Old 11-30-2006, 10:03 PM   #21
mjo
mjo is on a distinguished road
mjo's Avatar
1995 SL2
Default Re: Hot air intake
The HAI is out of commission because of a leaking heater core (which gets worse the warmer the coolant gets). I don't thing the HAI caused this because the car's been seeping for a year now. Thought I fixed it when I replaced the coolant pump
mjo is offline   Reply With Quote
Old 12-01-2006, 02:32 AM   #22
98greenSC2
98greenSC2 is on a distinguished road
98greenSC2's Avatar
I think, and correct me if I'm wrong, that basic physics says it takes a certain amount of energy to move an object of a certain weight at a certain speed. So, in theory, a car with a CAI and one with a HAI (assuming everything else is equal) will use the same amount of power to move at the same speed.
However, might the HAI has a slight advantage because of the less dense air requires the driver to open the throttle more to compensate? Wouldn't a more open throttle reduce parasitic pumping losses?
http://members.cardomain.com/stdmtn11
15.59 @ 87.1 quarter mile
1998 Saturn SC2 *sold* What have I done!?
98greenSC2 is offline   Reply With Quote
Old 02-12-2007, 03:20 PM   #23
mjo
mjo's Avatar
1995 SL2
Here's an update on the hot air intake mod. It definitely helps with fuel economy. After fixing the coolant leak from the heater core, the coolant temperature gauge always reads within the normal range. I also put in a new O2 sensor. My current MPG averages are 33-35 MPG for ambient air temps around 30-40 degree Fahrenheit. The cold weather I have been experiencing lately where the temperatures have been close to zero the mileage has been between 28-30. I did a 200 mile trip recently where I calculated the FE to be above 36 MPG; the ambient air temp was in the 20s and this trip took 6 hours because of the horrible icy weather I had to drive through.
Overall it looks like a fantastic, cheap, easy, winter mod for the DIY.
Modified air intake for hot air added 7.2% to mpg cheapybob S-Series General 90 01-19-2016 04:44 AM
Hot Air Intake? Mr Joe Handyman Vue Tech 22 07-07-2006 02:14 AM
Cold air intake removing stock air intake acwild S-Series Mods 2 03-26-2006 01:18 PM
