Old 11-18-2018, 12:09 AM   #1
Bud Tierney
Bud Tierney is on a distinguished road
Default 2000 LW1 Security System Question
Having trouble with Lock/Unlock key transmitter; afraid to lock with transmitter in case won't unlock...spare transmitter ruined by washing machine years ago...
Sat two days while cleaned transmitter and tried different batteries until finally unlocked (may've unlocked per sync try but unsure)...am getting new transmitter...
Question: when locked with transmitter and security engaged, if unlocked manually with key and driven, would security system have fit?? horn, fuel shutoff, whatever???
Owners book doesn't seem to cover, only mentions improper key fuel shutoff...
Any comments appreciated...
Add to Bud Tierney's Reputation
Rate the quality of this post and help Bud Tierney reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bud Tierney is offline   Reply With Quote
Old 11-18-2018, 12:33 AM   #2
Default Re: 2000 LW1 Security System Question
When using remotes to lock/unlock, two things occurs. Doors lock/unlock, GMs Passlock theft deterrent system is enabled/disabled. If a remote is used to lock doors/enable Passlock and the remote dies, is lost, enters the cleaning cycle in washing machines, drowned, run over, stepped on, thrown away and you have the ignition key - simply open the door manually and insert and turn the ignition key to ON within 10-15 seconds to disable Passlock from turning on with flashing lights and cycling the horn. Even if you're slow and Passlock turns on, flashes lights and sounds the horn, inserting the ignition key and turning it to the ON position should disable it or at least the alarm system. Passlock, when enabled and activated (flashing security light) disables injector operation - the starter will work to turnover the engine but the engine will never fire up since injectors ate disabled. In the event security flashes quickly, leave the ign key in the ON position for ten minutes - Passlock will reset in ten minutes while you wait. When security stops flashing, cycle the ign key off and you should be able to startup.
If you buy replacement remotes, bring them to GM or a locksmith capable of programming the bcm to accept (up to) four remotes. There is no diy programming. It must be done with either GM or locksmith using the same scantool to plug into the OBD II port and communicate worth the bcm using GM propriety software.
Old 01-01-2019, 12:13 PM   #3
LeeinOhio
LeeinOhio is on a distinguished road
My old remote stopped working on my 2001 LW300. I took it apart and cleaned the electronics and the dirty case with alcohol and a Q Tip and inserted a new battery. It still didn't work. Upon reading how they work, I theorized that the conductive layer of carbon (graphite) which contacts the electronics when you push the remote buttons might be worn off. I ordered exact remotes (be sure they look exactly like the old remote) for $16.00 postpaid intending to take the new pad out of one of the new remotes. I simply took the electronics out of my old remote and put it into the new remote case with the new pad. The remote now works. I still have a new remote which, if needed later, can be taken to a GM dealer to have it programmed to work. To my knowledge, this is not something a do it yourselfer can do.
Add to LeeinOhio's Reputation
Rate the quality of this post and help LeeinOhio reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LeeinOhio is offline   Reply With Quote
Security system question OU812 S-Series Tech 1 08-31-2012 03:01 PM
Security system question Sky King General Saturn Discussion 9 05-09-2008 01:24 AM
Remote Start / Security system question Jedis Ion General 7 09-18-2007 08:37 PM
Simple question about 2000 S-series Electrical System FDLxStudios S-Series Tech 22 03-27-2006 02:44 PM
2001 SL2 Security system question av2600 Mods and Performance 4 01-31-2004 09:53 PM
