Old 08-04-2018, 01:54 PM   #1
CruzzieQ
CruzzieQ is on a distinguished road
Question 2008 Astra H 1.8 l engine operating temp for fan operation?
HI, Does anyone know the radiator fan operating temperature for a 2008 Saturn Astra H 1.8 L??
My fan does not come on. The temp reached yesterday was 96 degrees and no fan came on no 1400 codes came up as I keep checking.
THANKS
Add to CruzzieQ's Reputation
Rate the quality of this post and help CruzzieQ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CruzzieQ is offline   Reply With Quote
Old 08-05-2018, 02:15 PM   #2
Default Re: 2008 Astra H 1.8 l engine operating temp for fan operation?
What does your cooling temperature show for a normal engine? 96F ambient temps is not very hot. If you're in local stop and go traffic, the cooling fan may cycle as coolant temps reach a certain value like 220F. There are several ways to test fan operation starting with checking the fuse for three cooling fan. If ac works, turning on ac should turn on cooling fan - two radiators warm up and warm/hot condenser coil airflow going into the radiator won't help with cooling so the fan is turned on. Check too see fan operation with ac on. Another way to check fan operation is to power the fan directly from the battery.
Old 08-17-2018, 10:35 AM   #3
CruzzieQ
Question Re: 2008 Astra H 1.8 l temp & O2 sensor
Thanks Fdryer, I do not have air condition, but i shall check the fuses
also wound this be the O2 SENSOR I need as there are 2?
Oxygen Lambda Sensor O2 Sensor Probe For Vauxhall Opel Astra H 04-13 855361 &&
My error code is:
P0141
MIL Controll: Yes
Current: NO
Historic: Yes
Description: Heated oxygen sensor (HO2S) 2, bank 1 heater control circuit malfunction
General, Short to Battery
Falaut Codes Readed By OPL DTC Reader 2.02
Old 08-17-2018, 10:45 AM   #4
Looking up P0141shows the downstream (after the catcon) O2 sensor heater is faulty. Either ther heater has an intermittent connection or it failed. You can try disconnecting and reconnecting it several times and see if the check engine light goes away on its own before replacing it. Car mileage?
Old 08-17-2018, 05:32 PM   #5
CruzzieQ
Thanks .. 125,000 miles I . will get my mechanic to try that.
Thanks again.
Old 08-18-2018, 09:25 PM   #6
kikastra
kikastra has a spectacular aura aboutkikastra has a spectacular aura aboutkikastra has a spectacular aura about
kikastra's Avatar
2009 Astra XR
If you want to go by the computer, which can be seen in the "secret" BC menu, my fan doesn't come on until 99C. HTH
2009 Saturn Astra XR3 5-Speed - 72,000KM
Add to kikastra's Reputation
Rate the quality of this post and help kikastra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kikastra is offline   Reply With Quote
Old 08-22-2018, 04:37 PM   #7
CruzzieQ
[B][/B]
THANKS,
KikAstra
engine stopping after reaching operating temp taxladyone L-Series Tech 5 04-30-2013 01:51 PM
2000 LS2 Thermostat Issue What temp should coolant be at normal operating temp Bob Panczak L-Series Tech 3 12-14-2010 12:49 AM
Question on operation temp. sl2 Kaveman S-Series General 22 02-27-2009 10:38 AM
Operating temp? papayamon2 S-Series Tech 10 09-16-2008 01:45 PM
SES Light turns off once engine is at operating temp...? bskicrash1 S-Series General 6 03-23-2006 09:35 AM
