Old 10-16-2013, 03:09 PM   #1
MikeNW
MikeNW's Avatar
1997 SL
Default subframe bolt torque; belt tensioner
Does anyone know the torque values for the subframe bolts (18 mm socket)? Seems that I can't find this in my *cough* comprehensive Haynes booklet...
Also, does anyone have a drawing showing the belt tensioner? I think mine is bad, but would like to see how it is attached to the engine before I mess with it.
Thank you!
08 Burgman 400
Add to MikeNW's Reputation
Old 10-16-2013, 03:36 PM   #2
proveniebam
proveniebam is a jewel in the roughproveniebam is a jewel in the roughproveniebam is a jewel in the rough
Default Re: subframe bolt torque; belt tensioner
Re: Belt tensioner
Two bolts. *****es to take off as they're likely rusted in place.
Top bolt accessible from the top (10mm i think). Long handle needed or you'll shred your knuckles.
Bottom bolt accessible from below (through the wheel arch). You'll need to push the adjuster out of the way too. But as mine was broken that was simple.
For me the bottom bolt was seized solid. Ended up drilling the head off and welding the tensioner to the bolt left on the engine.
Also I couldn't insert the new tensioner because the frame rail to the engine was too narrow (probably twisted chassis). Had to remove the 'pulley' using an impact wrench in inserted after the body of the tensioner was in place.
This was odd because the old tensioner came out without a problem.
Add to proveniebam's Reputation
Rate the quality of this post and help proveniebam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
proveniebam is offline   Reply With Quote
Old 10-16-2013, 04:21 PM   #3
Wolfman posted all the S-series torque specs here
http://www.saturnfans.com/forums/sho...ghlight=torque
Says cradle to body bolts are 151 ft/lbs - not 100% sure these are the ones you're talking about, but seems like a good guess
Pretty good pic of the tensioner here, pic by Hunt4Steve in his rebuild thread
http://i950.photobucket.com/albums/a.../Engine068.jpg
(tensioner is the left most black pulley)
edit: circled the tensioner bolts in his pic - and (unless someone has been mucking things up) they are indeed 10mm like proveniebam said
Old 10-16-2013, 04:24 PM   #4
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
Like Proven said.
Make sure to use a 10mm 6 point socket. You can also remove the top engine mount and jack the engine up to give yourself plenty of room.
I made this just now:
http://youtu.be/sPFuACW2vtQ
Shawn
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 10-16-2013, 05:50 PM   #5
OU812
OU812 has a spectacular aura aboutOU812 has a spectacular aura about
1996 SL1
Richpin has a video removing the tensioner.
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
Old 10-17-2013, 12:41 PM   #6
MikeNW
MikeNW's Avatar
1997 SL
Very awesome, thank you!
08 Burgman 400
Please Help: Rounded belt tensioner bolt Dude13450 S-Series General 21 10-21-2018 08:15 PM
Belt Tensioner Mounting Bolt chadfend S-Series Tech 5 08-19-2010 05:57 PM
Broken belt tensioner bolt.... Baron5867 S-Series Tech 6 01-29-2010 10:08 PM
rounded bolt on belt tensioner, now what? DJboozeAlot S-Series Tech 5 06-25-2009 07:27 PM
Tensioner/Idler pulley bolt torque pimpin88 S-Series Tech 4 01-31-2009 05:05 PM
