Old 11-28-2018, 03:35 AM   #1
StrnWolf
StrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura aboutStrnWolf has a spectacular aura about
1994 SL1
Default Solder or crimp?
I need to replace my ECTS connector, and redo the joints for my ICM connectors to make them water tight, and repair or replace some other connectors as well. My question is, would it be better to solder the joints or crimp them? For solder it would be a 60/40 of tin/lead. Either way there will be heat shrink tubing over the joints to seal them. For me, either way would be same amount of work, I just want the best connections so will do what is best.
07/2018-PRESENT 1995 SL2
04/2009-04/2019 1994 SL1
Add to StrnWolf's Reputation
Rate the quality of this post and help StrnWolf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
StrnWolf is offline   Reply With Quote
Old 11-28-2018, 07:07 AM   #2
Waiex191
Waiex191's Avatar
Default Re: Solder or crimp?
I soldered mine.
http://www.saturnfans.com/forums/sho...=234273&page=7
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-28-2018, 08:55 AM   #3
RobertGary1
Done right I prefer solder but crimping with a proper crimping tool is pretty fool proof and as you said you can get crimps with heat shrink ends.
-Robert
Old 11-28-2018, 09:28 AM   #4
trottida
trottida's Avatar
Solder for sure. Especially the ETCS connector because it carries a very low power signal and crimp connections have proven to be a failure point time and time again.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 11-28-2018, 09:34 AM   #5
For the soldering challenged this is an almost fool proof solution. The ECTS uses the white splice as the red one is a bit too large. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
You will need a functional heat gun, not a Harbor Fright special either. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Temperature control is a requirement with this type of connector so the Master Appliance 751 is not what you want to use unless you have a great deal of experience with heat guns.
A proper crimping tool is going to be more expensive that these pieces.
Old 11-28-2018, 09:54 AM   #6
2NDSOUT
2NDSOUT's Avatar
1999 SL
Solder is always going to give you a better electrical connection.
I would only crimp, if the area that you are in, on the vehicle, allows for decent movement and reach ability to get to the wiring.
Solder is always going to win.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 11-28-2018, 03:17 PM   #7
billr
Ha, I can't resist getting into this fray! Crimp is actually more reliable, but only if you have a quality tool and terminals. As pointed out, that can get more expensive than most DIYers will put up with, so they use inadequate tools/terms and have poor results.
For an in-line application like this, "stiffened" with the heat-shrink, I would probably go with solder. But at a connector housing, crimp terms are less likely to result in broken wires. Look at OEM wiring harnesses, how many crimps do you see vs, soldering?
Add to billr's Reputation
Old 11-28-2018, 03:31 PM   #8
Waiex191
Waiex191's Avatar
At the helicopter factory where I used to work it was all crimp for reliability. No radio shack or AutoZone parts there though. If you follow my link above, the reason I folded the wires on themselves was to support the solder joints with unsoldered copper.
Bryan Cotton
Old 11-28-2018, 03:59 PM   #9
billr
Yeah, I was going to throw that out, but wasn't sure it still applied. When I worked in aircraft over-haul many years ago they were transitioning from solder to crimp for connectors because of wire fatigue. Had banned Teflon tape on pipe threads too, because of contamination in servo-valves.
Old 11-28-2018, 04:42 PM   #10
RobertGary1
Same here. Soldering only allowed for avionics. Everything is crimped with approved parts and tools.
Thinking is that aircraft vibration could fail a solder.
-Robert
Old 11-28-2018, 05:05 PM   #11
GTS350
GTS350 is a jewel in the roughGTS350 is a jewel in the roughGTS350 is a jewel in the rough
If done correctly either way will work well. The key is "done correctly" bad soldering technique or cheap crimpers is usually the flaw with bad connections.
1999 Saturn SC2 (automatic) 23,000 orig miles (9/10/16)
1996 BMW E36
1971 Holden Monaro GTS 350
1908 Buick Model 10
Its official Saturn Night has removed all doubt.
Add to GTS350's Reputation
Rate the quality of this post and help GTS350 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GTS350 is offline   Reply With Quote
Old 11-28-2018, 07:22 PM   #12
Proper soldering REQUIRES a strong mechanical joint before soldering. Proper crimping REQUIRES a gas tight crimp which requires either ratcheting or hydraulic crimpers using specific wire size dies.
The 3 size fits all crimper and open barrel insulated splices from Harbor Freight or FLAPS do not meet the minimum standard.
Old 11-28-2018, 08:15 PM   #13
gveinot
gveinot is just really nicegveinot is just really nicegveinot is just really nicegveinot is just really nice
gveinot's Avatar
2000 SL2
2000 SL2
Solder them. The only reason factories crimp is it is faster to do, regardless of the industry or sector. With solder, the connection is less prone to corrosion. Wires are never crimped to a circuit board, they are soldered. Think about it.
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gveinot is offline   Reply With Quote
Old 11-28-2018, 08:44 PM   #14
SlayZombi
SlayZombi is a jewel in the roughSlayZombi is a jewel in the roughSlayZombi is a jewel in the roughSlayZombi is a jewel in the rough
2001 SL
I always try to solder. I use Rosin-core electronic safe solder and follow it up with a watertight electrical tape wrap. Soldering is less likely to fail and I just feel better knowing that the wires are fused together with metal and not just held on by friction/crushed.
Add to SlayZombi's Reputation
Rate the quality of this post and help SlayZombi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SlayZombi is offline   Reply With Quote
Old 11-28-2018, 08:44 PM   #15
RobertGary1
Except as pointed out above the FAA prohibits solder because a professional crimper is more reliable and less prone to breaking from vibration.
-Robert
Old 11-28-2018, 08:55 PM   #16
The soldering process when not properly sealed or the use of incorrect flux does indeed lead to broken wiring. Due to this the probability of failure between the average soldering job and a proper crimp is large. This is why the FAA dictates crimps. The rest of the crimp requirements are several pages of rather expensive requirements. In the ground based world soldering has it over common crimps in spades. Aircraft is its own world.
Old 11-28-2018, 10:50 PM   #17
StrnWolf
1994 SL1
Well then... I do not have any crimping tools, and I know I will get crap with this but when I replaced the ICM connectors, I used Harbor Freight crimp tool, AND dumb me forgot to put the tubing on first and yet I had a roll with me FOR the job. Would Radioshack's 0.063" thick Rosin-Core 60/40 solder work for the job? If not, then what would be BEST?
I have never had to solder anything that is prone to vibrations and movement, so what would be the proper way to solder the joints so they do not fail?
Also, where can I get heat-shrink tubing that would survive being near the engine?
Last question for now is, I know in some circuits, length of wire can sometimes have some effect, so would having longer than original wire after jobs between PCM and ECTS and then PCM and ICM change anything? Currently there is about 3 inches more of ICM wire than OEM, but I could cut more wire to make it shorter. And I have yet to receive ECTS connector and will try to make it as short as possible but question remains.
Old 11-28-2018, 11:25 PM   #18
gveinot
gveinot's Avatar
2000 SL2
2000 SL2
Most automotive shrink tubing will be able to withstand the temperatures of the engine area except for the exhaust manifold and associated exhaust pipe. As for adding 3 inches, do not worry about that, just use the same gauge of wire to ensure the current flow capabilities. Just don't buy craft store or dollar store low cost stuff. The wire should also be automotive type. I was a MTI certified Motorola two was radio tech, back in the day when cell phones cost $5000 and had a large RF Deck in the trunk. Motorola, the people who built the radios on the Lunar Rover, demanded and taught us to solder any joints. I understand the crimp issue on aircraft but that type of crimp is an industrial type device with an expansive tool and special crimps. Solder is the way to go under the hood of an 18 year old car.
Old 11-29-2018, 12:01 AM   #19
The radio shack solder will work if you have an iron that will produce sufficient heat. Out of the wind helps. To make the mechanical joint bend the stripped ends about 1/8"- 1/4" from the insulation at 90 degrees to form an "L", do this to both wires. Hold the wires so the bet "L"s overlap and then wrap each bent leg around the other wire. They will easily hook over each other once stripped and bent so the twisting part is easy. The wire is twisted into that little 1/8"-1/4" uninsulated area on each wire. Practice indoors with a couple of lengths of spare wire first. Once twisted together solder the wires together.
Old 11-29-2018, 02:27 AM   #20
StrnWolf
1994 SL1
Weird, I have never done that before, but when I read the post about having to make sure it's a stronger joint, that is exactly what came to mind but I was not sure until this post.
Question splicing Air Fuel sensor ? Solder shortrun S-Series General 20 02-08-2016 08:43 PM
Overheated solder RobertGary1 S-Series Tech 4 01-16-2013 07:53 PM
Solder vs crimp religious debate RobertGary1 S-Series Tech 32 12-18-2012 06:32 PM
ECTS Replace and Solder in connector Nick96'SL2 S-Series Tech 9 05-21-2011 10:18 PM
Solder radio pt2 RobertGary1 S-Series Tech 25 12-31-2009 01:19 AM
