1 09-25-2005 10:30 PM
Location of canister purge solenoid and vent solenoid? jslw300 L-Series Tech 2 05-05-2005 07:36 PM
