Old 10-11-2022, 11:15 AM   #1
kylesn
kylesn is on a distinguished road
Default saturn ion power locks
my 07 ion power locks not working right the doors won't lock when i press the lock button but they will unlock when i press the unlock button any ideas?
kylesn is offline   Reply With Quote
Old 10-11-2022, 05:20 PM   #2
Default Re: saturn ion power locks
If you have a spare remote, try it. Do the master door lock switch work to lock and unlock doors?
Old 10-11-2022, 09:15 PM   #3
kylesn
i don't have a key fob my car is just the base model i was referring to the buttons on the door
Old 10-11-2022, 11:00 PM   #4
My guess is the door lock switch is faulty. All signals unrelated to engine management (EFI system) are sent to the body control module. The bcm runs everything except air bag and abs. They have their own module as separate systems. All modules including the ecm/pcm send error codes to the bcm for output to the OBD II port.
Old 12-29-2022, 05:14 PM   #5
JefferyC
JefferyC is on a distinguished road
JefferyC's Avatar
It may have grown weak with age, had similar issue on my VUE. Check out RA.
JefferyC is offline   Reply With Quote
Old 01-14-2023, 12:59 AM   #6
kylesn
still having the issue not sure what it is neither the drivers side or passenger side power lock button will lock the doors but both will unlock the doors when i press the lock button on either side i hear a clicking noise but it sounds like it is coming from behind my radio or in that general area im at a loss and just been locking the doors manually
Old 01-15-2023, 09:25 PM   #7
It would be helpful if punctuation were used in the post quoted above. Many times I find it awkward to interpret where changes in sentences belong. If clarity matters to anyone out there punctuation really does matter. (If you think it doesn't matter then take a look at the next contract you sign.)
Oh well... Here's what comes to mind:
1) when problems like this arise they do not go away;
2) the OP has been given as good advice as is possible for outsiders to provide;
3) I agree with fdryer that the problem is likely to be a switch failure (post #4).
4) If the driver's door lock switch operates locks at both doors then it is effectively a "master" switch. I believe that it should be replaced first. The failure in this type of switch can result in the same failure of operation through another door lock switch;
5) It's up to the OP to decide what to do next. In any event, this is not a particularly difficult problem to resolve.
390K miles (engine replaced @ 375K).
Biden/Harris predictions, '21 -'25: weak economy; weaker military; more terrorism; emboldened RED CHINA. Sadly, B & H are proving me correct.
Saturn ion power locks justinmj4im Ion General 2 11-19-2015 07:54 PM
Saturn Ion no power Windows or Locks . . . Faeedor Ion Tech 5 07-02-2012 11:58 PM
Just Converted My Saturn to Power Windows and Locks xserver S-Series Tech 11 06-13-2009 03:19 AM
1999 Saturn SL1 - power locks clicking, windows not working Kurt321 S-Series General 2 05-28-2007 04:27 PM
1993 saturn sl1 power door locks blkmrideon22s S-Series General 6 01-18-2004 05:21 PM
