#1 | ||||
![]() This is a '98 SL2. The joint where the fuel line goes into the fuel rail is leaking. That's a QD joint. I'm really at a loss on how to go about fixing it. Hopefully I can just take it loose, clean it up and reseat it. I'll try that as soon as it cools. If that doesn't do it, I dunno.
... There is nothing more frightening than ignorance in action.
#2 | ||||
![]() There is a semi captive o-ring in there and it is probably nicked. Some are orange and easy to see and others are just black viton. Buna - N will work as well.
#3 | ||||
![]() I wasn't able to get to it till this morning. It's fixed but, what I found bothers me almost as much as the original problem. I went to take the line loose and it was already loose. I just pushed it back on and heard it snap in. The thing is we had made a couple stops and smelled gas before we got home. I wasn't certain it was our car till I looked at it. When I did get a look at it and saw the leak, it was running. So, it actually ran like that.
I ran it for a while and attempted to pull the line loose. It seems to be secure but, I can't imagine how this could have happened. I'm just going to drive it and keep an eye on it for a while. I'd still like to know how it happened. ... There is nothing more frightening than ignorance in action.
#4 | ||||
![]() Those types of connectors can go on crooked and not latch on both sides. As the actual pressure that would force the connector to separate from the nipple they usually hold even when only half latched for a long time. This type of failure has happened before and when it actually leaks they are reseated and stay latched this time.
Fuel Line Supplier?-pressurized line is leaking | Reliabilityman | S-Series Tech | 1 | 05-06-2015 12:31 PM |
About the LEAKY Fuel regulator........... | TomM96 | S-Series Tech | 10 | 01-08-2010 11:50 AM |
Fuel line specs on a 1998 Saturn Sl 1 (fuel injected) | WadeNKC | S-Series Tech | 9 | 01-07-2010 06:42 PM |
What happens if you kink/bend a fuel line during fuel filter installation? | Dingo Warrior | S-Series Tech | 4 | 05-31-2008 10:43 PM |
Clutch / leaky fuel line problems with 2004 Vue | addicted2mickey | Vue Tech | 0 | 11-09-2007 01:13 PM |
