Old 04-26-2012, 12:41 PM   #1
StormGrey05
StormGrey05 is on a distinguished road
Question ABS Sensor
I have a 2005 Saturn Vue 3.5L V6. The ABS and Traction Control Light recently came on after I replaced front brakes and rotors. I had it diagnosed and was told the left rear ABS sensor is bad and was quoted $229 to fix. The part appears to be around $50-80. How hard is this to replace myself, and are there any pitfalls to be aware of.
StormGrey05 is offline   Reply With Quote
Old 04-26-2012, 02:11 PM   #2
Chazberry
Chazberry's Avatar
1995 SW2
Default Re: ABS Sensor
RockAuto has sensors from $29-67. They are held into the Hub Ass'y with one socket head screw. The connector just plugs in. Very easy DIY.
Old 04-26-2012, 04:09 PM   #3
StormGrey05
Thank you for the information. It appears to be pretty straightforward. I'm due for some rear brakes anyway, so I'll just tackle all of this at once.
As an FYI, I asked the guy at the shop about installing the sensor and he said the one thing he comes across occasionally is that the sensor is easy to brake off if in the mounting hole if it is gummed up in there and you're not careful pulling it out. He suggested carefully twisting back and forth and slowly working it out to avoid snapping the sensor off in the hole.
Old 04-26-2012, 04:54 PM   #4
Chazberry
Chazberry's Avatar
1995 SW2
Couldn't hurt, but I've never had a problem pulling one out.
PS - the Front and Rear Sensors have different gender connectors. I see ACDelco sells a kit - probably with both male and female connectors.
Old 04-27-2012, 09:23 AM   #5
StormGrey05
Thanks again for the info. I'll make sure to check the connector type.
Tags
abs, left rear, sensor, traction control
Codes: cylinder 3 miss fire, camshaft position sensor. Transmission range sensor Puck head S-Series Tech 13 01-12-2012 08:52 PM
Bank 1 Sensor 1 O2 sensor in a 2003 V6 Saturn Vue fwimbe01 Vue General 1 12-07-2011 09:24 PM
Bad Crank Sensor/02 sensor/fuel pump help!! Olegoat Vue Tech 4 09-05-2011 06:23 AM
error code 1137- O2 sensor bank 1, sensor 2 location? jwox L-Series General 3 03-09-2011 12:06 AM
PO133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) Donny L-Series Tech 5 02-16-2007 01:21 AM
