Old 04-11-2013, 03:11 PM   #1
sdowiat
sdowiat is on a distinguished road
Default 94 S Cooling
Mine is a 94 5speed. Lots of miles ( about 250k ) but still runs good and gets 40 mpg. ( I can make it get 45 )
A couple of years I had to change the radiator. Not sure why, but since that time it doesn't cool as well as it should. Where it used to normally run with the temp gauge dead in the middle... now it wants to run higher. The electric fan does work, it's on continually whenever the AC is on and it comes on when the temp gauge is at about 3/4 and if the outside temp is 85 or higher it will get to the red... so I'll turn the heater on to pull it back down.
I've never had the red light come on, ( I watch the gauge ).. but it sure a pain running the heat in hot weather...
Questions: Do you think the new radiator capacity is too low? Can you replace the sensor with one that makes the fan come on at a significantly lower temp? Can you easily rig the fan to come on when you flip a switch, or rig it to run all the time?
sdowiat is offline   Reply With Quote
Old 04-11-2013, 04:12 PM   #2
Default Re: 94 S Cooling
First thing to do is replace the 2 wire temperature sensor, ECTS. While replacing it also carefully inspect the connector for any minute signs of moisture or corrosion.
http://www.youtube.com/watch?v=cucm7QGlsYs
92' SL1 cooling fan Phoenix_SL S-Series Tech 3 04-24-2012 03:53 AM
Cooling...EGR....SL1 saturn94v S-Series Tech 6 03-04-2011 12:07 PM
Cooling fan won't come on! GoldenSaturn94 S-Series General 9 09-15-2005 07:02 AM
Cooling Fan How-To? texlnghorn S-Series Tech 3 04-13-2005 09:56 AM
Cooling fan does not come on.. Rob130 S-Series General 7 03-22-2005 04:36 PM
