Old 06-29-2008, 09:22 PM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default Replacing the wheel bearing?
I want to replace the wheel bearings and I have both steering knuckles removed. On the back I see a snap ring, once the snap ring is removed how do you remove the bearing?
92 SL2, 5 speed
91 Lx 5.0
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 06-29-2008, 09:49 PM   #2
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Default Re: Replacing the wheel bearing?
Are you serious?? You've certainly been here long enough to have read at least one wheel bearing thread along the way. The bearings have to be pressed out, then new bearings pressed in, new snap ring, followed by pressing the hub back in. Take your removed assemblies to a shop and have them press new bearings in. Should be cheap.
Certified Saturn Technician
Old 06-29-2008, 11:43 PM   #3
amazinghl
Yup, do that.
00 Insight 72mpg
Add to amazinghl's Reputation
Replacing Front Wheel Bearing HyperCube33 S-Series Tech 20 01-01-2015 10:40 AM
Wheel bearing ? Maxwaxquad4 Vue Tech 7 06-23-2008 12:34 PM
Replacing input shaft seal/bearing Khandyman S-Series Tech 1 01-16-2007 03:18 AM
Wheel bearing 94sl2guy S-Series Tech 12 12-23-2005 05:29 PM
Replacing the idler pulley bearing coolgreany S-Series Tech 8 12-12-2004 08:44 AM
