Old 12-01-2021, 06:57 PM   #1
dakota1820
dakota1820 will become famous soon enoughdakota1820 will become famous soon enough
2001 SC1
Default Service light
My 01 SC has had the light on the couple of months I've owned it. I think all the dash lights are working I took a picture so if I'm wrong please tell me . What else could cause it to be on?
dakota1820 is offline   Reply With Quote
Old 12-01-2021, 09:05 PM   #2
billr
Default Re: Service light
Which one is "the light" you are concerned about? Have you have the car scanned for codes?
Old 12-01-2021, 10:02 PM   #3
dakota1820
2001 SC1
The service light is the light that stays on. I was told it meant a light on the dash is burned out but I don't see this as the case hence why I posted a picture of the gauge cluster to see if anyone did see a warning light that wasn't lit up.
Old 12-01-2021, 11:08 PM   #4
toggenburg
toggenburg's Avatar
It's not a maintenance reminder light, it's a malfunction indicator light.
It indicates a non-emissions-related problem, like with something controlled
by the body computer module.
You'd need to scan the codes to know what it was.
Old 12-01-2021, 11:14 PM   #5
Wrench light codes can only be read by a Tech II level tool, likely requires the Saturn specific add-on card as well.
In no particular order: Seatbelt, ABS (if equipped), Upshift (if manual trans), trunk/hatch open, low traction (if ABS equipped), turn indicators, DRL and high beam bulbs are not turned on in the pic.
Some of those are easy to test, others require pulling a fuse and/or the cluster.
Old 12-02-2021, 02:07 PM   #6
dakota1820, can you take another snapshot of the gauges with the engine running (idle)?
Hwy speed: service light, then battery light, then red engine light Upstate Saturn S-Series Tech 14 08-15-2018 03:27 PM
2003 Vue-Intermittent Service / Service Engine Soon Light rogers017 Vue Tech 0 10-05-2014 12:29 PM
Does the service chip reset after the service engine soon light goes off? whydoineedtoreg Vue General 5 07-20-2011 11:16 PM
service light (not service engine soon) 96sl2 irondiezl3 S-Series Tech 9 11-14-2006 08:51 PM
Service light (wrench) and poor dealer service Speedy L-Series General 15 04-19-2005 03:00 PM
