Old 07-03-2008, 01:09 PM   #1
d_rock
d_rock is on a distinguished road
d_rock's Avatar
2005 ION-3 Quad Coupe
Default Theft-deterrent Radio Installation?
I pulled a Saturn CD-player w/EQ from the junkyard, and it says Theft Deterrent on it.
I want to replace my stock cassette player with it.
Are there any issues I should know about since it is theft deterrent? Will it most likely be locked since it was from a junked car?
"Pessimists see the glass as half empty, optimists see the glass as half full. Engineers see that the glass is twice as big as it needs to be."
2005 Saturn Ion-3 Quad Coupe, Automatic
Add to d_rock's Reputation
Rate the quality of this post and help d_rock reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
d_rock is offline   Reply With Quote
Old 07-03-2008, 01:21 PM   #2
awprice
awprice is on a distinguished road
awprice's Avatar
2004 ION Red Line
1999 SL1
Default Re: Theft-deterrent Radio Installation?
I dont think you should have issues with it.
Add to awprice's Reputation
Rate the quality of this post and help awprice reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
awprice is offline   Reply With Quote
Old 07-03-2008, 01:45 PM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
Theres is a how-to on getting it unlocked. I did it yesterday.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 07-05-2008, 07:46 PM   #4
d_rock
d_rock's Avatar
Well it turned out to not be locked and it works great! Horray for great sound quality.
However, um, I have a problem...
When I press the rear de-fogger button, it doesn't light up...and it's not raining or snowing or anything so I don't really know how to test it.
I unplugged the battery when I swapped the radios themselves, but then stupidly I forgot to plug the de-fogger back in and I did so AFTER reconnecting the battery...could this have caused a short? bad fuse?
Old 07-05-2008, 08:45 PM   #5
d_rock
d_rock's Avatar
I just noticed that my chime isn't working either...maybe a bad chime module?
Old 07-05-2008, 08:47 PM   #6
Time to start checking fuses.
Old 07-05-2008, 09:36 PM   #7
d_rock
d_rock's Avatar
Should I be looking for fuses for the defogger/froster or fuses for the chime? or both?
Old 07-05-2008, 09:39 PM   #8
I have not cheated and looked at a schematic but I think you want to check the body fuse first. That is the Sat eve guess. I will go dig up a diagram and refine that if that does not get it. There are two places to check, The kick panel fuse panel and the under hood junction block, its next to the battery.
Old 07-05-2008, 09:43 PM   #9
Carl26
Carl26 is on a distinguished road
Carl26's Avatar
I'd check both fuses. As for testing the defogger, you can unplug the connector at the back window, turn on the defogger switch and check for power at the connector with a 12 volt test light. A test light is also a quick and easy way to check fuses without removing them.
Add to Carl26's Reputation
Rate the quality of this post and help Carl26 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Carl26 is offline   Reply With Quote
Old 07-05-2008, 10:07 PM   #10
Everybody should have a good test light or a multimeter. You are lost without one or the other.
Old 07-05-2008, 10:14 PM   #11
d_rock
d_rock's Avatar
Guys, I was about to pull out my multimeter and do some testing, but my defroster AND chime are miraculously working...funny how cars will fix themselves sometimes
All I did was remove one of the rear defogger fuses and put it back in.
Old 07-05-2008, 10:22 PM   #12
Dirty connections are a common problem with old cars. Causes All kinds of grief. Absolutely impossible to predict the failure symptoms.
Unlocking Theft Deterrent Radio kx250ryder How-To Library 128 03-03-2018 04:58 PM
How to tell - Theft Deterrent Radio. Red97sc2 S-Series Tech 5 09-16-2008 11:48 PM
Theft Deterrent Cd Player stang50 S-Series General 5 08-06-2007 01:46 PM
A different theft deterrent radio question BarnOwl S-Series Tech 9 05-22-2007 06:27 PM
Theft Deterrent malfunction? smull333 S-Series General 3 03-16-2005 07:41 PM
