#1 | ||||
![]() The past two Sunday mornings (after sitting overnight) when I start my Astra I hear a very brief clatter under the hood for a millisecond, like a diesel clatter or something. Then the engine quiets down. No problems running and I always let the car idle for a little bit before driving it. What could it be?
... marx404 Saturn lives on. 1994 SL2 2002 SC2 2007 ION.3 2008 Astra XE 2004 L300.1
#2 | |||||
![]() Join Date: Jan 2010
2008 Astra XE
2008 Astra XE
![]() Quote:
Ditto! It doesn't happen every day to me but once in a while I get the same thing! We have 2 2008 Astra XE's in the household. I'll have to drive DH's to see if his does the same thing...
#3 | ||||
![]() I had my car in the shop today to have my alternator and accessory belt replaced so while it was in, I had my tech check it out and he was puzzled. He checked for any TSB's on the noise but there were none. The shop manager suggested that this sound is common in mechanical lifters sometimes. (true?) My tech said he will try to find out more about it.
#4 | |||||
![]() Quote:
However, there are other hydraulic components in our engines that require oil pressure to prime. I'm not sure if your timing belt tensioners are hydraulic or not, but the VVT oil control valves are electronically operated. ... "That's a Hruck Bugbear, manufactured in Eastern Europe in the eighties and imported to the States. People mock it as a poor man's Yugo. I consider it the pinnacle of Cold War Balkan engineering."
#5 | ||||
![]() I too am apart of this. Happens more frequently in colder temps. I thought it was the exhaust shaking on initial start.
... 15 Mazda 3 s Grand Touring 5-Door Manual 14 BMW 435i M Sport 6speed 08 XR 5 speed - Blue with 3M film - SOLD! 03 Acura CLS 6speed - Silver with 3M film - SOLD!
#6 | ||||
![]() ![]() Join Date: Jul 2003
2008 Astra XR
![]() i too would say the clatter is from the solid lifters, at startup.
solid lifters are never as quiet as hydraulic lifters, at any time. ... Gerry 72 Buick GS red 2008 Astra XR black 3dr 99 SL1
#7 | ||||
![]() Join Date: May 2009
2007 ION-3 Sedan
2008 Astra XR
![]() The longer mine sat or the colder it got the more I would hear the clatter, sounded like lifters to me
#8 | |||||
![]() Quote:
#9 | ||||
![]() so I wonder why only once in a blue moon it happens?
#10 | ||||
![]() Join Date: May 2010
![]() My car makes a funny noise too. I thought it was a clatter noise because it kinda sounds like loose metal somewhere. It never happens in cold weather but in hot weather it happens when i start the car and when I hit the gas or my car shifts. But it is only for a quick second. I thought it was my exhaust until I had a friend sit on the hood of my car with the hood open and accelerate. He immediately said it was a belt. So our conclusion was that the hot weather slightly stretched the belt out. After about 5 minutes of driving it goes away after the engine gets the air flow. The more I listen to it i can tell its a belt. If I slowly press the gas I can make the noise drag out for about 4-8 seconds until i hit about 15 MPH as far as cold weather I have had my car in temperatures ranging from 10 degrees to 110 degrees. And I have only experienced this weird noise on a daily basis on start up in hot weather around 70-110 degrees as it reads on my info center.
#11 | ||||
![]() Join Date: Sep 2005
2008 Astra XR
2006 ION-3 Quad Coupe
![]() I too have this same clatter. I experience it on a daily basis. The only time I won't hear it is if I have the air conditioning off at the time of start up.
... 1999 SL2 / 2004 ION-2 Quad Coupe / 2006 Relay / 2006 ION-3 Quad Coupe / 2008 Astra XR
#12 | |||||
![]() Join Date: Dec 2009
2008 Astra XR
![]() Quote:
![]() It's like "YOU ARE NOW MANUALLY BREATHING"
#13 | ||||
![]() Join Date: Aug 2009
2009 Astra XE
![]() X3 on this!
#14 | ||||
![]() Ok, I have found that if I turn the ignition key to run position and let the "jet whining" sound subside (I assume that is some sort of fuel or oil pump???) before starting the car, I no longer have the clattering noise.
Try it and see for yourself. ... marx404 Saturn lives on. 1994 SL2 2002 SC2 2007 ION.3 2008 Astra XE 2004 L300.1
#15 | ||||
![]() Might be the fuel injectors.
#16 | |||||
![]() Join Date: Mar 2010
2008 Astra XR
1993 SW2
![]() Quote:
Has anyone tried tightening the belt? New here, my first post. What do we do for service manual? I see Haynes UK site lists an Open/Vauxhall Astra manual. Thanks all! ![]() ... Gary F. 2008 Saturn Astra 5-Door XR, Arctic White, Auto, Sunroof, Sport Handling 2001 Land Rover Discovery II 1993 Saturn SW2 (gave to son at 300K mi)
#17 | ||||
![]() Join Date: Jul 2008
![]() Check the thread about the alternator pully. Mine started off like everyone elses. it first started in the cold then in summertime. Trust me it get s worse.
My does a rattling/ hissing sound now everytime I start it. It eventually after quite awhile goes away. It sounds unhealthy for the car. Push for it to get fixed. I am still having problems cuz the dealership does not want to acknowledge that there is anything wrong. Try taking it to a mechanic shop that does warranty work. See what they say!
#18 | ||||
![]() I've always suspected that the startup clatter is related to the cam advance. Since we have solid lifters (instead of hydraulic), you don't have to wait for them to become pressurized, so if it was solely the lifters, you'd hear it all of the time.
On the other hand, the camshafts do have variable timing and they don't move instantaneously. I suspect that the momentary clatter may happen until the cams have moved to their appropriate location for the given engine RPMs and ignition timing.
Clatter Sound on Acceleration | jasenpeters | S-Series Tech | 3 | 11-28-2008 09:49 PM |
Clatter sound under hood | ewagtwo | Astra Tech | 3 | 09-18-2008 07:35 AM |
Valve Clatter??? | Slick | Vue General | 37 | 11-17-2004 01:05 AM |
2000 SW2 Valvetrain Clatter | SL2abuser | S-Series Tech | 5 | 09-25-2003 09:44 AM |
Clatter noise from right front end | joe | Miscellaneous Tech | 3 | 06-05-2002 06:32 PM |
