Old 04-18-2010, 02:47 PM   #1
newbievueowner
newbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the rough
2006 VUE Red Line
Default Rear axle bearing play in AWD diff?
Anyone with a 2002-2007 Vue ever check the play in the axle where it comes out of the rear differential while under their vehicle? I was in there the other day doing rear brakes and moved the shaft up and down, seems to be a lot of play/movement. I'm wondering if this is normal? Are others like this or is it supposed to be tight? I would have thought it should have been tight but.....??? Seems a little stange to me.
If some guys could check theirs I would appreciate it. I may have to go to a dealer late one night and look under the Equinox/Torrent to see if they are the same or not.
Add to newbievueowner's Reputation
Rate the quality of this post and help newbievueowner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
newbievueowner is offline   Reply With Quote
Old 04-18-2010, 04:22 PM   #2
Someclown
Someclown is on a distinguished road
Someclown's Avatar
2002 VUE 3.0L
Default Re: Rear axle bearing play in AWD diff?
I also noticed a lot of up & down, front to back , and in and out slack were the axle shafts exit the differential, I'm not sure if it's normal, I noticed it a couple years ago when I changed my RDM fluid and haven't done anything with it and it seems ok.I removed the props and checked it again last week and doesn't seem to be getting worse or leaking fluid(besides a little seal sweating). I think my fronts have some slack also.
Add to Someclown's Reputation
Rate the quality of this post and help Someclown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Someclown is offline   Reply With Quote
Old 04-20-2010, 05:01 PM   #3
newbievueowner
2006 VUE Red Line
Maybe it's GM 'normal' then........ don't know.
Just seems a little strange to me. The front axle shafts seem tight.
I'm going to check out a few Equinox/Torrents once I lose this damn cold.
2002 L300 Rear Axle Bearing and Hub Assembly Removal admiralbrown L-Series Tech 4 07-02-2012 09:06 AM
wheel bearing or axle? or neither? Squishyzach S-Series Tech 0 08-28-2009 12:54 PM
How much play allowed in CV axle? SL2Many S-Series Tech 0 07-09-2008 01:26 PM
Axle? Bearing? Red Sc2 S-Series Tech 8 03-23-2008 10:58 AM
Rear bearing/wheel play? ToddL S-Series Tech 3 03-12-2002 02:43 PM
