Old 03-04-2000, 10:56 AM   #1
mike
Guest
Posts: n/a
Default Front Wheel Bearing
Anyone have any tips on replacing the bearing on front wheel drive '92 SC with ABS. I can get the hub and bearing assembly off the car, need help getting bearing out and new one pressed in. Tips?
Add to mike's Reputation
Rate the quality of this post and help mike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-04-2000, 02:40 PM   #2
England
England is on a distinguished road
Default
Unless you have your own press I would buy the bearing from your dealer and have your local machine shop (Napa,National Bushing etc.)press in the bearing.
Add to England's Reputation
Rate the quality of this post and help England reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
England is offline
Old 03-04-2000, 02:53 PM   #3
mike
Guest
Posts: n/a
Default
I have access to a press. How hard to get the old bearing out of the hub?
Old 03-06-2000, 05:52 PM   #4
LilRedWag
LilRedWag is on a distinguished road
Default
Haven't worked a hub, I would assume the same effort as working with a gear puller?
Add to LilRedWag's Reputation
Rate the quality of this post and help LilRedWag reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LilRedWag is offline
Old 01-10-2004, 08:59 PM   #5
NoDifference
Guest
Posts: n/a
Default
With a press it's easy to remove the bearing. There are special tools to ease the process. Sometimes the race stays on the hub. I use an air hammer with a chisel end to slide it off.
Add to NoDifference's Reputation
Rate the quality of this post and help NoDifference reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-10-2004, 11:33 PM   #6
Dach
Dach is on a distinguished road
Default
Wow, this has to be the oldest resurrected thread I've ever seen! The original poster probably died yrs. ago.
Add to Dach's Reputation
Rate the quality of this post and help Dach reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dach is offline
Old 01-10-2004, 11:48 PM   #7
TheSaturnKid
TheSaturnKid is on a distinguished road
TheSaturnKid's Avatar
Default
Holy crap!
Add to TheSaturnKid's Reputation
Rate the quality of this post and help TheSaturnKid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheSaturnKid is offline
Old 01-11-2004, 12:19 AM   #8
amazinghl
Default
Almost 4 yrs... wow...
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 01-11-2004, 02:54 AM   #9
Default
You wanna talk about diggin deep for a thread!!!
Add to ssicarman's Reputation
ssicarman is offline
Old 01-11-2004, 01:06 PM   #10
NoDifference
Guest
Posts: n/a
Default
My fault, I'm new and not looking at dates. Don't hold it against me because I disagree with Wolfman ssicarman. I'm only trying to help. I'm not trying to take over.
Old 01-11-2004, 01:17 PM   #11
TedL
TedL is on a distinguished road
Default
That can be done, and done better, without putting down others. Otherwise, one might mistake you for an obnoxious know-it-all. That would be a mistake - - right?
Add to TedL's Reputation
Rate the quality of this post and help TedL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TedL is offline
Old 03-16-2004, 02:11 PM   #12
Qlara
Qlara's Avatar
Default
So, what's the right 'Socket' (Size and Depth) for cracking out the Front wheel hub to shaft nut?
Add to Qlara's Reputation
Qlara is offline
Old 03-16-2004, 02:26 PM   #13
TedL
Default
Per Wolfman, 30mm. Standard depth works. Generally AZ will lend it for free.
TedL is offline
Old 03-16-2004, 11:24 PM   #14
Qlara
Qlara's Avatar
Default
30mm 1/2" standard size will work fine then?
That's a pretty big-caliber socket....hehe, thanks!
Qlara is offline
Old 03-17-2004, 11:54 PM   #15
jogle
jogle is on a distinguished road
Default
Get a six-point socket.
Add to jogle's Reputation
Rate the quality of this post and help jogle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jogle is offline
Old 03-18-2004, 10:17 AM   #16
Luke
Luke's Avatar
Default
Fm Jogle
That is so important
Add to Luke's Reputation
Luke is offline
Old 10-24-2004, 11:31 AM   #17
the_skin_eater
the_skin_eater is on a distinguished road
the_skin_eater's Avatar
1999 SL1
Default
sry...have to bring this back again....at least its only couple months this time. I need to change my rear bearing, was gonna do it today but see that you mention press and all that. Do I have to use something special to do this job? Or can I just go out and wiz it?
Im not crazy, just bored...
http://www.cardomain.com/id/the_skin_eater ---Chek it out.
All my time goes to the Talon...My girlfriend is jealous. But my car is jealous that I sleep with her...
Add to the_skin_eater's Reputation
Rate the quality of this post and help the_skin_eater reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
the_skin_eater is offline
Old 10-24-2004, 09:43 PM   #18
wolfman
wolfman's Avatar
Default
On the rears I never bother to just replace the bearing. The rear hubs are much less expensive than the fronts. Replace the entire hub assembly, it just bolts right on.
Add to wolfman's Reputation
wolfman is offline
Old 10-24-2004, 11:42 PM   #19
the_skin_eater
1999 SL1
Default
Oh sorry, forgot to mention, I do have a whole hub. I got one because the other is cracked. Is this no problem to take off then, because I just searched for wheel bearing, which is what the dealership said was wrong, but he said hub when I asked him more about it. Thought it was the same.
front wheel bearing Thundercat Vue Tech 13 01-07-2010 12:09 PM
Front wheel Bearing mgordon1100 S-Series Tech 53 01-06-2010 10:47 PM
Front Wheel Bearing Help justgiver S-Series Tech 3 05-27-2009 09:23 AM
Front wheel bearing... ym42 S-Series Tech 17 04-16-2006 09:55 AM
Front wheel bearing noise SL2abuser S-Series Tech 8 09-27-2003 11:27 PM
