Old 05-04-2019, 03:11 PM   #1
jlbmusic
jlbmusic is on a distinguished road
Default ABS sensor
The ABS sensor bolt snapped when I was trying to remove it. Does anyone know the specs for that bolt. I need to replace it.
Add to jlbmusic's Reputation
Rate the quality of this post and help jlbmusic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jlbmusic is offline   Reply With Quote
Old 05-04-2019, 06:09 PM   #2
Default Re: ABS sensor
Unless someone knows the exact bolt size and thread, the easiest way to find out is either having or removing a similar bolt that fits the bolt hole or remove another abs sensor bolt (preferably not seized in place) to have for matching a replacement. Whenever removing nuts or bolts, if you can anticipate corrosion, sometimes seen as rust or severe corrosion), spray penetrating fluid to allow it to soak in and loosen seized fasteners. Sometimes heat or some hammer blows can help break corroded rust and bolts creating the mechanical equivalent of loctite.
Old 05-09-2019, 10:43 AM   #3
TomM96
If the bolt Head is 10mm, it's probably M6X1.
If bolt Head is 13mm, its likely M8X1.25.
Those most common of small fastenings....
When install new fastener, use some grease or rtv.
Add to TomM96's Reputation
Old 05-09-2019, 07:22 PM   #4
Macgyver
95% sure it's M6x1. Buy stainless steel hex flange bolts so it doesn't happen again.
Add to Macgyver's Reputation
2000 Saturn SL2, Self Revving Engine, Coolant Sensor or Throttle Position Sensor? aygc271 S-Series Tech 5 08-06-2018 08:39 PM
P013B O2 Sensor Slow Response Lean to Rich Bank 1 Sensor 2 Bee 2008 Vue 12 01-14-2017 04:59 PM
Codes: cylinder 3 miss fire, camshaft position sensor. Transmission range sensor Puck head S-Series Tech 13 01-12-2012 08:52 PM
error code 1137- O2 sensor bank 1, sensor 2 location? jwox L-Series General 3 03-09-2011 12:06 AM
PO133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) Donny L-Series Tech 5 02-16-2007 01:21 AM
