Old 07-27-2003, 09:12 PM   #1
silverblue02
silverblue02 is on a distinguished road
Question what size tire?
My 2002 SL needs tires. I have the factory 14'' rims. Can I go from a P185/75R-14.......to a 195/60R-14? I just want my tire to be a little fatter, not so much of a donut.
Add to silverblue02's Reputation
Rate the quality of this post and help silverblue02 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silverblue02 is offline
Old 07-27-2003, 09:55 PM   #2
wolfman
wolfman's Avatar
Default
Consult the web site http://www.tirerack.com for the sizes and upgrades available for your car (free) and probably teh best prices you will find as well. I highly recommend them.
Add to wolfman's Reputation
wolfman is offline
Old 07-27-2003, 10:25 PM   #3
silverblue02
Default
I appreciate your help,.....and yes they do have cheap tires. The Yokahama seem to spark my interest. Too many to choose from.
Old 07-28-2003, 12:19 AM   #4
Arnel
Arnel is on a distinguished road
Arnel's Avatar
Location: Pittsburgh, PA - Home of the World Champion Steelers & Penguins!
Default Re: what size tire?
That size tire should fit. The last two sets of tires (1) Falkens, 2)Uniroyals) that my wife has had on her SL1 were that size. Prior to that the SL1 ran 185/75-14's.
Just check that the tire diameter is similar to the OEM tires. On www.tirerack.com, you can check to see the size of the original Firestone Affinities or FR680's??? Someone please correct me if I'm wrong on the OEM tire.
93m SL1 "SLone" 145,000 mi. - RIP 10/08
94m SL2 "Ringo" 209,425 - ret. 7/31/07, RIP 10/08
01m SC2 "Lello" 129,000
07a GL VUE "Orbit" 48,900 - RIP 6/19/10
10a Ford Escape Hybrid - 8600 mi.
Add to Arnel's Reputation
Rate the quality of this post and help Arnel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Arnel is offline
Old 07-28-2003, 01:53 AM   #5
amazinghl
Default
http://www.miata.net/garage/tirecalc.html
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 07-28-2003, 10:20 AM   #6
eRic 02sc2
eRic 02sc2's Avatar
Default
also check on http://www.discounttiredirect.com they show plus zero options.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 07-28-2003, 09:26 PM   #7
FrozenPilot
FrozenPilot's Avatar
Default
My '95 had 175/70r14 as the OE tires, until I put some 185/65r14 replacements on. Check with the widest approved rim width for the tires on tire rack. Generally for the saturn 14"x7.5" wheel, you won't get any bigger than the 185 size.
Its all about the coffee...
'06 Mazda 6i & '95 Saturn SL1
Add to FrozenPilot's Reputation
Rate the quality of this post and help FrozenPilot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FrozenPilot is offline
Old 07-28-2003, 10:09 PM   #8
Arnel
Arnel's Avatar
Default
We had both sets of 195/60r-14's approved by Saturn. We had checked with TireRack then Saturn to play it safe.
Arnel is offline
Old 07-29-2003, 01:51 AM   #9
silverblue02
Default
thanks for all the help,.....much appreciated!
Old 07-29-2003, 11:57 AM   #10
SL2Ghost42
SL2Ghost42 is on a distinguished road
SL2Ghost42's Avatar
2000 SL2
2004 VUE 2.4L
Default
When I got my car, the back two tires were bald, so I went to my local trusted tire dealer, Plaza Tire. They had only TWO tires types in that would fit my car, and one of them was just plain, little technology put into the tire, only rated for half the milage of regular tires, etc. The guy I usually deal with, did NOT like those tires already and they had been in the store for only 2 weeks.
The other tires were the Yokohama tires, which looked a lot better technology-wise, and only cost about $30 more for both tires. So I went with the Yokohama and they rotated them so the Yokohamas went on the front. I also got the warantee on them (ALWAYS GET THE WARANTEE. You will NOT REGRET IT.)
When my other two tires wear out, I'll be getting two more Yokohamas on there, which I will probably do before winter hits in.
2000 SL2 107,000 "Little Saturn" - Daily Driver
2004 Vue 125,000 "The Vue" - Work Vehicle
Add to SL2Ghost42's Reputation
Rate the quality of this post and help SL2Ghost42 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2Ghost42 is offline
Old 07-30-2003, 04:42 PM   #11
benson500
benson500 is on a distinguished road
benson500's Avatar
There is a pretty big difference in overall tire height and circumference in the two tires you're talking about. The 195/60 is more than 1-1/2" shorter than the 185/75. This will result in your speedo being off by almost 10%. You'll be going quite a bit slower than your speedo indicates. This will also have a noticable affect on your final drive ratio -- you will be turning the engine 10% faster to go the same speed.
You should probably stick to 195/70's or 205/65's and, as noted, check the wheel specs to see if they'll handle the bigger size.
Regards.
[I]Former owner: '93 SC2 and '03 ION3.....[/I]
Add to benson500's Reputation
Rate the quality of this post and help benson500 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
benson500 is offline
Old 07-31-2003, 10:01 PM   #12
silverblue02
Default
Thanks for the advise Benson!
Old 08-01-2003, 01:10 AM   #13
Arnel
Arnel's Avatar
Default
Benson500, your claim is true, to an extreme.
When I did a comparison between the car's original tires, Firestone FR680's, I believe, and the current set, Uniroyal Tiger Paw Nailguard GT's there was a difference of .25 inch.
The prior set of tires, Falkens, sorry I can't remember the exact model, were shorter and fatter than the current set of tires WHILE both being 190-60R14's!
Silverblue02, to get an accurate measure, I would suggest checking your future tire's spec's with the appropriate OEM tire for your car.
Arnel is offline
17" Konig Unknown, size? tire size? 92[SL2] S-Series Tech 1 05-14-2007 11:45 PM
tire size adan976g Vue Tech 8 05-01-2006 05:08 PM
tire size custom1 S-Series Tech 6 03-07-2006 08:54 PM
Tire size SoUp S-Series Tech 4 09-07-2002 09:31 AM
Tire size Raiderdean S-Series Tech 2 02-25-2001 04:08 AM
