Old 09-19-2005, 07:31 PM   #1
1995-SL1
1995-SL1 is on a distinguished road
Default LS-1 Automatic Transmission Fluid Change
Hi All,
I recently purchased a 2000 SL-1 from the original 85 y/o owner.
The car has only 47k and is in beautiful condition. I want to service the automatic transmission and when I went to read the owners manual for the correct procedure (pictures, etc), it is an S-series owners manual! Go figure. The car comes with the manual, so I cant even believe the dealer screwed up. Maybe it was shipped with the wrong manual from the factory. In any case, I really need the correct procedure and fluid capacity. Also, this trans has a filler cap, but no dipstick (?), so I can only assume that I can't even check the level or inspect the fluid easily. Mama-Mia! Can someone explain the procedure or (MUCH better), can someone please fax or email or post the 1 or two pages that cover the auto trans/differential (same fluid, I'm guessing) service procedure.
A big THANKS in advance!
Add to 1995-SL1's Reputation
Rate the quality of this post and help 1995-SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1995-SL1 is offline   Reply With Quote
Old 09-20-2005, 09:24 AM   #2
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Default Re: LS-1 Automatic Transmission Fluid Change
The owners manual is an S series manual because you have an S series car. It's the first letter that tells you what series you have, the L series cars are LS or LW.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 09-20-2005, 09:49 AM   #3
BobL
BobL is on a distinguished road
if no dipstick, you do have an L series, but the wrong manual.
Changing tranny fluid is a total PITA on the L, and you'd be better off letting the dealer do it.
Drain period is over 50K, but 50K's not a bad idea.
Add to BobL's Reputation
Rate the quality of this post and help BobL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobL is offline   Reply With Quote
Old 09-20-2005, 05:23 PM   #4
1995-SL1
Thanks Bob,
I am an ASE master tech, so I would prefer to do the job myself, if I can get the right info. My LS1 (it is not an SL1) is my first L series, so I would like to learn the ropes. What is the deal with no dipstick? Just assume the fluid level is correct until it is time to change it? If you have any further info from an owners mauual, let me know.
Many thanks,
Max
Old 09-20-2005, 05:32 PM   #5
1995-SL1
PS - I just noticed that I wrote "2000 SL1" in my first post. My mistake. My new Saturn is a 2000 LS1. Stupid GM - the best thing they ever did was properly name their V-8 engines (LS1, LS6, LS7, etc). Then they do there best to confuse things by giving their newest line of vehicles identical and ever-confusing alphanumeric nomenclature. From SL1 to L100 to LS1, LW, WL, OHWell, yada , yada. Even us mechanics screw it up.
Thank God for Relay, Ion, etc. Much more proper names.
Old 09-20-2005, 06:19 PM   #6
bigc791
bigc791 is on a distinguished road
bigc791's Avatar
1994 SL1
I doubt it came with the wrong manual from the factory since they are made on other sides of the country. But anyways trans fluid change is pretty straight foward. Done the same as all GM transverse trannys since its the same thing. Drop the pan remove the filter install filter reinstall pan bolts are torqued to 9ft/lbs then add 6.9QQt of fluid. Filler is on the top to check it remove the plug near the right side axle. if low nothing will come out if over filled allow to drain from the hole until it dribbles. It must be checked when warm
Carmen
1998 2.4L swapped Plymouth neon is my ride.
Add to bigc791's Reputation
Rate the quality of this post and help bigc791 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigc791 is offline   Reply With Quote
Old 09-21-2005, 11:40 AM   #7
1995-SL1
Thanks for the info.
Can any one post fax or email me the page from the owners manual?
Maxxam8888@Yahoo.com
Thanks!
Old 09-23-2005, 08:53 AM   #8
BobL
You might want to post on Tech Talk to see if someone can send you something from the factory service manual.
I had a 2000 LS and the owner's manual had no info on trans fluid changes except the recommended interval.
Old 09-23-2005, 05:25 PM   #9
1995-SL1
Good idea - thanks.
By the way - I am having a heck of a time trying to find a cheap (meaning used) drivers side front headlamp assembly. Mine has two out of three mounting tabs broken. There are TONS of used SL/SC headlamps on eBay and I have even found a few at some salvage yards. But I have yet to find any LS headlamp other than dealer new or aftermarket.
VUE 3.5L Automatic Transmission Fluid Change David Harleyson How-To Library 54 08-03-2019 03:05 PM
Automatic Transmission Fluid unit731 Ion General 21 06-20-2019 08:40 AM
2007 Saturn Vue Automatic Transmission Fluid Change greensaturn How-To Library 13 11-04-2018 09:31 PM
How to change the automatic transmission fluid? atikovi Ion Tech 5 07-23-2006 11:49 PM
LS1 Automatic Transmission Fluid Change Info 1995-SL1 L-Series Tech 6 10-17-2005 12:38 PM
