View Poll Results: What grade/viscosity do you use in your engine?
0w30 1 1.35%
5w30 53 71.62%
5w40 4 5.41%
5w50 0 0%
10w30 16 21.62%
10w40 0 0%
15w40 0 0%
15w50 0 0%
20w50 0 0%
sae30 0 0%
sae40 0 0%
sae50 0 0%
Voters: 74. You may not vote on this poll
Old 12-07-2006, 03:27 PM   #1
92sl jeff
92sl jeff is on a distinguished road
92sl jeff's Avatar
1992 SL
Default Oil... Oil... and more Oil...
I use 5w30 for performance and fuel economy (like owner manual says).
Add to 92sl jeff's Reputation
Rate the quality of this post and help 92sl jeff reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92sl jeff is offline   Reply With Quote
Old 12-07-2006, 03:28 PM   #2
Kevin94SL
Kevin94SL is on a distinguished road
Kevin94SL's Avatar
2006 ION-3 Sedan
Default Re: Oil... Oil... and more Oil...
80w90 extreme service gear oil.
Actually, 10w30 summer, 5w30 winter
Kevin
Add to Kevin94SL's Reputation
Rate the quality of this post and help Kevin94SL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kevin94SL is offline   Reply With Quote
Old 12-07-2006, 04:24 PM   #3
K-1
K-1 is on a distinguished road
K-1's Avatar
2008 Astra XR
When I had my SC2, it was Mobil 1 synthetic 10w30 year-round.
Toyota: Moving Forward... off a cliff at a high rate of speed.
Add to K-1's Reputation
Rate the quality of this post and help K-1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
K-1 is offline   Reply With Quote
Old 12-08-2006, 12:48 AM   #4
98greenSC2
98greenSC2 is on a distinguished road
98greenSC2's Avatar
Mobil 1 synthetic 5w-30. Changed every 5,000 miles.
http://members.cardomain.com/stdmtn11
15.59 @ 87.1 quarter mile
1998 Saturn SC2 *sold* What have I done!?
Add to 98greenSC2's Reputation
Rate the quality of this post and help 98greenSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
98greenSC2 is offline   Reply With Quote
Old 12-09-2006, 10:43 AM   #5
bad mikey
bad mikey is on a distinguished road
Valvoline Synpower 5w-30. If I switch to Mobil1 it is because it is easier to find but as I use Blackstone Labs for oil analysis Valvoline has performed to perfection. I use the Penzoil synthetic in our Grand Marquis with no complaints also 5w-30.
Add to bad mikey's Reputation
Rate the quality of this post and help bad mikey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bad mikey is offline   Reply With Quote
Old 12-09-2006, 11:03 AM   #6
bgates2b
bgates2b is on a distinguished road
bgates2b's Avatar
2007 AURA XR
Mobil 1 5w-30 and K&N HP 1002 oil filter, every 2500-3000 miles.
"Congratulations on your brand new 2007 Acura" - Tenisha, the On*Star rep that handled my call during the Aura's delivery
Add to bgates2b's Reputation
Rate the quality of this post and help bgates2b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bgates2b is offline   Reply With Quote
Old 12-09-2006, 11:59 AM   #7
S3aturnR
S3aturnR's Avatar
1999 SL1
i've used quaker state 5w-30 in my racecar since it was new. every time except for once when i couldn't find it and used valvoline.
prolly not the best oil on the market, but i feel the big difference is that you ARE changing/checking your oil regularly.
s3aturnr
Add to S3aturnR's Reputation
Old 12-09-2006, 01:17 PM   #8
97coupe
97coupe is on a distinguished road
WalMart high mileage 10w30 every 3K miles or less. 5w30 has too much VI in it for me if it is conventional oil. You would think that as many ring soaks you read about here that they would finailly figure out that extended changes with 5w30 is gumming up rings as VI cooks out of oil in them and is mistaken for carbon. SYN oil would not be as subject to this problem nor would 10w30 conventionall oil be. I have never had stuck rings in nearly forty years of driving and never used 10w40 or 5w30 either as they were knows for this. GM had major problem with stuck rings in 80's from 10W40 and it is the last oil "grade" you should use in a modern engine.
Add to 97coupe's Reputation
Rate the quality of this post and help 97coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97coupe is offline   Reply With Quote
Old 12-14-2006, 02:16 PM   #9
92sl jeff
92sl jeff's Avatar
1992 SL
thanks everyone!
Anymore voters?
Jeff
Saturn SL 1992 1.9l sohc ST
Sunfire SE 1999 2.4l AT4
Old 12-14-2006, 04:02 PM   #10
eljefino
eljefino's Avatar
1995 SW1
anywhere from 0w30 if I can find it to 15w40 if it's summer and I've got a burner.
This poll assumes one has a consistent climate and only one car in their fleet. Also you didn't include 0w20 or 5w20, not that either is recommended but the poll is incomplete.
Add to eljefino's Reputation
Old 12-14-2006, 05:48 PM   #11
Nor does it distinguish dino from synth.
Add to madpogue's Reputation
Old 12-15-2006, 01:14 AM   #12
eRic 02sc2
eRic 02sc2's Avatar
5w-30 changed when the "change oil soon" light comes on.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 12-17-2006, 02:31 AM   #13
lego84
lego84 is on a distinguished road
1994 SL1
5W30 dino, every 3000.
Add to lego84's Reputation
Rate the quality of this post and help lego84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lego84 is offline   Reply With Quote
Old 12-17-2006, 02:52 AM   #14
Titanium48
Titanium48 is on a distinguished road
5w30 in winter (November-March) and 10w30 in summer (April-October). Both Castrol conventional oil. I change oil grades at about the same time I install or remove my winter tires.
Add to Titanium48's Reputation
Rate the quality of this post and help Titanium48 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Titanium48 is offline   Reply With Quote
Old 12-17-2006, 10:50 AM   #15
94sc295sl2
94sc295sl2 is on a distinguished road
94sc295sl2's Avatar
Location: spring hill tennessee (the motherland) sterling heights michigan native
1994 SL1
canola oil in the winter and peanut oil in the summer. both from walmart....
seriously i use what we have on tap at the dealer i work at.
jim reed chevy/isuzu/subaru/hyundai
remember that cars are built by robots built by human hands and are prone to failure.
Add to 94sc295sl2's Reputation
Rate the quality of this post and help 94sc295sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
94sc295sl2 is offline   Reply With Quote
Old 12-17-2006, 09:23 PM   #16
SaturnManiac
SaturnManiac's Avatar
I use Valvoline High Mileage oil. 10W-30 in the summer, 5W-30 in the winter. I'm not on the whole synthetic hype.....maybe for a newer car, but I don't want to change my over 100,000 mile car to synthetic when it's used to getting dyno......every decent mechanic has told me there is no use in switching to synthetic in a non-race car or a car that has over 75,000....and I'm old school like that. Besides I switched my 96 SL2 over to synthetic and it did nothing but burn more oil.....and my 2000 SL2 doesn't burn oil, and I'd like to try to keep it that way.
Add to SaturnManiac's Reputation
Rate the quality of this post and help SaturnManiac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-17-2006, 10:28 PM   #17
dcp
dcp is on a distinguished road
dcp's Avatar
Dino oil 5w-30 Valvoline---GOOD STUFF
Add to dcp's Reputation
Rate the quality of this post and help dcp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcp is offline   Reply With Quote
Old 12-18-2006, 12:02 AM   #18
SaturnSl1owner
SaturnSl1owner is on a distinguished road
2002 SL1
I have a few questions about this high mileage oil?
What is different compared to say castrol gtx dino oil?
When should one starting to use such oil?
I am curious, my current car, a 01 Kia Rio (I know, I know, cheapo) has currently 250K and I've always used castrol gtx, started with 10w30 and one really cold winter I had trouble starting the car to the point I had to get a boost because I drained the battery trying to start it, and after that always used and still use 5w30 and there are absolutly no leaks.
Now that I have the 02 sl1 with 76k I was planning on continuing the tradition unless I am convinced that the high mileage is actually better?
Add to SaturnSl1owner's Reputation
Rate the quality of this post and help SaturnSl1owner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnSl1owner is offline   Reply With Quote
Oil change, Tools Required, Oil Life Monitor Reset Instructions emg77 Astra Tech 57 04-24-2015 02:43 PM
Is there any reason I should get oil changes if im burning oil and put fresh oil in. AtlanticBeach S-Series Tech 12 08-01-2009 07:52 AM
oil change, oil and oil filter preferences? krismanme S-Series Tech 15 08-08-2008 10:48 AM
Oil Leak? Not oil pan, not valve cover, not front oil seal. klcl S-Series Tech 14 10-05-2007 12:25 PM
Burning a Quart of Oil Per 1500 miles: Oil Pan gasket or Rings? TIMSPEED Miscellaneous Tech 4 07-24-2004 09:06 PM
