Old 12-04-2018, 01:20 PM   #1
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
Default Name that Part!
So, what do we call that black plastic thing with two hoses that sits on top of the throttle body?
And for extra credit, can anyone tell me what size o-rings it uses to seal against the top of the TB???
My homeowner supply of plumbing o-rings way too thick in cross section, was hoping to find something close at NAPA, just no idea what I'm asking for.
Discovered the o-rings had expired while I was in process of cleaning up my throttle body today. Thinking that its no big deal, but figured GM engineers must have thought sealing it off was important enough to put an o-ring there in the first place.
Add to MiSaturn's Reputation
Rate the quality of this post and help MiSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MiSaturn is offline   Reply With Quote
Old 12-04-2018, 01:51 PM   #2
Default Re: Name that Part!
Not actually an o-ring, usually a special finned seal. That is the vacuum harness. A 1/16 or 1/32 diameter o-ring might work though.
Old 12-04-2018, 02:04 PM   #3
billr
McMaster may be most practical for those small O-rings, but an industrial bearing-supply place (in most big/medium cities) may also sell them retail.
Add to billr's Reputation
Old 12-04-2018, 02:08 PM   #4
A good fully stocked hardware store will have it.
Old 12-04-2018, 02:29 PM   #5
MiSaturn
2002 SL
1993 SL2
Much thanks!
Quick scan of the usual parts guys (NAPA, RockAuto, Oscaro) doesn't show a replacement unit, so refurbishment may be only solution.
Was thinking dab of RTV would seal it enough for time being, o-ring probably better solution long term. Or as long term as you can get for a 17 year old car with over 300,000 on the clock.
Old 12-04-2018, 07:13 PM   #6
The only source for a replacement vacuum harness is a junkyard. O-ring can be found a a decent big box lumber etc store or hardware store. Will not be at autoparts though.
Old 12-04-2018, 08:09 PM   #7
GTS350
1999 SC2
I call mine Steve.
1999 Saturn SC2 (automatic) 23,000 orig miles (9/10/16)
1996 BMW E36
1971 Holden Monaro GTS 350
1908 Buick Model 10
Its official Saturn Night has removed all doubt.
Add to GTS350's Reputation
Rate the quality of this post and help GTS350 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Need part number or name for this part - 2002 Saturn SL1 nxne75 S-Series General 2 10-14-2017 12:15 AM
Name this part and part number (2007 Ion-2) Swat ss Ion Tech 4 04-04-2014 11:15 PM
flex pipe exhaust part or part number? blaisedaddy Astra General 5 10-18-2012 07:14 AM
How to get the part #s for any part from the Trademotion SaturnParts website dbsanfte S-Series Tech 2 06-01-2012 04:56 PM
2007 Ion: Looking for a Part Number (and maybe the part) fosgate3 Ion Tech 2 06-05-2007 09:03 PM
