Old 06-04-2010, 01:56 AM   #1
PowerHaus930
PowerHaus930 is on a distinguished road
Default Whats your MPG?
I just wanted to starty a thread to document different cars MPG. I know there is a big variation of MPG that everyone gets depending on Sx1 or Sx2, manual or automatic, and mods. So i'm asking for you to state the year, model, transmission, mileage, and mods to get a better idea of what these cars can do.
95 SL1 w/88K
5 speed
HAI reading about 150*-160*
Tires up to 39psi
Engine cut-off switch on shifter
Best MPG - 42.51
Avg MPG - 39.48
I keep a gas log over at http://ecomodder.com/forum/em-fuel-l...vehicleid=3890 I definetly would reccomend keeping a log to keep an eye on your MPG. Plus it's fun to drive for MPG. I have a goal of 50MPG which i will break at some point i hope.
Add to PowerHaus930's Reputation
Rate the quality of this post and help PowerHaus930 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PowerHaus930 is offline   Reply With Quote
Old 06-04-2010, 08:51 AM   #2
tufamc
tufamc is on a distinguished road
tufamc's Avatar
1999 SL
Default Re: Whats your MPG?
I drive 280mi round trip to work and back 5 days a week. I drive the exact same route and full up at the same gas station, even the same pump, every morning. I really haven't tried too much in the way of mods, reliability is my main concern. Durring the winter I avarge 34-37mpg, and durring warmer temps 50*+ I usally get 39-42mpg. Car is BONE stock as of right now. I use mobil clean 5000 5w-30, mobil 1 atf, Kumo power stars 758 for tires, and never exceed 3k rpm. I'm going to try to attach my mpg logs.....
Add to tufamc's Reputation
Rate the quality of this post and help tufamc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tufamc is offline   Reply With Quote
Old 06-06-2010, 01:57 AM   #3
PowerHaus930
wow nice logs. i wish i could get those numbers stock. after some inconsistency with my MPG i believe i may need to replace my ECTS. other than that ive cleaned the throttle body , EGR, seafoamed the intake and gas tank and replaced plugs. so im not sure what the variable could be.
Old 06-06-2010, 12:03 PM   #4
fquan59
fquan59 is on a distinguished road
In the city, I get at least 30 MPG. On the freeway, it's usually in the upper 30s to low 40s.
1997 Saturn SL2, 5-speed
Add to fquan59's Reputation
Rate the quality of this post and help fquan59 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fquan59 is offline   Reply With Quote
Old 06-08-2010, 12:02 AM   #5
flythatway
flythatway is on a distinguished road
2002 SL1
I hit 45 mpg for the first time on my last tank of gas. I get much better mpg when I'm not running the airconditioner, but I had to run it a few times which may have hurt me...I've documented 8 mpg lower when running the AC. I have no mods although my tires are not stock...tires are slightly taller than stock...I have to add 5.4% to the mileage before dividing by fuel used. I drive about 65% hwy. I'm somewhat of a hypermiler...I coast if no one is behind me to stop lights/signs/turns and I try to keep my speed at or below 60 mph, but I won't impede traffic. Sometimes I'll switch the engine off if I have a long ways to coast (if its safe) and sometimes I'll do it when I'm going to be stopped for more than 30 sec. Also, the warmer/humid months give me about 5mpg better than the colder months.
2002 SL2 manual w/ about 144k...I don't pay much attention to my tire psi's.
2002 SL1 5-spd
Turn your AC off to save 6 to 8 mpg!
Just joined the 40 mpg club!
Add to flythatway's Reputation
Rate the quality of this post and help flythatway reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
flythatway is offline   Reply With Quote
Old 06-08-2010, 12:09 AM   #6
flythatway
2002 SL1
Also, my thermostat went bad last year (noticed my temp gauge showed lower than normal) and lowered my mpg by about 5...replaced it and my mpg (and temp gauge) went back up to normal. I usually avg about 40.
I wonder if I blocked some of the incoming air in the colder months if I would hurt anything and gain better mpg?
2002 SL1 5-spd
Old 06-08-2010, 01:19 AM   #7
PowerHaus930
by blocking the air do you mean blocking air from coming into the engine compartment? If so many people that hypermile and modify their cars for better gas mileage will block the air on the front spoiler or bumper from coming through the radiator. Its called a grill block and it helps the engine to warm up faster as well as keep the intake temps up. Of course if i were to do this modification i would not block the grill completely and keep my eye on the temp gauge as much as possible at first, then if it seems to work well with no overheating maybe i would block a little bit more. It is supposed to help alot during the winter and in colder climates. Another thing after reading some information about what "lugging the engine" really means i have started to shift alot lower then i used to. I now shift between 1600-1900rpm and it seems to be helping out mileage quite a bit. I accelerate rather slowly so it takes a little while to get up to speed but i dont mind.
Old 06-08-2010, 03:06 PM   #8
adventureoflink
adventureoflink's Avatar
'97 Saturn SL2, WAI, autotragic transaxle (), nearing 156k miles.
took it on a road trip a little while back, and got about 37MPG
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 06-08-2010, 06:20 PM   #9
sousa632
sousa632 is on a distinguished road
sousa632's Avatar
1995 SW2
With me, my wife, my 2 kids and stuff in the back to get through a day trip we were able to get 40mpg with the SW2. Most of the time it's in the mid 30's with just my wife driving in stop and go traffic 65 miles a day for work. I dont think I have seen sub 30's numbers with that car. My car........ that's a WHOLE different beast
John
96 Tbird 4.6L, 95 Saturn SW2
Add to sousa632's Reputation
Rate the quality of this post and help sousa632 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sousa632 is offline   Reply With Quote
Old 06-09-2010, 03:17 PM   #10
manualman
manualman is on a distinguished road
1995 SL
02 SOHC SL stick w/ 116k miles
Last three tank full runs were 40, 37 and 40. Lotsa freeway time, but not all!
O2 sensor is new, ECTS is brass, plugs are new NGKs and thermostat is 195F Stant. Passed IL emissions today-hurrah.
I call it my Polish hybrid.
Japanese hybrid Prius burns combination of gasoline and electricity for 49mpg average mileage, but $24,000 cost.
Polish hybrid (Saturn) burns combination of gasoline and ENGINE OIL for 38mpg average mileage and $2,800 purchase price.
Conclusion: Polacks rule.
Add to manualman's Reputation
Rate the quality of this post and help manualman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
manualman is offline   Reply With Quote
Old 06-10-2010, 12:34 AM   #11
bumpdraft
bumpdraft's Avatar
1998 SW2
1998 SC2 Manual Transmission without (silly plastic ) spoiler installed
about -1 deg. negative camber all 4 OEM alloy_wheels and allignment set by me
Horrible Michigan Roads
Engine not an oil-burner (maybe~1 cup of oil between 3000 mile change)
With my old tires that had about 1/4 of their tread left:
(mostly) Highway Mileage 55 to 75mph,
87 Octane Speedway Gasoline:
"Summer Tires" (the ones that came from the factory. I had 8 of them)
11-03-2008, 285 mi = 34.2 mpg
11-06-2008, 274 mi = 36.4 mpg
11-07-2008, 314 mi = 35.9 mpg
04-13-2009, 90 mi = 35.6 mpg
04-24-2009, 305 mi = 36.4 mpg
05-18-2009, 243 mi = 34.1 mpg (e)
05-19-2009, 71 mi = 39.0 mpg
05-20-2009, 219 mi = 36.8 mpg
05-28-2009, 227 mi = 34.3 mpg
05-31-2009, 274 mi = 38.1 mpg
Ave of Last 3 Fills = 35.8 mpg
05-31-'09 Ave of last 2 fills = 36.3 mpg
06-05-2009 298 mi + 208 mi = 37.3 mpg Ave
olde Blizzak WS15 (that didn't squirm all over <heck> like my current WS60's do) OEM Steel Wheels
Winter tires (and Winter gasoline blend?):
11-23-2008, 259 mi = 33.0 mpg
11-24-2008, 207 mi = 34.1 mpg
12-04-2008, 297 mi = 32.6 mpg (a)
12-16-2008, 257 mi = 34.3 mpg
01-03-2008, 237 mi = 32.4 mpg (a)
01-03-2008, 259 mi = 34.4 mpg
01-05-2008, 216 mi = 32.9 mpg
01-18-2009, 278 mi = 32.5 mpg (b)
01-18-2009, 203 mi = 35.4 mpg
01-18-2009, (33.7 mpg Ave.)
02-04-2009, 30.8+33.2=31.8 mpg Ave. (c)
02-24-2009, 33.5+31.8=32.8 mpg Ave.
03-08-2009, 266 mi = 33.9 mpg (d)
03-09-2009, 33.9 + 34.9 = 34.3 mpg Ave.
^Notes:
(a) some short trips and warm-up idling
(b) Entire trip on packed snow and ice
(c) Air Temp ranged from -24 deg F to 11 deg F (and , yes, I checked tire pressure)
(d) 70 mph in apocalyptic cross-winds for half the trip
(e) some city driving = killed mileage
Notes:
New 87 deg. C Thermostat 12-13-2008
Current mileage with new With new Firestone Firehawk GT 195/60R15, 55~75mph highway is in the 34 to 35mpg range.
They are stiff.
Larger diameter not only makes mileage seem less because of rev/mile...but I am also driving faster at the same spedo reading:
Also, recent New Rear Hubs/bearings (maybe they are still a little stiff?)
http://www.saturnfans.com/forums/sho...d.php?t=154791
Add to bumpdraft's Reputation
Old 06-10-2010, 12:36 PM   #12
joshuh
joshuh is on a distinguished road
Whereabouts in Michigan? I'm in Big Rapids.
Add to joshuh's Reputation
Rate the quality of this post and help joshuh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
joshuh is offline   Reply With Quote
Old 06-22-2010, 11:12 PM   #13
bumpdraft
bumpdraft's Avatar
1998 SW2
Average of last thee fills; starting and ending on the same gas pump:
757.4 miles = 34.976 mpg (and driving kinda fast)
...and I put the silly plastic back on the trunk lid!
Where's the bad roads? I-75 as it passes thru Arenac, Bay, Saginaw and Genesee Counties!
I am ready to pull over and Air-Down the tires!
If you see me, I'll be the irritating driver who just wizzed past you when the roads were good...
...and then slowed down to 65mph in the locations where the road crew placed 3/8" ~ 3/4" high speed bumps over the cracks in the road...or where it looks like the road's been beaten by a pile driver!
Old 06-22-2010, 11:20 PM   #14
mr18436572
mr18436572 is on a distinguished road
2000 SL2
2000 SL2 automatic. All stop-and-go city driving, 185* thermostat, 38-40 psi in the tires.
About 300 miles to the tank without A/C
About 270 with A/C
2000 SL2 auto - 167k - sold
1996 SL2 auto - 161k - sold
1997 SC2 auto - 105k - sold
2000 SC2 auto - 117k - sold
1996 SL2 auto - 250k - sold
2001 SC2 5sp - 160k - sold
Add to mr18436572's Reputation
Rate the quality of this post and help mr18436572 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr18436572 is offline   Reply With Quote
Old 06-23-2010, 11:43 AM   #15
joshuh
Default
We've got pretty good highway road over here, but the "main" roads are atrocious. They redid my road a couple years back, but only up to the entrance to the college kid apartments. Just goes to show what they consider important around here.
Old 06-23-2010, 12:39 PM   #16
bbarbulo
bbarbulo is on a distinguished road
with an SL1, i doubt that's by choice
sorry for the intrusion, carry on. to stay on topic, highway i get a nice 35ish or better, city it drops to maybe 25?
SW2m
Add to bbarbulo's Reputation
Rate the quality of this post and help bbarbulo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bbarbulo is offline   Reply With Quote
Old 06-24-2010, 06:02 AM   #17
mjoekingz28
mjoekingz28 is on a distinguished road
Yeah, I notice about a 8mpg drop with the Ac on. Everyone was telling me 10% is normal, but 8mpg is more like 20%.
Add to mjoekingz28's Reputation
Rate the quality of this post and help mjoekingz28 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjoekingz28 is offline   Reply With Quote
Old 06-24-2010, 10:39 AM   #18
sl2eggplant
sl2eggplant is on a distinguished road
Gas log for 99 SL2
Getting close to 40 mpg on daily route 64 miles roundtrip (85% highway, 15% city)
I'm nearing the end of my aero mods (coroplast hub caps, wooden belly pan, some grill block). Planning on installing rear wheel skirts, finishing / tweaking my belly pan, maybe some partial front wheel skirt. Other more drastic aero mods (wish list) include a nose job (smoothing front bumper / head lights area), smaller driver side mirror, and other little things.
Non-aero mod include max sidewall tire pressure, HAI, and driving without shoe.
Add to sl2eggplant's Reputation
Rate the quality of this post and help sl2eggplant reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sl2eggplant is offline   Reply With Quote
Old 06-24-2010, 09:28 PM   #19
Signmaster
I think a lot of that is determined by weather, drive cycle, and other such variables that make the MPG people get vary a lot to begin with. My drop is closer to 10%, but city traffic around here isn't all that terrible. I'd imagine that with more stop and go it would suffer worse, as the initial acceleration and idling would be affected the most by having more parasitic draw from the AC when you really need the power.
Back to the actual topic.
Bone stock '95 SL1
With AC on most of the time in the summer 30-31. No AC about 34-35. This is rarely even getting on the highway, with a longest highway trip during my work week of about 10 miles.
On a road trip I consistently crack 40+, and even with AC use and 70-75 mph averages have got 42+.
Old 06-25-2010, 11:30 PM   #20
guy_450
guy_450 will become famous soon enough
guy_450's Avatar
2001 SW2
I drove non-stop my SW2 on a distance of 432.8 Km (258.8 miles) on highway cruising at 115-120 Km/h (71-74 mph) and got 6.13 l/100 Km (46 mpg US), figured with a thank fill on both ends. Need new spark plugs and wires for sure
Out of subject:
I did test drive this week on a brand new Ford Fusion SE 2.5l (4 cyl) with a 6 speed manual tranny and I must say I have been impressed! I almost signed but there was none 2010 available in my area, whatever the color, with these 3 simple options: a) 6-speed Man. b) moonroof c) Sync for the Bluetooth.
Anyway, I have to postpone new car purchase until next year to replace my *hum* signature blue car once my son being graduated...
2001 SW2 4AT silver (garaged, 2000 SW2 5MT sold)
2013 VOLT, now it is son's DD, it has replaced my former 2002 SL2
2019 VOLT electric instant torque & regen braking + range extender
Add to guy_450's Reputation
Rate the quality of this post and help guy_450 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
guy_450 is offline   Reply With Quote
Whats Your Best MPG ??? core2009 Ion General 53 09-20-2016 05:49 PM
whats better travis123 S-Series Mods 8 04-09-2006 08:45 PM
Whats the best mod you've done to your car Punkunity Mods and Performance 17 10-02-2003 03:43 PM
Whats Next??? sc2point0 Mods and Performance 7 06-01-2003 05:11 PM
Whats Up With XRC? Bouncewitme Mods and Performance 4 03-14-2003 04:06 AM
