Old 12-02-2006, 02:32 AM   #21
98greenSC2
98greenSC2 is on a distinguished road
98greenSC2's Avatar
Default Re: eliminate wheel hop
I got some nasty wheel hop the last time I was at the track. It was my first time there with a LSD. I couldn't launch to save my life! 2.5 60' FTL. Anyway, I have the SMS dogbones and they do great. I have a crappy strut tower bar I'm looking to replace. I just filled in the dead spaces on the TAM with Windo Weld. I haven't noticed a big difference but I have been in any situations that'd likely induce wheel hop. I'd wager it'd cut down on it.
http://members.cardomain.com/stdmtn11
15.59 @ 87.1 quarter mile
1998 Saturn SC2 *sold* What have I done!?
Add to 98greenSC2's Reputation
Rate the quality of this post and help 98greenSC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
98greenSC2 is offline   Reply With Quote
Old 12-02-2006, 02:34 AM   #22
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
The LSD.. is it the Quaife?
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 12-02-2006, 03:54 AM   #23
98greenSC2
98greenSC2's Avatar
Nah, it's the PG. OK, it's not a true LSD. Still better than the stock open diff.
Old 12-02-2006, 05:15 AM   #24
Craig
Craig is on a distinguished road
There are three versions of the dogbone mounts; they will all interchange with each other (same mounting points and size), but the third-gen version is the only one that the Prothane mounts will fit.
Add to Craig's Reputation
Rate the quality of this post and help Craig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Craig is offline   Reply With Quote
Old 12-02-2006, 07:04 AM   #25
xupthree60
xupthree60 is on a distinguished road
xupthree60's Avatar
actualy they fit the 1st mounts and the 3rd mounts. cuz even tho they say the 3rd mount style is its own style, all they really did was convert back to the 1st style.
3x CFR SCCA autocross champion with a 95 SL2 & 98 SC2
Currently own a 02 L200 with no plans to mod.
Add to xupthree60's Reputation
Rate the quality of this post and help xupthree60 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xupthree60 is offline   Reply With Quote
Old 12-03-2006, 02:38 AM   #26
strongboy2005
strongboy2005 is on a distinguished road
I have a 94 sc2, will it fit?
What "generation" is my car?
Add to strongboy2005's Reputation
Rate the quality of this post and help strongboy2005 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
strongboy2005 is offline   Reply With Quote
Old 12-03-2006, 02:43 AM   #27
quiksc2
quiksc2's Avatar
1st gen. Should fit, from what the other guy said.
DCS
Old 12-03-2006, 04:03 AM   #28
xupthree60
xupthree60's Avatar
well i left off the word gen for a reason cuz the mounts didnt chainge the same times the gens did. i cant reember what years used the 2nd mount but 94 is deffenetly the first mount so they will work.
i wish i could remember where it was i saw all that info on the mounts
Old 12-03-2006, 01:16 PM   #29
eRic 02sc2
eRic 02sc2's Avatar
I have three questions:
1) How can I most effectively eliminate wheel hop?
2) How do I keep from blowing my diff pin?
3) Is there anything else I should be weary of "giving out" in a straight-line race?
I'm thinking about taking the saturn to the track in the Spring, and I don't want to embarass myself...
1) get rid of the OE Firestone Firehawk tires. they are bad m'kay
2) don't spin your tires while cornering
3) brakes? or clutch from launching at 4000 RPM too many times.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 12-03-2006, 01:22 PM   #30
eRic 02sc2
eRic 02sc2's Avatar
hmm... I get 2.3-2.4s 60-ft times with the stock open diff and OE tam and dogbones. how are you launching? try something less than 4000 RPM. say around 2500-3000 RPM to chirp without hop.
eRic 02sc2
Old 12-03-2006, 01:55 PM   #31
S3aturnR
S3aturnR is a jewel in the roughS3aturnR is a jewel in the roughS3aturnR is a jewel in the rough
S3aturnR's Avatar
1996 SL2
1999 SL1
naw... doesn't the 4000 rpm neutral limiter put you right in the drag racer launch sweet spot?!
the open diff is great for burnouts because it automatically transfers all the power from the wheels that grip, to the ones that don't...
s3aturnr
"reno is a lot like maybury, except everyone's on crystal meth and prostitution's legal" - junior
Add to S3aturnR's Reputation
Rate the quality of this post and help S3aturnR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
S3aturnR is offline   Reply With Quote
Old 12-03-2006, 08:28 PM   #32
strongboy2005
You only blow your diff pin from spinning out while cornering? I don't understand what it takes to blow the diff pin... my launches suck because I'm so afraid of peeling out even a little...
Old 12-04-2006, 02:44 AM   #33
xupthree60
xupthree60's Avatar
its not the pealing out that makes it break, its the sudden traction that does lol. a little spin is good for drag but not much at all, really u dont need to launch any higher than like 2600-2750 max, any more than that and ur spinning ur tires too much.
basicly dont do burn outs for fun. and if u get stuck somwhere that u can only get out if u floor it spinning ur tires, have someone pull u out insted. lol other than that i wouldnt worry too much
Old 12-04-2006, 03:30 AM   #34
quiksc2
quiksc2's Avatar
Ya. Before I knew about the diff pin problem, I used to dump my clutch and burn out all the time. Never had it go. Don't worry to much, but don't burn out just for fun.
DCS
Wheel Hop joemaniaci Vue Tech 2 09-16-2009 09:24 PM
Wheel Hop Turbosdime18 S-Series General 27 02-15-2005 11:19 PM
Wheel Hop... Rob1998SL2 Mods and Performance 9 07-01-2003 06:09 PM
Wheel Hop 97_SATURN_UT S-Series Mods 9 02-26-2003 12:39 PM
wheel hop grumpy Mods and Performance 6 01-31-2002 09:56 PM
