Old 02-12-2009, 01:33 PM   #1
Mark S.
Mark S. is on a distinguished road
2002 L-Series 3.0L Sedan
Default Body Control Module
My L200 has about 74k. The first weird symptom was that the Security system was engaged with the key fob, it would not let you in with the key fob. Had to use the key. The dash lights flashed on and off during the 10 minute drive home. I removed the battery cable and it seemed to work fine after it reset. That particular symptom occurred twice in a few weeks. Lately, the BCM emits a static sound when the lights are on only. I removed the BCM and checked for poor connectors/connections. Reconnected and the noise is still present when the lights are on. the noise is coming from the door chime transducer/speaker on the BCM board. I don't wasnt to spend $500 or so for a BCM replacement until I am certain it is going bad. Also, It the BCM going bad, or is it just a minor hiccup? Any advice would be appreciated.
Thanks! Mark
Add to Mark S.'s Reputation
Rate the quality of this post and help Mark S. reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark S. is offline   Reply With Quote
Old 02-12-2009, 01:49 PM   #2
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default Re: Body Control Module
You might have to bite the bullet on this one.
It sure sounds like a BCM. I would take it to the dealer and see if that door chime is causing some issues first.
BTW, while you may get a BCM somewhere else, you still need the dealer to reprogram it, and any key fobs you have.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline   Reply With Quote
Old 02-12-2009, 08:44 PM   #3
Mark S.
Bik,
Thanks for the post. I may wait until more symptoms get worse. Only the buzzing door chime transducer(speaker) so far. Just annoying, but not screwing anything up yet.
Old 02-13-2009, 09:52 AM   #4
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Prepare for the worst.
A member here posted one time of horns honking & lights flashing while his car was parked.
When mine went, the odometer read 628,000 miles.
I had only 41k.
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Body Control Module question alethia L-Series Tech 50 10-10-2011 09:44 AM
Body Control Module (BCM) HAS82 L-Series Tech 1 06-08-2009 03:20 PM
SL 1 series Body Control Module midnight5683 S-Series Tech 1 06-20-2008 12:17 AM
Body Control Module Rick M Vue General 1 01-08-2008 10:58 AM
05-06 Body Control Module needed cpformula Ion Tech 11 01-09-2006 12:47 AM
