Old 10-08-2018, 09:51 AM   #361
Zeebins
Zeebins's Avatar
Default Re: 96 SC2 bringing it back to life (slowly)
Did you use the original Saturn red or is it just a generic red?
The fun starts when you shift into third
1997 SL2, 114K miles
Add to Zeebins's Reputation
Old 10-08-2018, 10:22 AM   #362
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
1996 SC2
1999 SC2
It was a single stage Summit Racing Gloss, Flame Red.
I have never sprayed base clear coat so I just bought this paint it has a hardener with UV protection.
Since it was a different color we had to paint the door jams.
Add to Mark_b's Reputation
Rate the quality of this post and help Mark_b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark_b is offline   Reply With Quote
Old 10-08-2018, 12:05 PM   #363
Wow, looks fantastic!
Old 10-08-2018, 12:37 PM   #364
Mark_b
1996 SC2
1999 SC2
Thanks.
My arms are sore today.
The color sanding process was this.
I worked on one part like fender at a time. I taped off adjacent edges or the hood worked one half and tapped center line.
Wet sand with 1200 clean sand again 1200 clean spot sand with 1200.
Wet sand with 1500 clean spot sand 1500.
Sand 2000 clean
Buff with wool wheel Meguiar's 105.
Clean spot buff with Wool pad Meguiar's 105.
Clean foam pad Meguiar's 105.
Clean the foam pad use Meguiar's Mirror Glaze 82 Professional Swirl Free Polish
Clean then use the finish foam pad with Meguiar's G19216 Ultimate Polish clean then done move on.
I started out with Summit Racing compound but that did not work near as well as the above procedure.
Old 10-09-2018, 08:10 PM   #365
Mark_b
1996 SC2
1999 SC2
I did a review on Summit Racing and posted picture of Zackís Saturn.
Give the Saturn a little exposure.
https://www.summitracing.com/parts/SUM-UP321
Old 10-18-2018, 10:34 AM   #366
Mark_b
1996 SC2
1999 SC2
I canít find the driverís door chrome trim at the top.
When we took it off we put a small kick in it now it will not stay on.
I checked junk yards here and two adjacent states and I can find this trim piece.
Does anyone have one they are willing to sell to me?
Old 10-18-2018, 10:51 AM   #367
Mark_b
1996 SC2
1999 SC2
I need this trim piece for a 96 SC2
Old 10-18-2018, 07:59 PM   #368
Looks to officially be considered a part of the SC outer window sealing strip assembly for the left door. Checking the JY pix some 96 SCx cars have the chrome strip and some do not. There is no indication tat it was a dealer installed option either.
Old 10-18-2018, 08:48 PM   #369
Zeebins
Zeebins's Avatar
I was at the junkyard eariler and there was a SC1 that had the chrome strip under the window. It looks like part of it was peeling off though. Maybe the chrome was just some kind of sticker that went over the normal black trim?
Old 10-19-2018, 10:30 AM   #370
I had a few cars where the strip was chrome under black rubber/plastic.
Weird. The black rubber/plastic coating wore away, exposing the chrome.
Most older pics of SC2s that I recall show that as black trim.
For example:
http://www.skoutr.com/images/saturnsc2/P6100009.JPG
I do see a few where it looks like chrome on that lower piece, but that is the only chrome piece on the entire car.
Old 10-19-2018, 10:34 AM   #371
Mine is black. Might be an easy piece to try and do chrome vinyl wrap on.
Add to Waiex191's Reputation
Old 10-19-2018, 11:03 AM   #372
trottida
trottida's Avatar
For what its worth, I didn't think that piece looked right in your photos. My intuition thought it would be better off black. I love how this car has turned out and I'm somewhat envious.
2001 SL1 MT (433,500 km @ 06/2019)
1999 SL2 MT (277,300 km @ 06/2019)
2011 Suburban LT (128,250 km @ 06/2019)
Past Saturns
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-19-2018, 01:05 PM   #373
macbox
macbox will become famous soon enough
macbox's Avatar
1997 SC2
Those are hard to find and they are equally persnickety when being removed and installed.
Removal tends to bend the rear part upwards, and they are hard to straighten once bent. On my current DD, the PO had driven a screw through it and into the door frame to keep it from bending upward, probably because it was removed and bent during removal. The last time I got one from a junkyard I cracked the door panel of the donor car next to the bottom rear corner of the window, so be careful for that. When you take the mirror off, you can push it rearwards from the front instead of prying it up.
The next time I install one, I'm greasing it up so it slides on easier.
Prior to install, soak the mouse fur with silicone spray soaked into a cotton ball, the cotton ball will prevent spray from getting everywhere, and the silicone will help the window slide.
They are a black semi-gloss finish that peels off with age, and the chrome is underneath. The only thing that I've thought of that is closest to that finish is plasti-dip spray, but I' haven't tried it.
If you order one of these somewhere, make sure they mount it on a piece of wood before boxing, otherwise it will get bent while in transit.
"The Twins"
#4, "Betty" 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#7 "Betsy" 1995 SC2, 131K, daily driver.
Add to macbox's Reputation
Rate the quality of this post and help macbox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macbox is offline   Reply With Quote
Old 10-19-2018, 02:01 PM   #374
That chrome cover is not intended to ever be removed from the outer window belt seal strip, the entire assembly is a unit. For slip use this stuff 3M 08897 https://www.amazon.com/MWUR9-08897-S...70_&dpSrc=srch
Old 10-23-2018, 06:52 PM   #375
Mark_b
1996 SC2
1999 SC2
I looked on the ends and it does look like it had black over it at one time. Strange it is chrome under it.
I do not know where I am going to find the piece. There are no gen 1 SC2 in the junk yards around me.
This weekend I might try to fix the bend in it maybe that will keep it on.
I changed oil in this car over the weekend and my son has put a little over 7K miles on it since the motor rebuild.
Old 11-01-2018, 12:23 PM   #376
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
Mark, I found one in the local yard and pulled it for you. I believe you needed the driver side, as that is all the car there had also. It will need paint or the chrome needs to be slightly polished. I removed it as a unit, so the chrome is not bent.
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Old 11-01-2018, 12:58 PM   #377
Mark_b
1996 SC2
1999 SC2
Thank you so much! Yes it was the drivers side. It pops up almost everyday then i push it down. My son will be excited.
I just texted you
Old 01-14-2019, 11:45 PM   #378
Mark_b
1996 SC2
1999 SC2
Quick update.
My son has put 10,500 miles on his car since we rebuilt the motor. He is now getting 29 MPG he really likes his car.
The only issue it has is if It sits for a week or more the fuel system will lose its prime.
We now have a complete fuel pump/sending unit on hand to install one weekend when he has the tank low on fuel.
He drives to school everyday so it does not normally sit very long. So it is not a big deal but i still would like to take care of it.
Old 04-19-2019, 11:14 AM   #379
Mark_b
1996 SC2
1999 SC2
The car is running great no codes. My son has put on just under 15,000 miles on the motor rebuild. The car has just went over 100K miles.
He will be needing a new set of tires soon but that is not a bad thing.
Old 04-19-2019, 11:41 AM   #380
The proper starting technique with these cars is to turn the key to ON and allow the PCM and initial monitor tests to run. This takes less time than it does to put on the seat belt so it goes like this: key on but not crank, put on seat belt, crank engine.
If you install the carter pump it usually solves the bleed down issue.
2004 Saturn Ion 2 QC 2.2 manual - revs slowly, returns slowly to idle chetterhead Ion Tech 14 09-22-2012 11:43 PM
Bringing the old gal back to life Hjoken S-Series Tech 21 02-24-2012 12:45 PM
Could Magnas Unique Business Model Lure Penske into Bringing the Astra Back to Lif wifeofcore General Saturn Discussion 14 06-18-2009 12:46 AM
Bringing 94 SL1 back to life - been sitting for 3 1/2 years Spazie S-Series General 19 01-02-2008 02:19 PM
bringing a $400 SC2 back to life geartooth94 S-Series Tech 9 01-12-2005 09:31 AM
