Old 06-10-2012, 10:25 PM   #1
bennett9000
bennett9000 has a spectacular aura aboutbennett9000 has a spectacular aura about
bennett9000's Avatar
Default 01 SL1 - no cluster backlight
Cant figure this one out yet, and all the search results are different than what I'm seeing.
Previous owner had some sort of device crammed under the dash top; probably a remote start sensor or a sensor for a head unit remote. Anyway, it was unhooked and just sitting up under there. I removed it, and put the dashboard all back together, and now there are no cluster lights. Or more specifically, no BACKLIGHT.
All of the indicators and warning lights work as normal. the HVAC backlight is working correctly. The stereo backlight is working correctly. But the gauge dials are dark, and the digital odometer numbers are also dark. I've checked the PARK fuse, and it's good. I havent pulled every single fuse, but the ones that point to the cluster are good. No other lights or systems are out, that I can tell. The only casualty is the cluster backlight.
Any thoughts where I should go next?
-Andy
01 SL1 (2011-2014) 99 SW2 (2002-2009) 95 SL2 (1997-2002)
00 ROUSH Cougar V6 03 SVT Focus #2370 08 Mustang Bullitt #5389 2013 Fiat 500 Abarth
bennett9000 is offline   Reply With Quote
Old 06-10-2012, 11:45 PM   #2
simkid5614
simkid5614 is on a distinguished road
simkid5614's Avatar
Default Re: 01 SL1 - no cluster backlight
Okay, Just as a simple test, Remove your Dimmer/Fog/Trac switch then turn on your parking lamps after about 10 seconds, Your gauges should default to maximum brightness. Some safety feature programmed in.
2002 SL2 115k "Whisper" No leaks!! :) 115 and going strong..
simkid5614 is offline   Reply With Quote
Old 06-11-2012, 11:11 AM   #3
bennett9000
I will give that a shot. Thanks.
-Andy
Old 06-11-2012, 11:29 AM   #4
Unless 3rd gen is different, I don't think our clusters are backlit (at lease teh 1st and 2nd ones aren't).
There are two overhead "theatre" lamps that light up the face of the gauges from above. The bulb for the odoometer fails faster than the other bulbs because it is on all the time when running.
edit: this thread shows the 3rd gen back
http://saturnfans3.saturnfans.com/~s....php?p=1587755 and mentions theater bulbs, so I'm guessing 3rd gen is not back lit
more info
http://www.saturnfans.com/forums/sho...d.php?t=152386
Old 06-11-2012, 11:38 AM   #5
bennett9000
Right, I guess "backlight" was a misleading term.
The bottom line is, I can't see ANYTHING on the cluster at night. Total darkness. There are no theatre lights and no odometer lights (you can still see the odometer numbers in sunlight, so the LCDs are still operating as normal, but the illumination is gone.
-Andy
Old 06-11-2012, 11:44 AM   #6
I've read a few people say that they somehow broke the filaments in the bulbs from removing the cluster, and had to put new bulbs in. Odd that it was just those 3 bulbs but strainger things have happened.
You could swap in a known good bulb into the odometer spot and see if it comes back - not sure what size bulb the 3rd gen uses for theater lights
Old 06-11-2012, 11:56 AM   #7
bennett9000
Putting the shroud back on does involve a nice rap with the flat of your hand, to seat it correctly. It's entirely possible that caused bulb failure.
I'll grab a handful of cluster bulbs next time I'm at the Yard; there is one distinctly missing from the HVAC display anyway.
Thanks for the tips; keep 'em coming!
-Andy
Old 06-12-2012, 03:19 AM   #8
simkid5614
simkid5614's Avatar
Crap on that. Just grab for the cluster. You can't do anything about the HVAC in the gen 3 cars. They are hardwired. Unless you can solder. Its a #74 baseless bulb or a smd LED. I think a 3-5 mm will suffice.
Old 06-12-2012, 07:28 AM   #9
bennett9000
Pulled the dimmer switch and let it sit with the parking lights on for a while last night, no change. So next step, unless I get other suggestions, will be dropping in some new bulbs.
Thanks so far, everyone.
-Andy
Old 06-17-2012, 06:29 PM   #10
bennett9000
Problem solved.
I grabbed a handful of cluster bulbs at the Yard today. Replaced the two "theater light" bulbs and the odometer bulb, and everything works as normal.
Strange they all three decided to fail at the same time, but that was it.
Thanks for the help and suggestions, everyone.
-Andy
Old 06-17-2012, 07:29 PM   #11
simkid5614
simkid5614's Avatar
Yeah the dimmer trick works for the Radio, I/p Cluster backlight, and the HVAC lighting
3rd gen radio LCD backlight quantumech S-Series Tech 22 10-06-2016 12:16 PM
Gauge Cluster backlight. adventureoflink S-Series Tech 7 08-10-2009 02:26 AM
Odometer Backlight UsNsUbSoNaR S-Series Tech 7 06-10-2008 07:12 AM
'98 SL2 Odometer Backlight moonak98SL2 S-Series General 6 07-14-2005 08:19 PM
SL2 Odometer backlight JayNYC S-Series General 2 04-02-2005 07:48 PM
