Old 05-22-2009, 02:24 AM   #1
H-Dogg
H-Dogg is on a distinguished road
Default P0340 ses code
I searched threads for anything about this code and I followed everyone's advice, I replaced the spark plugs with copper ones, got new plug wires, and cleaned up the piece behind the coil packs. This fixed the problem for a day but the ses light was still on and it's slowly starting to go back to how it ran before. What's my next move?
Add to H-Dogg's Reputation
Rate the quality of this post and help H-Dogg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
H-Dogg is offline   Reply With Quote
Old 05-22-2009, 03:08 AM   #2
Default Re: P0340 ses code
DTC P0340 Camshaft Position (CMP) Sensor Circuit
And there aren't any other codes? Have you scanned fo any new codes? You can always pull the PCM fuse to reset the codes and try again. Wait 5-10 seconds before putting the fuse back in. Get the code(s) read again if they pop up.
If there's misfiring with the ignition system, the coils and ignition module that the coils sit on need to be cleaned so good electrical contact is made to the blades and ground. The mounting bolts need wirebrushing to clean off corrosion as they serve to ground the ignition system. Use dielectric grease on the coil towers for light lube and corrosion prevention. Regular grease to coat the bolts as a cheap corrosion prevention.
Be sure there aren't any new error codes if the SES light turns on again by re-scanning.
Please HELP! p0340 error code. silenz S-Series Tech 3 12-08-2006 10:13 PM
Continuous SES code p0340 plainzwalker S-Series General 3 05-06-2005 05:03 PM
P0340 code readout lordshaq Miscellaneous Tech 3 10-04-2004 05:32 PM
Still need help with P0340 code jegster S-Series Tech 7 07-01-2003 11:39 PM
SES P0340 code help jegster S-Series Tech 8 04-22-2003 09:45 PM
