Old 09-10-2014, 09:25 AM   #1
stevelogan1967
stevelogan1967 is on a distinguished road
Question 2004 Vue front brakes locking up
Driving home last friday the car felt sluggish. When I pulled in the drive I could smell and awful burning and could feel heat from the front driver's side wheel. Passenger side also seemed hot, though not as much.
Took it into our local mechanic who tried, but could not duplicate it. Since I wasn't 100% sure both sides had failed to release his first thought was a left side caliper. Before they could put that on he said they did get it to lock up on both sides, but he felt that both calipers failing at the same time would be a long shot.
They replaced the master cylinder yesterday and test drove it for 15 miles, no problems. They dropped it off in our driveway and as the mechanic pulled it in to park he noticed it felt like they hadn't released yet again, so they took it back to the shop.
Not sure where this us. Assuming that the chances of both brake lines are as likely to fail at the same time as both calipers, what else is the possible common cause here? He was thinking maybe the booster pump, but from my reading that's not a likely point of failure. I also that a bad ABS sensor could do this, but wouldn't that apply a full braking instead of just not releasing intermittently?
Add to stevelogan1967's Reputation
Rate the quality of this post and help stevelogan1967 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stevelogan1967 is offline   Reply With Quote
Old 09-10-2014, 10:03 AM   #2
Chazberry
Chazberry's Avatar
1995 SW2
Default Re: 2004 Vue front brakes locking up
I think navygunner is still working on this unsolved mystery . . .
http://www.saturnfans.com/forums/sho...d.php?t=202631
Add to Chazberry's Reputation
Old 09-10-2014, 06:07 PM   #3
john95SW2
john95SW2 will become famous soon enough
john95SW2's Avatar
Had same problem...replaced both front calipers and hoses on both sides. All appeared to fail at about the same time. Mechanic said it took him a little time to figure it out as all had to be hot to stick. And it took differing amounts of heat to make each side stick which was what was fooling him at first.
Problem solved.
Add to john95SW2's Reputation
Rate the quality of this post and help john95SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
john95SW2 is offline   Reply With Quote
2004 Saturn Vue - Front drivers brakes smoking - HELP mikewelch5 Vue Tech 14 04-19-2017 10:16 AM
Need Help , brakes locking on lespaul1021 Vue Tech 6 09-06-2014 04:58 PM
07 Saturn VUE new brakes locking up senna95 Vue Tech 39 11-08-2013 01:10 PM
Brakes locking up ? saladdin S-Series Tech 7 05-26-2010 02:49 PM
Locking LF wheel with brakes tjd83 S-Series General 14 12-23-2006 01:15 AM
