Old 12-06-2006, 02:01 AM   #1
strongboy2005
strongboy2005 is on a distinguished road
Default What RPM do you shift?
You're at the track in your 1994 saturn sc2. Your only mod is a cold air intake. What RPM do you shift at in each gear?
Add to strongboy2005's Reputation
Rate the quality of this post and help strongboy2005 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
strongboy2005 is offline   Reply With Quote
Old 12-06-2006, 02:05 AM   #2
SaturnManiac
SaturnManiac's Avatar
Default Re: What RPM do you shift?
Drive hard. Shift right before you absolutely need to. Just try not to redline alot. You should know when to shift by the sound of the car, not the RPM's.
Add to SaturnManiac's Reputation
Rate the quality of this post and help SaturnManiac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 12-06-2006, 02:44 AM   #3
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
From what others have said, 6500 sounds like the magic number for upshifting, puts you right in the peak hp. Down shifting is a little less, because then it puts you at max torque.
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 12-06-2006, 09:52 AM   #4
S3aturnR
S3aturnR's Avatar
1999 SL1
well, you gotta get as close to the rev-limiter as possible without touching it. if you hit it, it will slow you down, but if you shift too far before it, you'll be missing a few revs. i usually go right to the tip of the redline and shift in competition. maintaining your vehicle takes on a new and special meaning when you do this often...
s3aturnr
Add to S3aturnR's Reputation
Old 12-06-2006, 10:51 AM   #5
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
The rev limiter is set a 6750, but if you shift there, you already passed peak HP. Peak is right around 65-6600.
You can tell Linux is made by geeks.
Add to RangerRover's Reputation
Rate the quality of this post and help RangerRover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RangerRover is offline   Reply With Quote
Old 12-06-2006, 07:13 PM   #6
colonelhogan44
colonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nicecolonelhogan44 is just really nice
colonelhogan44's Avatar
Isn't peak more in the 5500 range?
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 12-06-2006, 09:07 PM   #7
eRic 02sc2
eRic 02sc2's Avatar
Checkered Flag Re: What RPM do you shift?
up-shift at 6500 RPM. make sure you shift before hitting the 6750 -/+ 150 RPM fuel shut off.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 12-06-2006, 10:13 PM   #8
nad
nad is on a distinguished road
1993 SC2
The valves in our cars will fall off the map right after 6500.
So shift right then, if not right before it.
Add to nad's Reputation
Rate the quality of this post and help nad reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nad is offline   Reply With Quote
Old 12-06-2006, 10:35 PM   #9
osxuser
osxuser is on a distinguished road
How often do people drive up to the limiter. I shift a between 3500 and 4500 in normal driving. For racing, I do up it to 6500. Because I drive hard all them time, I started running semi-synthetic.
'96 SC2 5spd <-Staying N/A
'94 SC2 5spd RIP
Add to osxuser's Reputation
Rate the quality of this post and help osxuser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
osxuser is offline   Reply With Quote
Old 12-07-2006, 01:34 AM   #10
98greenSC2
98greenSC2 is on a distinguished road
98greenSC2's Avatar
Shift around 6600-6700rpm. Remember, no granny shifting would you should be double clutching.
Around town, I shift 2500-3000rpm.
http://members.cardomain.com/stdmtn11
15.59 @ 87.1 quarter mile
1998 Saturn SC2 *sold* What have I done!?
Add to 98greenSC2's Reputation
Rate the quality of this post and help 98greenSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
98greenSC2 is offline   Reply With Quote
Old 12-07-2006, 05:49 AM   #11
xupthree60
xupthree60 is on a distinguished road
xupthree60's Avatar
2002 L-Series 2.2L Sedan
yes u wernt double clutching like u should in that drag race
3x CFR SCCA autocross champion with a 95 SL2 & 98 SC2
Currently own a 02 L200 with no plans to mod.
Add to xupthree60's Reputation
Rate the quality of this post and help xupthree60 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xupthree60 is offline   Reply With Quote
Old 12-07-2006, 06:03 AM   #12
Sir Trews
Sir Trews is on a distinguished road
Sir Trews's Avatar
I agree with the top limit of 62...maybe 63 or so...beyond that, you're just turning the crank... but xupthree60? Why the d-clutch? When it's on, it's there... I thought....well... just a question.
<=== Just a Hotrod... with good ponies!
My SL2..She's hurtin'. Pretty bad. No pic.
All GM stable here... '71, and '89, both long beds...
*Hugs* Saturn Maniac! Glad you're still here! ;*)
Add to Sir Trews's Reputation
Rate the quality of this post and help Sir Trews reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sir Trews is offline   Reply With Quote
Old 12-07-2006, 06:19 AM   #13
xupthree60
xupthree60's Avatar
que??
i dunno what ur asking, i was just making fun of Dom (vin deisle)
Old 12-07-2006, 08:53 AM   #14
RangerRover
1999 SW2
IIRC, according to dyno tests, the peak torque is around 5000, but the peak HP isnt until later. This is all for the DOHC of course.
Old 12-07-2006, 08:55 AM   #15
Kevin94SL
Kevin94SL is on a distinguished road
Kevin94SL's Avatar
2006 ION-3 Sedan
On the SOHC I shift between 4500-5000 RPM. Torque peak is 2400RPM. Never had the opportunity to drive a DOHC with a clutch in it - I'd probably shift around 6000RPM though.
Kevin
Add to Kevin94SL's Reputation
Rate the quality of this post and help Kevin94SL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kevin94SL is offline   Reply With Quote
Old 12-07-2006, 12:07 PM   #16
S3aturnR
S3aturnR's Avatar
1999 SL1
yeah, the double clutch reference was a dig on "the fast and the furious". basically, anyone that knows anything about driving knows that you don't double clutch when you are upshifting. only downshifting and it's usually not necessary on modern cars or cars without a full race gearbox with no synchros. vin diesel wouldn't have sounded more ridiculous if he had told him he should have been heel/toe shifting during that race. that's another deceleration-only move...
s3aturnr
Old 12-07-2006, 12:19 PM   #17
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
I have an automatic. Shifts itself, freeing me up to drink coffee and scratch myself.
And double clutching is only used when a transmission has no syncronizers, like cars 60 years or more ago or some very old over the road trucks.
Old 12-07-2006, 12:33 PM   #18
S3aturnR
S3aturnR's Avatar
1999 SL1
ah, yes, the auto tranny. gotta keep one hand free for the babes, right?
double clutch can also be used in conjunction with heel/toe downshifting when going from a very hi-rpm to a low gear (either 1st or 2nd). there's a point where the synchros are simply overwhelmed and do nothing. a properly timed double clutch will help in those situations...
s3aturnr
Old 12-07-2006, 05:44 PM   #19
nad
1993 SC2
Heel and toe driving is used for downshifting. When you are going into first or second while traveling at a high rate of speed. The idea is to get the engine moving to the same speed that the tires are moving so that there is little/no wear on the clutch pad itself. Granted it is MANDITORY when you are driving a car without syncros. However using it in a modern day car is not a bad idea.
Double clutching is used in a turbocharged car. The process is step on the clutch, put the car into nuetral, let the clutch off. Step on the clutch again and hit your gear. This is done in order for the engine to slow down. If you "slam" into your next gear while still maintaining those high RPM's, your tires will spin. When your tires spin, you don't have traction, when you don't have traction, you are not accelerating which in turn makes you slower. Double clutching lets the motor drop down in RPM's so that when you do get into gear your tires will have less chace of spinning.
For example: Rev your car to 3 grand and dump the clutch. That's just the same as "granny shifting" your force fed car. On the other hand, hold it at 1.5 and dump the clutch. You will spin a lot less here and that is your "double clutch".
Old 12-07-2006, 05:55 PM   #20
98greenSC2
98greenSC2's Avatar
RPM Not Dropping after shift youngrwaggs S-Series Tech 26 05-24-2009 06:08 PM
RPM shift points for 93 SL2, WOT (video) 2003MercMaraude S-Series General 4 08-30-2008 05:30 PM
Problem with 2000 SL2 - High RPM no shift quaggo S-Series Tech 5 09-12-2007 04:43 AM
healthy shift points (rpm wise) Tatusmi S-Series Tech 32 03-26-2003 08:16 AM
What RPM does your auto shift at? GreenEggsAndHam General Saturn Discussion 13 09-17-2000 01:26 AM
