Old 11-14-2017, 01:29 PM   #21
Default Re: Used transmission installed, but shift pattern is wrong.
OK you will have to check the physical shift cable alignment-adjustment and then the electric range switch adjustment.
Links to the FSM procedure.
Mechanical shift cable is done first. http://www.saturnfans.com/photos/sho...hp?photo=52339 All you have to do is lift the tab and then get everything set into Drive from both directions.
Range switch is adjusted second. http://www.saturnfans.com/photos/sho...hp?photo=49744 Must follow directions exactly.
subtle "rod knock" like sound, but the pattern is wrong cityhawk S-Series Tech 20 08-09-2016 08:31 PM
Is there a pattern to tighten the transmission panel? ( Side ) CaptainMouse64 S-Series Tech 1 12-17-2012 02:58 PM
New Pioneer radio installed, now a bunch of stuff is wrong! greekfreak Vue Tech 2 11-23-2009 04:36 PM
Shift Pattern on and XR gmsuv 2008 Vue 9 06-26-2008 05:44 AM
Has anyone installed aftermarket shift knob? johnsocal Ion General 9 12-18-2003 08:42 AM
