Old 11-05-2018, 03:58 PM   #1
odiaz1831
odiaz1831 is on a distinguished road
2003 ION-3 Sedan
Default Easiest Auto Trans Fluid to get?
Im having trouble getting my hands on trans fluid for an auto trans. Currently Im waiting on some Valvoline max life for imports, but I recently had Walmart cancel my order for the same amount. Hopefully Adavanced Autoparts comes through. Whats the most common fluid around that we can use?
Add to odiaz1831's Reputation
Rate the quality of this post and help odiaz1831 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
odiaz1831 is offline   Reply With Quote
Old 11-05-2018, 04:28 PM   #2
Default Re: Easiest Auto Trans Fluid to get?
Any fluid marked Dexron/Mercon compatible. For example, at Walmart,
https://www.walmart.com/ip/Super-Tec...allon/20573820
(read the bottle in-store, as their packaging for different formulations looks nearly identical)
Super Tech Automatic Transmission Fluid is formulated with premium quality ingredients to provide excellent performance in General Motors and Ford vehicles requiring the former Dexron III or Mercon transmission fluid.
In the S-series, both the manual and auto transmissions used the same fluid.
Mobil One ATF should be available, and should have a Dex/Merc formulation
Old 11-05-2018, 04:40 PM   #3
odiaz1831
2003 ION-3 Sedan
Oh wow i didt know the supertech reached the requirements. I had only seen a bunch of different and expensive fluids on this site.
Old 11-05-2018, 09:15 PM   #4
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
1997 SW2
This is easy to get.
Advance Auto.
• 1994 SL1 new traded
Add to dummo's Reputation
Rate the quality of this post and help dummo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-05-2018, 11:14 PM   #5
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Valvoline Dex/Merc...
Blue jug, not the red Dexron VI...
https://www.walmart.com/ip/Valvoline...allon/15125788
NGK BKR6E-11 spark plugs
Old 11-18-2018, 01:42 AM   #6
odiaz1831
2003 ION-3 Sedan
Finally did my fluid change. Filter that was on was red, but no magnet. Signifies that it was changed at least once? Anyway, use 4 quarts of supertech atf and .5 quart of their high mileage atf. Didnt really plan to use high mileage but they only had that left. Used a wix filter.
Noticed my shifting instantly was better. Slam sounds way better than before. I dont get it every time now.
Old 11-18-2018, 02:18 AM   #7
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
Make sure you keep an eye on the fluid level for the next few weeks. I changed my trans fluid a few weeks ago now and just last week I noticed that the plastic shield under the radiator was wet. I assume it's the trans filter thats leaking but I haven't had time to look at it yet. I am also defiantly slowly loosing trans fluid so I can pretty safely say its not coolant leaking from the radiator.
Road salt will be the death of me
1997 SL2, 112K miles
Add to Zeebins's Reputation
Old 11-18-2018, 12:44 PM   #8
odiaz1831
2003 ION-3 Sedan
Will do. Did you check the transmission line to the radiator? Mine was leaking there after i replaced the radiator and hose. Was told o add teflon tape around the threads. I was also loosing fluid tbrough the filter like you said.
Old 11-18-2018, 01:02 PM   #9
cgg17
cgg17 will become famous soon enoughcgg17 will become famous soon enough
cgg17's Avatar
1995 SL2
I lost fluid through the filter on our 99 auto. Filter kept spinning off. Ended up putting a hose clamp around the filter, and then had the clamp butted up against the excess metal gasket to keep it from spinning off. Worked well.
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-18-2018, 01:55 PM   #10
Zeebins
Zeebins's Avatar
I'm not gonna be able to look at it until Wednesday so I'm not sure if it's a line yet. I wouldn't think it would be a the line since it wasn't leaking before and I didn't do anything to it while changing the fluid but when your working on a car that's over 20 years old pretty much anything could break at anytime, lol. So I'll defiantly have to look at the line, maybe it is the source of the leak.
Old 11-18-2018, 04:14 PM   #11
odiaz1831
2003 ION-3 Sedan
Exactly. I didnt plan on changing those hoses. I only did brcause i couldnt remove them because they were so rusted to **** didnt even look like a nut anymore
Old 11-18-2018, 11:40 PM   #12
dummo
dummo's Avatar
1997 SW2
Easiest to change!
That spin-on filter is awesome!
Old 11-19-2018, 03:04 PM   #13
Saturn Night
You shouldn't have ANY slamming of the gears. How many miles are on this car? Are there any other shifting issues, such as a delayed reverse before the slam?
Old 11-21-2018, 11:05 PM   #14
odiaz1831
2003 ION-3 Sedan
Oh yeah i know. Theres a slight delay before reverse, but honestly cant tell if its normal. Occasionally slams into reverse now. Before it would be constant. Valve body and input shaft nut will be done before end of year. She has 130k. Hopefully i can still save her, was given to me by my SIL.
Auto Trans fluid-? sdheavymetal S-Series Tech 3 10-05-2012 09:01 AM
Auto trans fluid sdheavymetal S-Series Tech 16 01-22-2012 04:16 PM
Auto Trans Fluid - Old Oil? flynlowrr S-Series Tech 12 07-26-2011 10:01 AM
Reading Auto Trans Fluid raj49 S-Series General 5 10-15-2010 10:35 PM
Auto Trans Fluid? Which one? `02 SL2 cdb95lt1 S-Series General 1 02-04-2006 02:00 AM
