Old 01-05-2010, 02:03 AM   #1
mfedenko
mfedenko has a spectacular aura aboutmfedenko has a spectacular aura about
mfedenko's Avatar
Default Faulty Lifter?
Tick tick tick tick she goes for the first few minutes following a cold start.
Pretty much disappears afterwards, however, depending on the level of my obsessive-compulsiveness , there might some trace of ticking once warm but much attenuated.
Oil level adequate, Mobil 1 5w30, 60k miles. Lifter you think?
Any one have an exploded view of the SOHC? My Haynes manual is not very helpful in that regard.
How would you go about isolating the issue, also, is there a potential for subsequent wear/damage if left un treated?
Many thanks from cold and snowy Montreal.
Add to mfedenko's Reputation
Rate the quality of this post and help mfedenko reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mfedenko is offline   Reply With Quote
Old 01-05-2010, 02:44 AM   #2
Default Re: Faulty Lifter?
The entire lifter system can get a bit out of whack mechanically and clank when cold. The shafts that the rockers run on can either snap come loose and you get excessive clearance. An individual lifter can become leaky and leak down overnight and then tick. You begin the isolation process by listening with a mechanical coupling (big screw driver) placed along the exhaust and intake side of the head/cam cover joint while the engine is running. Place the handle against your ear. You are attempting to identify intake/exhaust and cylinder.
Old 01-05-2010, 03:05 AM   #3
mfedenko
mfedenko's Avatar
Hey Old Nuc, thanks for the suggestions, your posts and opinions are held in high regard.
Would the screwdriver technique be sufficient in isolating intake versus exhaust?
It seems it should be simple enough to find the proper cylinder but could the close proximity of the I/E be as obvious?
Old 01-05-2010, 11:34 AM   #4
One side will usually be a bit louder. Your mileage is really not high enough to be experiencing lifter problems.
Faulty switch?? Timguy1008 L-Series Tech 1 02-26-2009 05:06 PM
Lifter bad or Lifter mad??? hAnNibAl_H S-Series Mods 21 09-19-2008 01:11 PM
3.5 Engine must be replaced if faulty wolfman Vue Tech 10 05-06-2006 05:53 PM
Faulty Lighter? RickK S-Series General 2 08-02-2005 12:14 AM
Faulty Blinkers???? joshc L-Series Tech 11 07-18-2002 07:59 PM
