Old 12-16-2007, 05:41 PM   #1
docusn1
docusn1 is on a distinguished road
Dizzy Sat SL1 P0301 CODE ROUGH IDLE
Hi to all my name is Mark I have a 2002 Saturn SL1 4Dr. Sd. with 50,000 miles original owner. My service engine light came on in the car some time ago with rough low idle and sulpher smell in exaust. Tune up performed with quality plugs, wires, upper O2 sensor, PVC Valve, air filter. After that was done still had rough idle and smell checked for code and came up with P0301, with that in hand I swaped coils from left to right and ran car again hopeing for a different cylinder code but still had same code. I then pulled of the module and had it tested and the module failed. With that in hand I replaced module and the car ran alot better no smell idle alsmost perfectly smooth with a occasional hiccup herd in the exhaust. Injectors cleaned and I still get the same code and if left at idle for long periods of time it will become rough but the smell is gone.
Any help ideas would be greatly appreciated, Thank You Mark
Add to docusn1's Reputation
Rate the quality of this post and help docusn1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
docusn1 is offline   Reply With Quote
Old 12-16-2007, 06:00 PM   #2
rc1488
rc1488's Avatar
Default Re: Sat SL1 P0301 CODE ROUGH IDLE
clean out your throttle body and IAT passages replace gasket if needed also. have you change your ECTS ? if not id do it also while your under the hood.
Add to rc1488's Reputation
Old 12-16-2007, 10:28 PM   #3
CrewCab
CrewCab will become famous soon enough
CrewCab's Avatar
2008 AURA XE
Take a can of carb cleaner and spray it on the intake manifold near the # 1 cylinder area. You should notice a change in the idle, the vehicle may even stall.
A leaky intake manifold gasket are common for the later generation SOHC engines.
Add to CrewCab's Reputation
Rate the quality of this post and help CrewCab reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CrewCab is offline   Reply With Quote
Old 12-17-2007, 08:25 AM   #4
docusn1
Dizzy Re: Sat SL1 P0301 CODE ROUGH IDLE
Thankyou for the help I will clean out the TB and IAT passages today and replace the ECTS while I am there. Mark
Old 12-17-2007, 08:30 AM   #5
docusn1
Thankyou I will spray that area down today when I clean the TB and change the ECTS, I hope this will point to closeing the gap on this code and rough idle. Thankyou again,Mark.
95 sc1 rough idle ses code 26 help twwhited S-Series Tech 9 11-15-2009 04:23 PM
P0300 code and rough idle jakelabob Ion Tech 1 02-06-2009 01:40 PM
Rough Idle and P0410 code storm_amoure S-Series Tech 21 11-17-2007 10:50 AM
Code P0300... Rough Idle mrb277 L-Series Tech 1 07-09-2006 10:48 AM
SES code 45, rough idle, exhaust smell dennis S-Series Tech 22 06-20-2006 11:28 AM
