Old 01-28-2013, 08:20 PM   #1
gbc_15
gbc_15 is on a distinguished road
Default new ignition cylinder issues 2001 S series
I will try and make this as brief and clear as possible. I had the ignition cylinder go bad on the 2001 Saturn SL2 and was forced to drill and pound it out with a hammer. I was able to get the old one out and partially install a new one. When I say partially install the new one It cranks the engine and the engine runs but does not turn smooth. The bigger problem is when you turn the key to the off position if you turn it to far it locks into place and will not allow me to turn it back to re start the engine. In all the research I was doing on the initial problem I remember reading somewhere that you can damage some part when having to forcefully remove the old cylinder, can anybody give me a part number or name on this piece that may have been damaged in the removal of the old cylinder? Is it an cheap and/or easy fix? Thanks for any help you can offer.
Add to gbc_15's Reputation
Rate the quality of this post and help gbc_15 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gbc_15 is offline   Reply With Quote
Old 01-28-2013, 11:25 PM   #2
Default Re: new ignition cylinder issues 2001 S series
You will need to replace the ignition cylinder housing.
Add to ssicarman's Reputation
Ignition Lock Cylinder or Ignition Switch? jzambon S-Series General 12 03-26-2017 04:30 PM
2001 Saturn SL2 new ignition cylinder Help gbc_15 S-Series Tech 1 01-27-2013 05:01 PM
How to remove ignition key cylinder with broken key in the cylinder, L-series? dejavu48 L-Series Tech 0 11-15-2008 12:46 PM
2001 S-Series Clutch Issues Asinity S-Series Tech 7 02-05-2006 05:36 AM
Ignition key cylinder removal on L-series axls L-Series Tech 6 10-02-2005 06:48 PM
