Old 10-02-2019, 09:11 PM   #1
Chaz9496
Chaz9496 is a jewel in the roughChaz9496 is a jewel in the roughChaz9496 is a jewel in the rough
2001 L-Series 2.2L Sedan
2003 L-Series 2.2L Sedan
Default Stabilizer Bar Bushing Insulators
Does anyone know where you can get bushing insulators ? They seem to be unavailable, which doesn't surprise me in the least. I've got a rattle on the right front side over bumps and you can also go over one on the left side and the right still rattles. The sway bar links have been changed and are tight using a pry bar. New strut mounts in 2016. I was told to try rapping the bar with duct tape and see if it stops it, then the problem is the insulators. A co-worker gave me a ride home a few months ago and his Chevy Equinox Made the same noise, on the same side. I asked him what that was and he said the tire shop said it was a bad tire. lol. Really?! He spent $350 on new tires and the second ride home it still did it. Someone didn't know what they were talking about there. What do you do if you can't replace them, drive it like it is ? Maybe somehow I can find some universals. I just need the diameter of the bar for the correct fit. Thanks for any info.
Add to Chaz9496's Reputation
Rate the quality of this post and help Chaz9496 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-02-2019, 09:50 PM   #2
Chaz9496
Default Re: Stabilizer Bar Bushing Insulators
From what I found, Moog makes insulators by bar diameter. That's probably what I'm going have to try.
Old 10-03-2019, 09:40 AM   #3
floridasl22002
This supplier appears to have them
https://www.carid.com/2002-saturn-l-...nce-sway-bars/
Old 10-05-2019, 10:45 AM   #4
Chaz9496
Nope, Out Of Stock. I checked that site already last week too.
Old 10-05-2019, 10:47 AM   #5
Chaz9496
Does anyone know the Sway Bar diameter ? I can get universal bushings from a Moog dealer but they go by diameter. If not, I was going to mic it. Thanks -In-Advance.
Old 10-13-2019, 08:01 PM   #6
tomlct
tomlct has a spectacular aura abouttomlct has a spectacular aura about
I looked up for Vectra B on a French parts site, and it came up with Moog OP-SB-6806. Is this what you are looking for? I think it looks like the AC Delco piece. The page also shows the specs, so maybe you could find a Moog or similar part from the US.
(I had to buy the short end cables for the emergency brake for drum brake models from the German EBay site, using Vectra B as a reference, parts non-available is a problem for us, keeping our L's on the road)
https://www.oscaro.com/coussinet-de-...-p#/?vid=16710
Add to tomlct's Reputation
Rate the quality of this post and help tomlct reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tomlct is offline   Reply With Quote
Old 10-14-2019, 07:57 PM   #7
Chaz9496
I'm not exactly sure. I may be incorrect but my Sway Bar measured 19.99 MM with the micrometer today at work. I assumed it would be a 20 MM inside diameter insulator then. I may have it mic'd by a tech just to make sure sure I have the correct measurement. The one in the link looks a little small and it shows it's 16 MM inside diameter. I'm not too good with measuring instruments.
Old 10-20-2019, 03:14 AM   #8
pierrot
pierrot's Avatar
Front stabilizer bar bushing kits are easily found online through OEM parts websites and are not expensive. Our L-Series cars use the same sway bar regardless of engine size and model year. By way of example see the link below, item no. 2.
https://www.gmpartscenter.net/auto-p...omponents-scat
322,000 miles - Holy canolli!
Add to pierrot's Reputation
2003 Ion Rear Axle bushing insulators dabatman99 Ion General 0 05-25-2014 07:07 AM
Stabilizer/Sway Bar Bushing Too Big?!?! Mr_Vexed Vue Tech 5 10-04-2013 09:05 AM
Stabilizer Bar Bushing Trouble silverbase Vue Tech 11 03-12-2013 07:59 PM
Front Stabilizer Bar Bushing size ? talonsaab Vue Tech 2 12-15-2012 10:43 PM
Stabilizer bushing replacement help! Iron Man S-Series Tech 17 11-28-2008 08:02 PM
