Old 12-08-2014, 10:56 PM   #1
Mike R
Mike R is on a distinguished road
2000 SL2
Default Sl clutch ?
I'm replacing the clutch on my 2001 SLI. Is the LUK Part # 04193 the right one to order or is there a different one? I got lucky and pulled the trans before the diff pin totally ejected. It made a small crack that my buddy says he can tig weld and I'm going to weld the pin to the case.
2001 SL1 5 speed
2000 SL2 Automatic
Add to Mike R's Reputation
Rate the quality of this post and help Mike R reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mike R is offline   Reply With Quote
Old 12-09-2014, 08:21 PM   #2
Mike R
2000 SL2
Default Re: Sl clutch ?
No one???
2001 SL1 5 speed
2000 SL2 Automatic
Old 12-13-2014, 08:43 AM   #3
BarnOwl
BarnOwl's Avatar
2000 SW2
I haven't but, plenty of people have TIG welded the diff pin. I'm assuming you know how to pull the tranny apart to get to it. Can't help you with the clutch model number. LUK is considered the best but, I've not had problems with other kits.
Add to BarnOwl's Reputation
Replaced clutch - Now clutch pedal too light and engagement not correct jk3006 S-Series Tech 23 07-21-2013 07:49 AM
94 clutch replacement--must engine be removed to access clutch? agingric S-Series Tech 3 11-11-2010 10:30 AM
2005 Vue Clutch Reservoir Dry = No Clutch. Slave issue??? polycar Vue Tech 1 09-03-2010 01:11 AM
Clutch fluid level, clutch pedal vibration, small leak Heartbeat - '95 SL2 Miscellaneous Tech 10 10-10-2003 06:35 PM
difference between clutch actuator and clutch master/slave cylinder geartooth94 S-Series Tech 3 06-10-2003 12:36 PM
