Old 10-21-2018, 06:21 PM   #21
Default Re: TPS woes
The problem is likely inside of the PCM. Regardless of where the TPS is set physically the PCM will assign the value of 0.37-0.4v to the data out at key ON, the actual voltage may be quite different. Insulation piercing probes are real handy at this point.
--5v reference to block ground
--5v reference to TPS(PCM) ground
--TPS signal to TPS ground, throttle closed
--TPS signal to block ground, throttle closed
Old 10-22-2018, 12:05 PM   #22
Saturn Night
Originally Posted by RobertGary1 View Post
Strange datapoint
Heading out for some dr mandated cardio I realized my multimeter was still hooked up to back probe the pcm across the tps sensor and tps ground (not reference ). So for kicks I turned on the multimeter and turned on the ignition. Got 0 volts. Figured the probes have slipped out so I pressed the gas. It reacted. Then back at idle the voltage very slowly stated to climb until it reached 0.40.
Got my bicycle ready and thought maybe Iíll try that again. This time without touching the throttle. Turned on the multimeter, tuned on the ignition got 0 volts. Waited about 5 seconds and the voltage slowly started to climb. About 0.02 volts/second until it reached 5v.
After my ride I might switch up my set up to read across the tps reference and tps ground and see if itís the same.
Iíve never tried this type of test before; this seems like itís wrong. The PCM shouldnít have to warm up to have proper reference voltage? Or maybe itís normal for some strange reason.
-Robert
Have you tried replacing the connector pigtail and some of the wiring? I have read over the responses and your issues, which sounds like a loose electrical connection.
The TPS is nothing more than a similar type of resistor found in Tyco RC track car controllers, or the resistor used for the fuel pump sending unit to the gauge.
As the butterfly opens, there is a little metal piece that moves along the coil inside the sensor, which adds or takes away resistance, which is how the voltage signal being sent from the PCM is changed.
You can test a TPS with an ohm meter, on the pins and see how they work.
Unplugging the sensor will default the PCM to "0" resistance, so the full 5v signal is commanded by the PCM, but will then set a DTC because no signal is returned and you have a broken circuit.
Old 10-22-2018, 12:52 PM   #23
RobertGary1
Yes, 3 pig tails, 3 TPS's and 2 TB's. See original post for discussion of bad connection.
-Robert
Old 10-22-2018, 12:56 PM   #24
RobertGary1
The problem now is getting it to happen. I've got a multimeter taped to my dash probing the TPS signal across the TPS ground. I'm waiting for a P0122 to be thrown or even a bad idle.
I noticed that the EGR and MAP share the same 5v reference circuit so I think I'll compare it to see if it also has a slow warm up. The 5v reference circuit for the TPS takes several seconds to come up to voltage if the PCM is "cold" but immediate if the PCM has had power in the last few minutes. I'm not yet certain this isn't normal though. That in itself doesn't throw a code likely because the PCM is comparing the TPS signal with the TPS reference.
-Robert
Old 10-26-2018, 06:13 PM   #25
Saturn Night
-Robert
Ahh, ok. I didn't notice you had replaced the connector already. I did see the other repairs.
I don't much about PCMs, when TS, other than a bad PCM doesn't always code or trigger the light.
You could have an issue with a fried Quad Driver Circuit, of the MAP/EGR reference voltage are on the same circuit.
Replacement/Reprogramming the PCM may be your remedy to this one. I'm going to just follow this thread, since Nuc knows more about this than I do.
Old 10-26-2018, 08:56 PM   #26
-Robert
I would check the other sensors on the 5V ref bus. That slow rise to 5V is indicative of a failed circuit in the PCM unless you see the same thing on the other loads. It should be instantaneous upon key ON though. Might be worth the effort to give it a hard look.
Old 01-07-2019, 01:36 PM   #27
RobertGary1
As a follow up. I placed a multimeter at the PCM connector across the TPS voltage and its ground. I taped the multimeter to the dash so I could watch it. The problem has never again happened (knock on wood). Either its just super intermittent or perhaps there was a problem with the contacts at the PCM that backprobing the contacts corrected.
-Robert
Old 01-07-2019, 02:30 PM   #28
PCM contacts are a known issue, usually the older PCMs are relatively immune and fixed with a thorough contact cleaner bath. I recommend insulation piercing probes instead of any back probes as these contacts are quite easy to damage mechanically by backprobing.
Old 01-07-2019, 02:54 PM   #29
billr
billr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of lightbillr is a glorious beacon of light
I disagree, the PCM connectors in my '94 were very easy to "back-probe", without getting even close to the contact area.
With the locking "comb" out I put the end of a small wire in next to the long crimp area, then put the comb back in to lock the probe wire in and make sure it was snug against the crimp area.
Add to billr's Reputation
Old 01-07-2019, 04:29 PM   #30
That is not backprobing.
Old 01-07-2019, 07:48 PM   #31
RobertGary1
Yes. When I say backprobe I mean shoving the probe in the output end of the connector.
-Robert
Old 01-07-2019, 09:11 PM   #32
billr
Now I'm really confused. OP, do you mean with the connector halves not mated? I think of "back-probing" as being from the wire-side ( "back" side) of a connector, done so you can read voltages with the circuit connected. Probing the contacts of a disconnected harness is just, um... "probing". I wonder if there is some official definition (SAE, ANSI, IEEE, ASE, whatever...)?
Old 01-07-2019, 10:31 PM   #33
RobertGary1
No, with the connector connected shove the probe in the ass end of the connector.
-Robert
Old 01-08-2019, 12:06 AM   #34
billr
OK, you and I (and everywhere else I have looked) are in agreement about what "back-probing" is, and I stand by my opinion that it is safe and easy with the PCM connectors using the method I described above.
Old 01-08-2019, 09:54 AM   #35
Just google "back probes" these are specially designed test probes used for back probing low voltage circuit connectors that usually do not have environmental wire seals. The gen-1 and 2 PCM does not have environmental seals.
Use the correct tool for the job and know how to use it.
https://www.pomonaelectronics.com/pr...obe-pins-basic
Old 01-08-2019, 02:22 PM   #36
billr
I wonder which one of us is going to grow up and quit this silly bickering first?
I am referring to a method of getting voltage readings without un-mating a connector, not a specific make or shape of "probe" to accomplish that. I'm simply saying a small wire can be slipped in there (talking about gen1 PCM connector) easily and with no damage to the contacts. It "probes" in exactly the same manner as any of the slip in tools, and extremely similar to insulation-piercing "back probes", but with no damage to wire insulation.
AC Woes marcusmerritt S-Series Tech 1 06-08-2014 08:39 PM
HELP 98 SW2 woes Saturninin S-Series General 19 11-13-2011 06:47 PM
A/C Woes k-dee Ion General 3 09-22-2005 08:48 AM
Rad woes. Kevin94SL S-Series General 5 10-21-2004 09:42 AM
PCM Woes ProDarwin Miscellaneous Tech 4 06-06-2003 12:42 AM
