Old 05-28-2018, 08:47 PM   #1
Redvue55
Redvue55 is on a distinguished road
Default Crankshaft position sensor wire diagram
I have a 2003 Vue 3.0 Awd that i am looking for a pinout of the pcm connectors or a schematic for the crankshaft position sensor, i would like to run new wires to the sensor without disecting the wiring harnesses...
Redvue55 is offline   Reply With Quote
Old 05-29-2018, 02:13 AM   #2
Default Re: Crankshaft position sensor wire diagram
What makes you think new wiring between the crank sensor and ecm is needed? One simple question - did you lose both spark and injector operation? The crank sensor provides precise timing signals to allow the ecm to operate the EFI system. No crank sensor signals to the ecm = no fuel pump operation during starting/running, no spark and no injector operation. Verifying zero fuel requires removing plugs to examine them for fuel (injector and fuel pump operation). Verifying lack of spark would be spraying starting fluid into throttle while starting - zero spark while spraying starting fluid would mean the engine won't fire up.
The crank sensor doesn't need power. It generates signals from a Hall effect sensor; a built in magnet and field is altered by machined teeth on the crankshaft, generating pulses for each tooth and gap with a space to determine cylinder #1. The ecm uses these timing signals to operate the EFI system.
If you have fuel going into cylinders, the injectors are operating - this isn't a faulty crank sensor or wiring. If spark is seen, this isn't a faulty crank sensor or wiring.
Old 05-29-2018, 01:45 PM   #3
Redvue55
If ecm is not getting the signal, and the crank sensor is confirmed by diagnostics to be working as it's designed intent, there's obviously a disruption somewhere.
Old 05-30-2018, 12:28 AM   #4
To check pinouts on the ecm, you'll have to remove the battery, underhood fuse box, and battery box to access the ecm. There are two multiple pin connectors to the ecm.
Tags
ckp sensor, p0335, pcm pinout, vue, wiring diagram
crankshaft position sensor douglasfry Vue Tech 3 12-30-2010 03:05 PM
Crankshaft position sensor stejubek S-Series Tech 2 08-10-2009 11:52 PM
Crankshaft position sensor mushusdad S-Series General 22 05-12-2007 03:02 PM
Crankshaft Position Sensor Help striker1211 L-Series Tech 7 03-20-2007 11:09 PM
Crankshaft Position Sensor the_new_raceman S-Series Tech 3 03-11-2005 10:37 PM
