Old 08-06-2005, 11:16 AM   #1
Luke
Luke's Avatar
Information Spark Plug "Corona Stain"
Corona Stain:
A brown stain - often mistaken for gas leakage - is sometimes observed in a ring around where the insulator joins the metal shell of the spark plug. This discolouration is generally called Corona Stain and is the result of oil particles present in the air around the engine adhering to the insulator surface.
The Corona Stain is often seen on spark plugs that are installed deep into the engine such as on many four valves per cyclinder engine applications. This is because oil particles are not blown away by air circulating around the engine compartment and thus adhere to the insulator surface. It is imporant to understand that Corona Stain causes no deterioration to the function of the spark plug.
http://www.ngkntk.co.uk/technicaltips/coronastain.asp
Add to Luke's Reputation
Rate the quality of this post and help Luke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Luke is offline   Reply With Quote
Old 09-26-2005, 12:48 PM   #2
Heartbeat - '95 SL2
Heartbeat - '95 SL2 is on a distinguished road
Heartbeat - '95 SL2's Avatar
Default Re: Spark Plug "Corona Stain"
I guess that's a good indicator of a leaking cam cover gasket, even before it gets out-of-hand. Good topic, Luke, I always thought it was just heat discoloration!
Add to Heartbeat - '95 SL2's Reputation
Rate the quality of this post and help Heartbeat - '95 SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Heartbeat - '95 SL2 is offline   Reply With Quote
Old 11-07-2005, 07:47 AM   #3
jambra1
jambra1 is just really nicejambra1 is just really nicejambra1 is just really nicejambra1 is just really nice
1999 SC2
Luke,
I know this is a couple months after your post, but thanks for posting these pictures. I just changed out the plugs on my wife's 99 SL2 yesterday and this is EXACTLY how all four of the plugs looked. Additionally, I noticed that the threads on the cylinder end of the plug each had a thin film of oil on them.
I'm going to proceed on the assumption that the cam cover gasket is beginning to leak even though there was no real accumulation of oil in the plug wells and the plug wire boots were clean. It seems that if there is indeed a leak, it's fairly recent and not all that profuse at the moment. Better to catch it early in the process and nip it in the bud.
Thanks for the link.
Add to jambra1's Reputation
Rate the quality of this post and help jambra1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jambra1 is offline   Reply With Quote
"NEW" Spark Plug.. Better Than NGK ? richpin06 S-Series General 18 01-14-2007 01:15 AM
Spark plug wires (another "what's the best" thread) L200Pilot S-Series Tech 6 12-01-2006 05:36 AM
Spark Plug Help, Silverstone Plugs Vs. The "Others" Mr.Barrett S-Series Tech 11 12-21-2005 06:22 PM
Spark plug wire has "chew" marks? Norseman S-Series General 6 08-08-2005 12:17 PM
"Reading" a Spark Plug DualCamCoupe How-To Library 3 08-31-2003 11:20 AM
