Old 06-13-2019, 07:50 AM   #1
rfisher
rfisher is a jewel in the roughrfisher is a jewel in the roughrfisher is a jewel in the rough
Default the old blower motor switch trick
hi Saturn sages- been up against poor depictions and instructions in Haynes manual on switch r and r. need your specific guidance if you have done the switch job on an L series. new switch delivery was postponed to today or tomorrow . can get bezel off and control unit unscrewed. how do you then get the old switch out and new one in? since unit looks fragile, want to get it right the first time. shyster dealer and an indy wanted 325 and 290 for job. nothing changes does it. thanks tons bob f
Add to rfisher's Reputation
Rate the quality of this post and help rfisher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-13-2019, 07:11 PM   #2
Dsaturn
2001 L-Series 2.2L Sedan
Default Re: the old blower motor switch trick
It has been over a year since I did mine so I can not remember what was involved. I remember a couple of screws and so real brittle plastic that can break if you are not careful. https://www.partsgeek.com/gbproducts...E#immersedview
Add to Dsaturn's Reputation
Old 06-14-2019, 10:50 PM   #3
rfisher
hi dsaturn- got the new blower switch delivered today. seems there are two electrical plug connectors in the back of the heater ac control assembly . also appears you have to disconnect the temp dial cable. also appears radio has to come out. not sure about the blower switch. seems it has to slide out form the back. unclear how it locks in place though. sound right to you so far? thanks tons bob f
Old 06-16-2019, 07:42 AM   #4
Dsaturn
I did not take radio out but for better access it is probably a good Idea. Yes the switch comes out from the back and if I remember correctly you have to separate the heater control face from the back as in that pickfrom parts geek. That is where the brittle plastic is.
Blower (Motor/Resistor/Switch) Issues coryreid Ion General 5 11-19-2015 02:45 AM
blower motor not working - getting 12 v @ motor until on djcrisco S-Series General 3 10-13-2015 08:01 AM
Blower motor runs real low with switch off. TCPSW2 S-Series General 6 03-11-2012 08:48 PM
Trick To Changing Top Motor Mount? bountyhunter S-Series Tech 11 03-20-2011 02:05 AM
HVAC Blower Motor Dying...can one fix motor? flyhop S-Series Tech 2 09-28-2006 10:08 PM
