Old 12-16-2011, 07:45 AM   #1
Tommie
Tommie is a jewel in the roughTommie is a jewel in the roughTommie is a jewel in the rough
1996 SL1
2002 SL1
Default A dream: An updated and refined Saturn SL
The perfect SL would have the following changed:
Higher grade steel subframe or improved rust protection.
A SOHC engine with a revised head (no cracking)or a DOHC engine with SOHC gear ratios for fuel economy.
A diff pin revision so I can spin the tires without worrying about destruction.
Top mounted battery terminals.
More leg room. My left foot has no space, lol.
Better seat fabric. The drivers left side lumbar always wears and tears from in and outs...
Feel free to add to the dream...
Tommie is offline   Reply With Quote
Old 12-16-2011, 07:52 AM   #2
davorocks
davorocks is on a distinguished road
1999 SC1
1999 SW2
Default Re: A dream: An updated and refined Saturn SL
I love my 3 door. The only thing I would change is ythe third door on the opposite side. Maybe disc brakes in the rear.
99 SC1 3 door 5 speed-98 C1500 350 not slow-97 K1500 305 slow-96 Camaro 3800 SII-95 Firebird Formula bad mpg
davorocks is offline   Reply With Quote
Old 12-16-2011, 08:21 AM   #3
PlasticCarsRock
PlasticCarsRock's Avatar
That's easy enough... just grab a set from a junked s-series that has them.
Old 12-16-2011, 08:37 AM   #4
Originally Posted by Tommie View Post
1) a DOHC engine with SOHC gear ratios for fuel economy.
2)A diff pin revision so I can spin the tires without worrying about destruction.
3)Top mounted battery terminals.
1) Fairly common easy to do swap. Went from 33mpg highway @ 70 to 37mpg @ 70.
2) You just don't have enough spare transmission's. I have 3 (spares) & spin the tires all the time. It doesn't break, even redlining 1st & 2nd and having 3rd start gaining full traction around 30mph (did that once) or weekly drifting on back roads during the summer.
3) Again, fairly easy swap. 2 4g cables & maybe an hour to install...
Old 12-16-2011, 10:07 AM   #5
PlasticCarsRock
Even with spares, you have the problem of getting stranded somewhere if the pin fails (even if you drive more reasonably when away from home, the pin doesn't necessarily come out when you spin the tires--spinning the tires shears off the small retaining pin, but the large pin may not actually explode through the side of the transmission for miles).
However, welding the pin in place does permanently solve the problem (assuming the welder knows what they're doing). There's also the option of an MFactory limited slip differential (manual transmission only) which doesn't even have the pin.
Old 12-16-2011, 10:14 AM   #6
.... would not just be a sedan. The competitive edge of the original S-Series was the availability of the wagon. It sold poorly at the time, but it's actually become more sought-after since it ceased production. If the S-Series were revived today, a wagon/crossover would be a must.
Better yet, a sixth forward gear, at about the MP2 fifth ratio. This gives you both the bottom-end pull and the top-end economy.
To add:
* More programmable / customize-able PCM
* NO &#$@*^ BCM
* Folding mirrors
* Five-lug wheels
* Separate lock and latch on the tailgate (wagon)
* Real towing capacity
Old 12-16-2011, 10:35 AM   #7
spacemanspif
spacemanspif will become famous soon enough
spacemanspif's Avatar
+1 on the extra gear.
Or they could make a new engine and had better low end torque and keep 5 gears but toss 1st. 6 gears in our cars would be A LOT of shifting...as it is now, my shift pattern usually skips 3rd gear unless I wind out 1st in which case I skip 2nd and 4th.
Definitely need a spot to rest our left foot, I'm not asking for that much more leg room, just a dedicated spot.
New engine needs a remote oil filter location because stock one is in a stupid spot that ends up getting oil everywhere but the drain pan.
Keep it light. A new car will need to comply to a lot more crash standards and need more air bags, electronics etc...another reason why a new, more powerful engine would be nice...so weight savings should come from lightweight materials like aluminum and carbon fiber.
Better seats!!
-Mike
1995 SL2 5spd - Stock/MP2 trans swap - 258,XXX miles - 38mpg @ 65mph
1987 Monte Carlo SS - 5.3/4L80E swap - 13.92@103mph - 19mpg @65mph - needs POSI
spacemanspif is offline   Reply With Quote
Old 12-16-2011, 03:25 PM   #8
manualman
manualman is on a distinguished road
1995 SL
How about this
http://www.autoholiks.com/wp-content...ee-Quarter.jpg
with plastic doors and quarter panels and a rather lower MSRP. And do it fast so I can get a good deal on a used one when my S cars burn out please.
manualman is offline   Reply With Quote
Old 12-16-2011, 07:42 PM   #9
bennett9000
bennett9000 has a spectacular aura aboutbennett9000 has a spectacular aura about
bennett9000's Avatar
I did a rear disc swap on my 99 SW2; the complete kit cost me about $65 at the junkyard. Great, easy mod.
-Andy
01 SL1 (2011-2014) 99 SW2 (2002-2009) 95 SL2 (1997-2002)
00 ROUSH Cougar V6 03 SVT Focus #2370 08 Mustang Bullitt #5389 2013 Fiat 500 Abarth
bennett9000 is offline   Reply With Quote
Old 12-17-2011, 04:30 PM   #10
siris
siris is on a distinguished road
Better suspension geometry.
and
Ecotec FTW!
siris is offline   Reply With Quote
Old 12-17-2011, 08:20 PM   #11
cfg83
cfg83 is on a distinguished road
cfg83's Avatar
Tommie -
I like all the things you are talking about. Here are some more :
- Aero-kit similar to the Chevy Cruise/Malibu Eco so that we can own the MPG high-ground.
- Oil drain holes in the pistons.
- Manual *everything* option, even if it costs more. I don't want power windows.
- Aggressive DFCO (Deceleration Fuel Cut-Off), aka down to just above the RPM instead of the 2500 RPM I am seeing now.
- Maintain the proportion of scale of the S-Series (I prefer 2nd-gen). I don't like the "tall" proportion of today's compact for the sake of increased interior volume.
Do we have anyone with skillzz in PhotoShop for a design update?
CarloSW2
cfg83 is offline   Reply With Quote
Old 12-18-2011, 11:40 AM   #12
linuxdude
linuxdude is on a distinguished road
Default Ah, I've thought about this too :)
I reckon it's like fantasy football. My list:
+ better oil filter location, ideally on upper engine, hanging down so gravity works to prevent spills
+ diff pin welded at the factory
+ license the stainless steel shifter bushing from that guy who sells them on eBay
+ drain back holes in pistons!
+ heavier gauge wiring
+ 6th gear, for highway cruising
...and definitely the option for manual EVERYTHING. No gratuitous electronic bling and points of failure.
linuxdude is offline   Reply With Quote
Saturn Dream David 93 SL2m General Saturn Discussion 2 03-26-2010 09:46 AM
Some Saturn Dream Cars.... 100KSW2 General Saturn Discussion 13 06-30-2007 03:17 PM
Finally Got My Dream Saturn!!! andy_95sl2 S-Series General 19 02-26-2006 07:28 PM
Re-refined oil revue Vue General 10 07-14-2004 09:00 AM
Saturn Curve Supercharged Coupe Has Refined Flair eRic 02sc2 General Saturn Discussion 5 01-04-2004 08:22 PM
