Old 10-18-2008, 02:33 PM   #1
CA-Legal-Vette
CA-Legal-Vette is on a distinguished road
Default EVAP canister purge solenoid location
Originally Posted by Low Saturn View Post
http://www.differentracing.com/tech_...es/dtc/26.html
A 26 by itself usually indicates a bad or failing CCP (charcoal cannister purge) solenoid. Its located on the back of the engine under the intake manifold.
But it could be one or more of eight different things.
OK. I finally worked through the whole diagnostic with everything checking out. EGR solenoid resistance is at 40.6 ohms.
Now let us assume for a moment that I have no idea of what a purge solenoid looks like or where it is located............... Please help!
On a related note, who on earth thought it made sense to combine the fuel line bracket with the EGR mounting bolts? After removing and cleaning the EGR twice, this bracket is so bent up that it is only a cut hazard.
By the way: 94 SL1 Automatic - 160k miles
Add to CA-Legal-Vette's Reputation
Rate the quality of this post and help CA-Legal-Vette reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CA-Legal-Vette is offline   Reply With Quote
Old 10-18-2008, 02:46 PM   #2
1995sl1sohc
1995sl1sohc is on a distinguished road
1993 SL1
Default Re: EVAP canister purge solenoid location
On the top of the throttle body there is 2 small vacuum lines that lead down behind the engine, follow these and they will lead to the canister solenoid. Very hard to see from the bottom, you will be working by feel most of the time unless you remove the starter. It is held on by a single 10mm bolt, keep track of which line goes where.
Richpin06 also has a video of it that was very helpful, probably in the sticky in the how to library.
Add to 1995sl1sohc's Reputation
Rate the quality of this post and help 1995sl1sohc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1995sl1sohc is offline   Reply With Quote
Old 10-19-2008, 08:29 AM   #3
Crasoum
Crasoum will become famous soon enough
1993 SL2
Why would it be important to know which line goes where, doesn't it just open a vacuum to the engine when energized?
Add to Crasoum's Reputation
Rate the quality of this post and help Crasoum reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Crasoum is offline   Reply With Quote
Old 10-19-2008, 05:41 PM   #4
jamie930
jamie930 is on a distinguished road
that is what I thought too. But I got the SES light for evap system switched the lines around SES light went away. It knows some how
Add to jamie930's Reputation
Rate the quality of this post and help jamie930 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jamie930 is offline   Reply With Quote
EVAP purge solenoid hufhouse L-Series Tech 3 01-04-2008 11:49 PM
CCPS (Carbon Canister Purge Solenoid) location? xupthree60 S-Series General 2 03-25-2006 02:05 PM
canister purge solenoid jaylie S-Series Tech 1 09-25-2005 10:30 PM
Location of canister purge solenoid and vent solenoid? jslw300 L-Series Tech 2 05-05-2005 07:36 PM
evap canister purge solenoid Hittman S-Series Tech 7 01-29-2004 11:06 AM
