Old 11-17-2018, 07:13 PM   #1
Dooter11
Dooter11 is on a distinguished road
2000 SL2
Default Weird high rev at idle?
The other day during regular driving my 00' SL2 all of a sudden started to keep RPM at about 1300-1500 constant, even at idle.
This was totally random and kept persisting for a few miles and it finally went back to normal after I shut off the car and started it again.
It didn't come back YET, but I'm sure it's something that will get worse with time.
Has anyone experienced this before? I saw another thread about high idle and it the TPS was mentioned. Should I go to that part first if the issue comes back and persists?
Add to Dooter11's Reputation
Rate the quality of this post and help Dooter11 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dooter11 is offline   Reply With Quote
Old 11-17-2018, 09:36 PM   #2
Default Re: Weird high rev at idle?
Classic TPS symptom.
I just changed mine about 4 hours ago, same symptoms. I got the Standard Motor Products TPS #TH387 from Rockauto, ordered on Nov 14, received via USPS Nov 16
STANDARD MOTOR PRODUCTS TH387 $ 27.79
Discount (go to retailmenot.com $ -1.39
Shipping First Class Mail $ 2.99
Tax $ 1.76
Order Total $ 31.15
Old 11-24-2018, 12:55 AM   #3
Dooter11
2000 SL2
So I bought this TPS from an Ebay reputible seller, and the packaging says GM OEM as well as Made in Japan. Is this real? I find it funny that GM would be making parts in Japan, actually quite ironic. Pics attached to post
File Type: jpg B06558C9-36F3-4ACD-963B-FE74CED42B1D.jpg (87.7 KB, 14 views)
File Type: jpg 34E44208-35B6-4A93-838C-C9D6D93435E0.jpg (90.0 KB, 12 views)
Old 11-24-2018, 10:48 AM   #4
That's the genuine GM part.
Weird High Idle issue HFHEARD S-Series Tech 2 10-19-2017 04:15 PM
solved high idle, now high temp/no heat gdf_sl1 S-Series General 7 10-10-2012 12:26 PM
Iacv fixed high idle now getting periodic low idle cmpcpro S-Series Tech 1 07-28-2010 10:18 PM
High Idle AND now High RPMs 1995 SC2 randibou S-Series Tech 3 03-20-2009 05:52 PM
high idle help? weird electrical quirk too daisuke S-Series General 16 12-11-2004 02:49 AM
