Old 02-24-2019, 04:26 PM   #1
Silverblu02SL2
Silverblu02SL2 is a jewel in the roughSilverblu02SL2 is a jewel in the roughSilverblu02SL2 is a jewel in the rough
Default fuel economy, range , fuel gauge accuracy
What are you getting for fuel economy on your Saturn? I am new to this 02 SL2 automatic with 62k orig miles. The last tank was around 20 mpg w 60/40 city/ hwy. The PO kept extensive mpg records since new and it had 38 mpg tanks all hwy for highs to lows of 19 mpg city driving.
I I filled it up 2 weeks ago for the first time (let the pump click off automatically w/o filling it to the brim). At 180 miles, fuel gauge needle is just a hair under 1/4. Is that about right?
Where is the needle when the low fuel symbol comes on? With 12.1 gal tank, @ 20 mpg, it looks like I need to go to a gas station at around 230 miles or risk running out of fuel!
In contrast, my 92 VW diesel has a 14.5 gal tank and gets 43 mpg hwy. I typically go fill up at the 500 mile mark.
Did Saturn purposely make the tank so small to force you go to the gas station more often to check the oil?
1/28/2019 2002 SL2 w 62k miles
Add to Silverblu02SL2's Reputation
Rate the quality of this post and help Silverblu02SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Silverblu02SL2 is offline   Reply With Quote
Old 02-24-2019, 04:37 PM   #2
Default Re: fuel economy, range , fuel gauge accuracy
The low fuel light is supposed to come on with 1 1/2 - 2 gallons reaming, that has been to be in serious error though so YOU get to test it out. Mine comes on at 0.75 gallon FYI.
City stop and go will be in the 19-22 gallon range on 87 octane NO alcohol and a gallon lower with alcohol gas. You will get 35-36 on the highway with the 87 alcohol gas.
Old 02-24-2019, 04:39 PM   #3
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
Yeah, I thought the tank on my '93 was tiny at 12.8 gallons.
Being in NYC I would reckon there is a lot of idling going on. When possible drive at low traffic density times. Find opportunities to take alternative routes like expressways etc. Using navigation apps can reroute you around traffic snarls/congestion.
Is your vehicle running at full temperature? It has been years since the last time I got 20 mpg in an S-series.
My low fuel light does not work verified by running out of gas on the interstate. Last few fills were 11.xx gallons, never saw a low fuel light. I put fuel injector cleaner In every fill, no joy. I think the 3rd gens might be more reliable though.
1999 SL2 A4 -86k miles
Currently sipping Mobil 1 & LiquiMoly mos2
TCW3 dosed fuel
https://www.ls1.com/forums/f48/been-testing-oil-91206/
1993 SL2 SOLD @189k
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 02-25-2019, 12:48 AM   #4
Zeebins
Zeebins's Avatar
My low gas light has always come on with a little more than 2 gallons left in the tank. I've had it come on a few times but I've never put in more than 10.5. Definitely doesn't seem normal but I'd rather have it come on too early than too late.
97 SL2, auto, 116K miles
Powered by Plastic
Add to Zeebins's Reputation
Old 02-25-2019, 07:47 AM   #5
onlinebiker
You think 12 gallons is small??
My 61 HD Sportster only had a 1.9 gallon tank. Of course the bars weren't that far apart and the bike shook your kidneys so much you needed to stop and take a leak anyway...
So it all worked out...
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 02-25-2019, 02:53 PM   #6
GTS350
GTS350 is a jewel in the roughGTS350 is a jewel in the roughGTS350 is a jewel in the rough
1999 SC2
The fuel gauge in our cars are not very accurate, it just gives you a general idea of how much gas you have left.
1999 Saturn SC2 (automatic) 23,000 orig miles (9/10/16)
1996 BMW E36
1971 Holden Monaro GTS 350
1908 Buick Model 10
Its official Saturn Night has removed all doubt.
Add to GTS350's Reputation
Rate the quality of this post and help GTS350 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GTS350 is offline   Reply With Quote
Old 02-25-2019, 02:58 PM   #7
Theoretically, I should be getting 1 mpg more in my 3rd gen coupe than my 2nd gen sedan.
In reality, I drive the cars a little differently.
from this thread
http://www.saturnfans.com/forums/sho...d.php?t=154963
Old 02-25-2019, 07:04 PM   #8
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
For the 4 speed automatic, I would try Mobil 1 AFE in 0W-30...
https://mobiloil.com/en/motor-oils/m...-fuel-economy#
I am running a similar Mobil 1 ESP in 0W-30, and getting 40+ with a manual transmission...
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
fuel gauge accuracy???? bobhud S-Series General 14 03-30-2012 08:57 AM
My fuel filter arrived! Could it increase fuel economy and Power? Nick96'SL2 S-Series Tech 22 04-30-2011 11:28 PM
Best scan tool? Fuel economy gauge? youknowme General Saturn Discussion 0 08-23-2010 02:54 PM
Fuel Gauge/Range/BC Sirraven Astra General 7 06-05-2008 08:51 PM
2006 Fuel Gage Accuracy GearGuy Vue General 2 05-01-2006 07:06 PM
