Old 07-16-2002, 10:17 AM   #1
joshc
joshc is on a distinguished road
Dizzy Faulty Blinkers????
I bought a used 2000 LS1 and I love it.
I was driving the other day and tried to use the blinkers,
but it just clicked really fast and there was no blinking green arrow. Both the left and right did the same thing. Upon pulling over, I found that neither the left or right turn signals were blinking. Both the rear and front signals were out. I was totally unable to signal to anybody that i was turning. First thing I thought was the fuse. I found that the fuse was fine, when I pulled the fuse, it wouldnt even click fast. So I switched the fuse with another one just in case and still no turn signals. I tried to show my wife that the blinkers were not working and all of a sudden they were working fine!! But, ever since then its been off and on, sometimes they work other times they are completely dead and all i hear is a fast click. Anybody else ever had the same problem????
Add to joshc's Reputation
Rate the quality of this post and help joshc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
joshc is offline
Old 07-16-2002, 10:35 AM   #2
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
Default
Some cars use fast blinking as a signal that a bulb is burned out. You may have a loose or bad bulb.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline
Old 07-16-2002, 10:45 AM   #3
Galileo
Galileo is on a distinguished road
Galileo's Avatar
2007 AURA XE
Default
Since none of your turn signals are working when this occurs, you may need to replace the turn signal stalk which includes the T/S switch. Try using your Hazzards to see if all the bulbs are operational.
Beautiful People First~
Add to Galileo's Reputation
Rate the quality of this post and help Galileo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Galileo is offline
Old 07-16-2002, 11:44 AM   #4
Qlara
Qlara's Avatar
Idea
Possibly the Flasher unit (usually located near the same inner fuse relay box) is at fault.
Have you tried the Hazard lights to confirm no signal bulbs have burnt out?
Add to Qlara's Reputation
Qlara is offline
Old 07-16-2002, 11:50 AM   #5
Spanky
Spanky is on a distinguished road
Spanky's Avatar
Default
I agree, check the flasher.
Add to Spanky's Reputation
Rate the quality of this post and help Spanky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Spanky is offline
Old 07-16-2002, 08:30 PM   #6
wolfman
wolfman's Avatar
Default
1 more educated vote for the flasher....
Add to wolfman's Reputation
wolfman is offline
Old 07-17-2002, 09:06 AM   #7
ricksLS1
ricksLS1 has a spectacular aura aboutricksLS1 has a spectacular aura about
ricksLS1's Avatar
Default
Do the Hazards work? I had the problem with the directionals (Arrows inside were on solid I believe and did not flash) and the hazards and the fix was a new Hazard warning switch. They tie in somehow I guess. Is the light off on the harard switch? That was another thing I noticed. This is the only thing the dealer could fix on the 1st shot!
Add to ricksLS1's Reputation
Rate the quality of this post and help ricksLS1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ricksLS1 is offline
Old 07-17-2002, 11:38 AM   #8
Qlara
Qlara's Avatar
Happy
Actually that's right, L-series' hazard switch is a 'Light' unit with different wiring....compare to S-series Toggle-type simple hazard switch.....
Guess it's another Quality-related issue.
Qlara is offline
Old 07-17-2002, 12:12 PM   #9
ricksLS1
ricksLS1's Avatar
Default
I think there is a TSB or even a re-call on this (I never got a recall notice. Here is what the repair invoice says:
Customer states directionals and hazards not working
Cause: Low\Insufficent Sealant
TECH COMM: Nesscasary to R and R Hazard Switch Asm to CRR
Repair: Switch replace hazzard warning
Part 90584073 Switch Assemby
ricksLS1 is offline
Old 07-17-2002, 04:06 PM   #10
Qlara
Qlara's Avatar
Happy
And this TSB is for what year and trim in L?
Qlara is offline
Old 07-18-2002, 09:11 AM   #11
ricksLS1
ricksLS1's Avatar
Default
QLARA ... If you go to a link call All-data you can find information on recalls. If you want to learn about recalls and TSB's I suggest you look at it. Several people in this forum find it useful. Here is the info from alldata.
00-C-03 JUL 99 Recall - Replacement Of Hazard Warning Switch Assembly
It's on all 3 trim levels of the 2000 models LS,LS1 and LS2.
PS: As I said mine wasn't recalled and it went bad. Maybe for a different reason. Unless you pay you can't get more info than I supplied
http://www.alldata.com/recalls/
ricksLS1 is offline
Old 07-18-2002, 07:59 PM   #12
WeeeZer14
WeeeZer14 is on a distinguished road
WeeeZer14's Avatar
2003 VUE 2.2L
2002 L-Series 2.2L Sedan
Default
Hrm... I really need to ask my dealer 'bout this. I have had it happen twice to me in my 2002 L200. Once was in the dead of winter the first time I tried to use my signals one day -- rapid clicking like the relay was going crazy. Just turned the signal on and off a few times and it worked just fine. Figured the relay was frozen or something
Anyway, last week or so, I was again using my signals for the first time of the day and same thing -- rapid clicking to the point of being a buzz. Turned signal on and off a few times, no change. Then I hit the hazard button and it worked fine. Turned off hazards and the signals worked fine. This time temperatures have maybe been in the 70's at night and usually in the 90's during the day.
Otherwise signals always work and I use them to signal every turn and lane change unlike most people in NJ
Add to WeeeZer14's Reputation
Rate the quality of this post and help WeeeZer14 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WeeeZer14 is offline
Blinkers and Flashers out. Need help please geektastic dave S-Series General 5 01-07-2008 09:21 AM
Blinkers not working on a pontiac 6000 91 92[SL2] S-Series Tech 1 05-12-2007 01:41 AM
Clear side markers (NOT blinkers) - legal in NJ? BODKAx3BEPb S-Series General 12 06-05-2006 11:29 PM
LED Blinkers? Esca Ion General 3 12-07-2004 11:27 AM
turn signals - blinkers duffygirl Ion General 30 04-28-2004 07:03 AM
